Question about Encore ENHWIN3 Wireless Router
I forgot my username and password, now i can't log in. How can i setup my router again? I'm using a ENHWI-N3 802.11 n Router
  • 4,281 Answers
First press RESET button for 10 seconds it is in back side of router.Then all settings defaults.Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Posted on Oct 16, 2010
I forgot my paswordhow do i reset it
Username: Admin or Administrator
Password: <Blank>, try just pressing enter or try "admin" as the password as well.
If this does not work and you believe the router is using the default username and passwords try viewing the default settings at routerpasswords.com
Resetting your router
If the default username and password doesn't work it's likely you or someone whose setup your router has enabled a password that has been forgotten. Thankfully most routers will have a small pinhole button on the back or bottom of the router (like that shown in the picture to the right), pressing this button in and holding on this button for 10-15 seconds will hard reset the router. After this has been done setup the router again and enter a username and password that you can write down.
hope this helps
Apr 19, 2012 | Linksys WRT54G2 Wireless-G Broadband...
I keep getting the error 323. I forgot my name and pass to the router and i cant get on the internet through 192.168.1.1 because its not admin i changed that to. can u help and tell me what to do. i have...
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | Linksys WRT54G2 Wireless Router
Forgot my password and cannot reset?
Sep 06, 2011 | Computers & Internet
Cannot set up password for my unit
a user manual is here http://www.encore-usa.com/download/manual/ENHWI-G2_Manual.pdf Power everything off connect the modem to the WAN port on the router - switch on the modem - allow lights to settle switch on the router - allow lights to settle
you can loginto the router and setup according to your ISP instructions you should be able to log onto the ISP website and see what settings are required Often the default settings in a router and connected to a modem will work
hopefully it can help your this idea of mine to your problems my friend so that you can used it in good.
Aug 29, 2011 | Encore ENHWI-G2 Router
Forgot the router password
Press a restart button at the back of your router, hold it like that for 20 seconds.
That should take back all settings to default.
Now you can go to 192.168.1.1 and type default username and password( try admin/admin, or admin/blank, something like that, you can at the bottom of your router box)
And when you enter, there you can set up your new password and choose another router settings..
Good luck, I hope this will help you
Aug 07, 2011 | Encore ENHWI-N2 802.11n Wireless Router...
How to get my password
Your default IP Address username and password are given below
Default IP Address: 192.168.1.1
Default Admin Username: admin
Default Admin Password: admin
If you are having further doubts regarding the Router please visit the following link (http://www.speedguide.net/routers/encore-enhwi-g2-80211g-wireless-router-54-mbps-618 ).Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
Jun 12, 2011 | Encore ENHWI-G2 Router
I forgot the password and username,and i want to change the security password of my router what shall i do?
If you have forgotten the router's password then you have to reset the router to factory default to access the interface again. Then you can use the router's default user name and password, that is admin and admin (or username: " " (leave it blank) and password: admin (all in lower case)
You can find the default passwords on the following website;
http://www.routerpasswords.com/index.asp
Once you have logged in to the router console, you can set new security password
Apr 01, 2011 | Linksys WRH54G Wireless Router
I forgot my password and cant think of it how can i get a new one or reset it with out losing every thing on my computer i need the password so i can get the internet on my wii
the comtrend router password has nothing to do with the PC you can reset the router and then use the default username and password - ASSUMING you already tried the username and password and it did not let you log into the router setup screen
theres a few routers starting CT507 (1 , 1E etc ) see the download page here for a user manual http://www.comtrend.com/support.htm
Sep 28, 2010 | Comtrend CT-507 Router
Need password to internet
You can't.
What you can do is reset the entire router. There should be a button on the back you can press in with a paper clip, hold it down for a few seconds, lights should flash.
Your router will then be reset to factory defaults. Without any more information I can not tell you how to find the default user/pass to log in.
Apr 08, 2010 | Computers & Internet
Forgot linksys router password
Resetting router will revert back to factory default settings. If you had special settings then you will have to set those back up.
Default password to get into the Linksys routers. Username is blank, password is admin.
You will have to setup the wireless portion again after reset.
Apr 07, 2009 | Linksys Wireless-G WRT54G Router
Encore ENHWIN3 Wireless Router Logo
335 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
