Question about Sharp Heating & Cooling
Fresh air setting on Sharp afx-120nx
Just below the louvers there is a tab that can be pulled out or pushed in to recirculate the air or bring in air from the outside. I'd like to know whether the air is recirculated with the tab pulled out or pushed in.
Thanks.
  • 525 Answers
Http://www.sharpusa.com/files/air_man_AFS100NX_S120NX_S125NX_R100NX_R120NX.pdf
I have a shortcut to a .pdf Adobe file that will link you to the operators manual for this model. Click on the link!
Page 14 tells you to push the button for fresh air, if I read it correctly.
Hope this helps,
Dave E (Illeagle
Posted on Jun 03, 2008
How does plastic head cover pull off on a head split system Panasonic split system air conditioner
Look for 2/3 small plastic covers for screws just under the louver(s) one at each end of the air discharge opening and one in the centre (maybe). Pry these off gently with a small screwdriver and you will see the screws underneath. Remove the louver first to make access easier. There may also be a screw in the centre just above the louver.
Once all the screws are out, the cover should lift up easily from the bottom and then release from the top clips. If it doesn't come off easily, you may have missed a screw.
Jan 26, 2016 | Panasonic Heating & Cooling
Tip
When using the ac on a hot summer day,or a mild spring day,the compressor runs...
When using the ac on a hot summer day,or a mild spring day,the compressor runs all the time.If you set it to low,and turn the temp to cold or toward the warmer side,lets say cool,then the ac compressor runs also,it just cycles,on,and off.No matter what setting you are using on your ac control,the ac compressor stays on,using fuel.Get the most out of your ac,while it uses your fuel,to keep you comfortable.All vehicles have a MAX setting,or a recirculate setting.Always use this setting.I say,always use this setting,not only that,but use this setting.I stress this because you are pulling in air ,from the out side,that is warming the evaporator,and making the ac work harder to give you comfort.In the hot ,hot summer,the settings MAX,and recirculate,keep the air that is in the vehicle,in the vehicle.It recirculates the air,instead of bringing hot air inside the vehicle ,and bringing the temp,up,to a warmer temp.A lot of people don`t even know that this is on the control,or don`t know what it is for.Some times the recirculate button,or dial,will have a picture that looks like a C,but squared off at the corners.So folks,get more out of your vehicles cooling and heat system.Yes ,this will work on heat also,maybe not defrost,but on some cars,it will work.
on Dec 16, 2009 | Air Tools & Compressors
Tip
Climate control settings,on all vehicles
on Dec 08, 2009 | Chevrolet 1500 Cars & Trucks
How do I pull out the air conditioner from the sleeve? Something is holding the middle of the louvers preventing me from pulling out the ac. Help
if its getting hung up on the middle of the louvers check to make sure nothing has pushed the louvers in ,in that spot. Also look inside after you have front cover off to make sure all screws are out and it can have a simple catch lock on the inside to avoid accidental slide out.
May 27, 2013 | Friedrich QuietMaster Electric SS10J10AR...
Where is the vent on my Friedrich AC unit? I don't know how to close or open it.
the fresh air vent open close tab should be located somewhere along the vent louvers look at the bottem of them starting from right to left its their use a flashlight to see it good luck ..let me know /joe/
Aug 25, 2010 | Friedrich QuietMaster RS10J10 Air...
Hot air only, no fresh air or ac air. no engine overheating.
Your hot air keeps coming since the louver get stuck due to mechanism failure inside the ducting console. It usually is controlled by temperature setting. When the setting has no effect then the engagement is loose. Nee to open the dash vent to check out.
Jun 25, 2010 | 2002 Toyota Tacoma
Vent Setting for he Haier ESA406J
You push it in to recirculate the air, the reason that you are getting that sound when you open up the vent is because you are sucking air from the outside as well as the inside of the home. Please rate
Jun 04, 2010 | Haier ESA3056 Thru-Wall/Window Air...
Get cooled fresh air from this ac unit
They are sized to always recirculate, some models do have a "vent" and when open, the vent brings in a percentage (by volume) of fresh air mixed with the air in the room.
May 26, 2010 | GE AJCQ12DC Air Conditioner
Have whirlpool gold accuwave micro hood combo model# GH51884XPS5
The inspector is correct, air should be coming through the top louvers, although you sometimes will have a little air coming from the sides and back. Drop the microwave and see which way the blower is rotated, towards the louvers or towards the back or top. Some units also have a panel that blocks the venting from going the wrong way. Good Luck, Appliance Specialists
Dec 15, 2009 | Whirlpool GH8155XJ Microwave Oven
2005 Toyota Corolla air conditioner is cold but
The air flow does not 'increase' with the recirc button pressed. The fan motor blows at specific speeds, no matter whether fresh or recirc is selected. The recirc feature is there so that you do NOT admit 'fresh/hot' air from the outside into the AC box. In short, the recirc feature is to re-use, or, recirculate the existing air in the car. When it is properly working, on a hot day, the recirc selection should drop the internal temperature at the center air vent about 6 degrees lower than with the fresh selected.
Jul 18, 2009 | 2005 Toyota Corolla
Heating & Cooling Logo
218 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
