Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Is there a spacer between the removable housing (that tightens the bar with 2 nuts) and the actual bar on a chainsaw, model 142 Husqvarna? Thanks, Rbi
  • Husqvarna Master
  • 2,239 Answers
No, there is only a chrome plate to protect the plastic ber pad.
Posted on Jan 05, 2011
How do I change the bar bolts?
Depends on Model. Some you will have to remove muffler, other models are actually inside of oil tank. Once you locate the Square head of the bolts, you can than tap them out gently from the other side using a hammer. Afterwards, tap new bar bolt in its place. NOTE: if bolt head is inside of oil tank you will need to drain oil first.
Jul 14, 2014 | Husqvarna 142 Chainsaw For Parts
Changing the chain on chainsaw
remove the 2 nuts holding the sawdust strut/sidecover and remove side cover. remove chain and bar. clean the chain slot and oil holes on bar. install new chain over bar and place remainder of chain over chain sprocket.back off chain tightener until chain and bar fit. reinstall side cover.
Nov 24, 2013 | Husqvarna 455 Rancher 555cc 35 hp 20"...
Chain wont tighten up
Jeff:
Loosen the two nuts on the right side cover of the saw (1/2 inch socket) turn them out 2 turns. Use a flat blade screwdriver on the screw at the right side front of the housing (near where the bar comes out of the saw). Turn the screw right until the chain can only be pulled up 1/8 of an inch at the top center of the bar. tighten the two 1/2 inch nuts. The two nuts clamp the bar so it won't move. If the chain tensioner still won't work, remove the right side housing by removing the two 1/2 inch nuts and look at the tensioner assembly and how it fits into the chain bar. The problem will be obvious. If you need to replace the tensioner assembly, a new one can be ordered through http://www.husqvarna.com.
Aug 16, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Removing cover to changeing chains
Remove the 2 side casing nuts.
Slacken off the chain tension screw. (it may be attached to the side casing).
Remove bar and chain.
Replace chain on the bar and reposition back and the saw.
Put the side casing back on and adjust the chain tension for the new chain.
Tighten up the 2 side casing nutsonce bar is in working position.
Apr 14, 2013 | Husqvarna Garden
How do I thghten the chain on my 154
loosen the 2 13mm nuts at the base of chain bar. rest the other end of the chain bar on a block of wood to keep tension correct. the adjuster screw is on the other side of the chain bar to the 2 nuts you just loosened. turn it clockwise until free play is removed but but no more. tighten nuts back up. job done.
Aug 09, 2010 | Husqvarna Chain Saw Handle Models 50 51...
Brake mechanism stuck in locked position Husqvarn 142 chainsaw
COMMON PROBLEM----you have to push it forward you wont break it, it is much stronger than you think you just have to hold the cover section and push or lever the bar forward, it will go. I believe one Ace hardware guy had some sort lever wrench made up just to do this for all the people like you. so muscle up and do it "youdoit "
Sep 24, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do you loosen the chain on a chainsaw husqvarna 136?
Hi there. On the outer bar cover near the motor you will find 2 nuts. Slightly loosen those two nuts. Then check around the these nuts or near where the bar attaches to the powerrhead at the front of the saw. You should find an adjustment screw of some sort, which will be the chain tensioning screw (which moves the bar forward/back depending on which way it is turned). This has the effect of either tightening or loosening the chain, so turn this screw noting whether the chain is tightening or becoming loose.
You must slightly undo those 2 main nuts on the side of the chain/bar cover first or the bar will not move and the chain cannot be loosened.
Jul 08, 2009 | Husqvarna Garden
Bar stud removal
only had one 20 years ago they were right hand nut side an left hand into block//used the two lock nuts tightened together to pull studs//like over tightening the lock nuts clockwise breaks stud threads loose ..install new same
Mar 16, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
After i use chainsaw the chain loosend
First you loosen 2 bar nuts , then tighten adjuster screw ,this is on cover behind bar nuts or between bar nuts or inside bar on crankcase depending on what model you have ,its also helpfull to lift nose of bar while you tighten adjuster,dont over tighten chain ,then tighten bar nuts
Nov 17, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
85 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
