Question about GE Dishwashers
I have a GE Dishwasher Mdl# GSD22300Z01WW and it is leaking where the motor connects to the Sump. Is there a way to fix one that sits vertically and if so How?
  • 44 Answers
Replace the motor and sump. It comes as a complete unit.
Posted on Oct 16, 2010
My dishwasher leaks water around the motor when its starts to spin
the most common problem is a hole in the rubber boot that is attacht to the sump are and motor, boot need to be replaced
Nov 16, 2010 | GE Dishwashers
GE dishwasher leaks in middle - bottom - what part do I need
you would need to replace the sump or rather the sump gasket but they dont usually sell the sump gasket without u buying a new sump and most of the time you pay more for just the sump then if you were to buy the sump and motor together as a kit you can find the parts at marcone appliance parts and they will mail you the parts directly before ordering the sump make sure you check the drain pump also it is located in the same area but when you usually have a leak it comes from the sump or the sump gasket but you'll have t crawl under and visually inspect where your leak is coming from please remember to rank this opinion on how it helped with your appliance situation and if i can answeer any further questions please message me back thanks again
rickead1
Sep 02, 2010 | Dishwashers
Kenmore 17263 has a noisy motor and is leaking at the motor
I am not familiar with your particular model - so take my advice lightly.
Usually the motor and sump (not the bottom pan) come as one assembly that come as a unit. Replacing both is usually easiest and economical considering that a motor problem could be caused by something wrong with the sump, or the other away around.
Thiis is something you can fix yourself if you are mechanically inclined.
Sep 12, 2009 | Kenmore 24 in. 17263 Dishwasher
Hello: I have a ge gsd5500 dishwasher. I want to remove the pump connect which is leaking. Key 455 This connects the pump to the main tub in the middle. How do you remove it? Thanks
Remove dishwasher from under the cabinet. Turn dishwasher on it's side. Loosen the clamp holding the motor/pump from the pump connect. Loosen the clamp holding the motor to the sump. Carefully remove the motor from the sump and pump connect. Turn the rubber connect counterclockwise several turns till it is disconnected from the bottom of the tub. Mine had a small crack right along the top. You needed to bend the connect to see it.
May 12, 2009 | GE 24 in. GSD5500G - Multiple Color...
We have a GE Dishwasher Model # GSD 2000 Z02AD - water leaks
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Jan 06, 2009 | GE 24 in. GSD2230Z Built-in Dishwasher
Leak from a black module, where an arm connects
if your dishwasher leaks check out this: Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Oct 11, 2008 | GE Nautilus 24" Built-in Dishwasher
Ge nautilus leak left side
If your dishwasher leaks, check these: Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
  • Lower rack
  • Spray arm
  • Spray arm support
Oct 05, 2008 | GE Nautilus 24" Built-in Dishwasher
Leaking from rear in cabinet
  • Lower rack
  • Spray arm
  • Spray arm support
Sep 30, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
233 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
