Question about RTO PasLode 900420 Impulse Framing Nailer
My 900420 didn't shoot a nail ,i installed new battery and fuel cell,and is 33 degree nail r right for this model .
  • RTO Master
  • 43,501 Answers
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Posted on Mar 06, 2011
My nailer will not send the nail all the way in
Good morning
Daft though it may seem, is the depth of drive adjustment set correctly? If so then it could be either gas that is out of date or a fuel cell that has not been manufactured correctly. Just pop a brand new cell that is a genuine branded product and see if this cures the issue. If not, then take it to you're local repair centre.
Sep 21, 2014 | RTO PasLode 900420 Impulse Framing Nailer
Paslode 900420 fires only one nail and the battery has to be pulled and reinsert to fire again. After shooting one nail, the light alternate between green and Red. I have tried new fuel cell and fresh...
It needs to be cleaned and oiled. You can buy an electrical cleaner spray and oil specific for paslodes at Home Depot. You will have to take the back off (where the filter is) and clean it with the cleaning spray then oil it well. Put it back together and it will work like new again. You will be surprised how much difference it will make. Good luck
Sep 11, 2012 | RTO PasLode 900420 Impulse Framing Nailer
The framing nailer first started not firing all the time and when it did - the nail didn't go all the way in. Now - even though we installed a new cell and fully charged battery - i does nothing. ...
ive found that sometimes where the batt is inserted into the gun theres two contacts down there wit a rubber pads the contacts rest against. check and see with a flash lite if one of the rubber pads has pulled away and wraped itself around the contact, if so pull it out with needle nose pliers or what ever works.if not the problem make sure your batt is good some will read 6 volts but will have no or week current. worst case repAIR SHOP.
Jul 05, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Not firing right
the nail return spring for the piston is stuck or broken,dis mantle the gun and clean and check the spring to see if its broken
Apr 06, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Nail not firing, battery charged, fuel cell good,
When you took it apart to clean it, you may have piched off the large brown o-ring on the head valve. To check this, take the orange head valve cover off and push the gun downard onto a piece of wood as if firing it. Watch the o-ring to see if it clears all the metal fingers around the fan.
Dec 20, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Cleaned impulse framer 900420 put in new fule
If this is a framer there isn't a lockout for it. you would need to pull the front assembly to remove a jammed nail or look for problem.
Oct 20, 2009 | RTO PasLode 900420 Impulse Framing Nailer
2 nails shooting at once from nail gun
Could be couple problems. Are you using the right nails for this tool the right guage and degree? Is the nose worn allowing 2 nails to be able to shoot. Give me the model number and brand and I will try and find a print for this tool with firther suggestions, but these would be the most common
Sep 27, 2009 | Campbell Hausfeld Tools & Hardware -...
Nail gun
have you activated the fuel cell by pressing the black nozzle down onto the cylinder?
Jul 27, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Brand New Paslode 900420, I bought the red gas, charged battery for 2 hours and it work shoot any nails. What am i doing wrong?
Also try and check whether or not the slide where you insert the nails that you push the button down that way it is pushing the nails forward
Jul 15, 2009 | RTO PasLode 900420 Impulse Framing Nailer
RTO PasLode 900420 Impulse Framing Nailer  Logo
221 people viewed this question
Top RTO Air Tools & Compressors Experts
yoopertech
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
