SHARP 5320E COPIER
I NEED HELP TO CONNECT THE PRINTER/COPIER TO PC.I TRY TO USE USB CABLE 2.0 AND USB 1.1. I INSALLED THE DRIVER VER.1.1 BUT THE ICON OF PRINTER SHOWING OFFLINE AND READY(FLASHING).
MY PC USB 2.0 AND THE PRINTER USB 1.1.
IF THE PROBLEM FROM THE CABLE HOW I'LL KNOW THE DIFFERENCE BETWEEN USB 2.0 AND USB 1.1 CABLE?
THANKS
  • Anonymous Jun 26, 2008
    I have the same problem with windows vista!!!!
I have the same problem with Vista...where can i find the right software...thank You all!
Posted on Jun 26, 2008
Hi Expets, I have panasnic 8035 Copier. I want to connect it with my Pc to that I can take print for some pdf files. I haave windows 8 installed on PC. Can please some one tell simple way how to connect it...
hi dude...
this copier has two port, parallel and USB port, first u can connect the wire to pc then power on the copier and go to the control panel - device and printers, u can see the copier icon but not installed...
1- u can download from the internet then installed
2- in the device and printer right click on copier`s icon click on troubleshooting then u see the bar and then after 5 maybe 10 min your copier installed...
Oct 26, 2017 | Panasonic DP-8035 Copier/Scanner/Network...
The copier can not print
the copier 5316 does not work with win7.you should have win xp on your pc.uninstall the driver.unplug the usb cable between you copier and pc.insert the cd and install driver again.then connect the copier to your pc.check if there is not any error code on your copier display.
Aug 03, 2010 | Sharp AR-5316 Advanced Digital Imager...
-COPIERS - AR-5316 Advanced Digital Imager Copier: i m not getting the printer driver of sharp AR-531...
The printer driver comes on installation CD when buying a new copier. If you are using it as a printer, insert the CD inside the CD-ROM drive and click open the file written set-up and follow on-screen menu. Connect the USB cable when prompted to finish your installation. Now you can print using your Sharp AR-5316 and that is the driver for it.
May 18, 2010 | Sharp AR-5316 Advanced Digital Imager...
I want to download sharp printer driver AR 5316/5320E
if u ned download manualse and driver softwer see 2 www.givemefil.net every thing is thire
Jan 18, 2010 | Sharp AR-5320 Black and White Copier
User intervention required
install the driver n check by replacing the u.s.b cable n switching it on different ports
Aug 04, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-M205 is not working with windows vista home edition
1. Uninstall the previous driver
2. Re-install the driver ( do not connect the usb cable at this time )
3. After driver installation, the pc will ask you to connect the usb, do this and it should be OK
Apr 01, 2009 | Sharp AR-M205 Copier
Toshiba e studio 166 like printer dont work
connect the copier to computer through USB cable, turn it on, then re-install software it will recongnize the port and machine itself.
Nov 01, 2008 | Toshiba e-Studio 161 Copier Copier
126 people viewed this question
jasbo
jasbo
