Question about GE Spacemaker Washer and Dryer Electric Laundry Center
My GE Product Quality Spacemaker Luandry, washer water level sensor is not working. I did a load of laundry and found out during the rinse cycle my water did not turn off, therefore leaving me with one wet mess. After cleaning everything up, i ran an empty load to monitor the machine. While filling up the tub the water, again, did not cutt off. I manually cut the water and put the machine to the next cycle and everything else worked fine including the spin and draining. Is there a simple fix to check the sensors?
    President:
  • 1,430 Answers
Here is a link that should help testing and replacing a pressure switch
Posted on Oct 16, 2010
Testimonial: "Thanks for the video... it wasnt for my exact make but I think I get the just of what needs to be done. Thanks"
This question is old, but other viewers may still be searching. This guy explains the testing process is very easy to follow steps and without the need of a volt meter to test.
Posted on Dec 04, 2012
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Cold Pulses when set to HOT only
if you want only hot water, shut off the cold.. its only really used during the rinse anyway..
Feb 02, 2014 | GE Spacemaker Washer and Dryer Electric...
I have a GE Spacemaker washer and it does not agitate. It spins at the end. Please suggest what should I do?
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Sep 30, 2011 | GE Spacemaker Washer and Dryer Electric...
Water sensor not working. Started a load of Laundry and the water did not shut off therefore flooding my whole Laundry room. How can I fix this myself?
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug or turn off circuit breaker ,if the water continues to fill, that valve is sticking,it is what to replaced
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps
Gene
Jul 31, 2011 | GE Spacemaker Washer and Dryer Electric...
"GE Quality Product Spacemaker Laundry"
you could have a broken belt or a frozen pump pulley. the leak has to be addressed to see where it's coming from. it could be from the pump hoses/connections. it could be the main tub seal that's leaking. if you're not handy with tools and test equipment, i suggest you call someone to have a look at it. these are problems that wont be resolved by pushing a button.
and thankyou for using this site. i hope you will continue to use this site.
if you have any further quesions or need further advice, repost another question. be sure to include the model number as well. you gave a good explanation, and that helps. anything you can think of can be of assistance
thanks,
mike
Jul 07, 2011 | GE Spacemaker Washer and Dryer Electric...
Hello: I have a tenant who is having problems with a GE Spacemaker washer/dryer -Stylemaster # is 622866-A. Here is how she describes the problem: ...it seems as though the washer isn't functioning...
If a spin and drain problem you can pull the front off to see if perhaps a small item (ie. sock or like size item) is stuck between basket and tub or in the drain hose? If it is a wash time problem that would be another direction.
Oct 06, 2010 | GE Spacemaker Washer and Dryer Electric...
Wash cold rinse hot?
reverse the hoses @ the supply connections,that will take care of it
Mar 09, 2010 | GE Spacemaker Washer and Dryer Electric...
GE SpaceMaker washing machine does not stop filling.
try replacing your water selenoid coming in. remember it isnt a mechanical timer it is a computerized timer, so if the selenoid isnt the problem, it might be the computerized timer. computers are very finicky, pain in the a- -!
Mar 23, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Washer stops before the rinse cycle.
It will probably continue to be an issue, but the last three loads it has worked fine. Hopefully the mishap was a fluke.
Thanks for your help.
Feb 18, 2009 | GE Spacemaker Washer and Dryer Electric...
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
684 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
