Question about Panasonic Televison & Video
The screen keeps flashing a blue box with the name Panasonic and all the features of the tv and I can't get it to stop.
Press and hold the Play / Repeat button on the TV. It will beep and give you some message about inserting a cassette. Just hold the button for a few seconds. Should do the trick. Worked for me.
Posted on Nov 23, 2010
The TV turns on but cannot find a signal (as has been normal when swictching to HDMI inputs). Usually it takes a second and the Cable or FIOS signal shows on screen. As of today, the images never comes...
Tries tv and cables boxes uplug,replug it back like about an hour later for the tv resetting itself back to the factory setting and those pay boxes updated it softwares.Take the HDMI cable plug it in into another tv HDMI hub.Tv should have signal and work again.
Feb 17, 2011 | InFocus ScreenPlay 61" Rear Projection...
50" plasma panasonic 720p tv has several colored
Flashing error codes could be the Direct tv box itself.Because tvs have problems within itself don't flashes error codes on the tv screen,the problems,just show up.Tries tv and Direct tv satellite box unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting and the Direct tv box updates it softwares data's.The problems should be solved,if have the same problems,first call Direct tv for a replacement box,see how it work out.Than turn ur attention to the tv.
Feb 08, 2011 | Panasonic TC-P50X1 50 in. Plasma HDTV
My Sony Grand Wega KF42E200A has stopped presenting subtitles at the bottom of the screen. I have them on CC1 and they just stopped working out of the blue. No changes have been made in video settings. Is...
call the cable company most cable boxes have the closed captioning feature in them and if they reset the box it will turn it off. try turning the cable box off with the tv still on then press the menu button on cable box remote( with box still off) a menu should pop up on tv screen and look at the closed caption selection if off turn on.
Feb 06, 2010 | Sony Grand WEGA KF42WE610 42" Rear...
How do I scan with my Panasonic 8020E?
firstly ur copier must be on a network, down load a driver called the communicatin utility from the workio web site , its on the driver disk if u have it, run that on ur pc ans start it up, it should open a blue box bottom right of ur screen, put ur name in the key name box and same in the screen name box, thats all u have to do
Sep 09, 2009 | Panasonic DP-8020E Black and White Copier
I have a ge dect 6.0 and it flashes a blue light and display says NEW VOICE MAIL...i have an answering machine not voice mail..HOW DO I GET THE BLUE LIGHT TO STOP flashng?
Try pressing the message button and see where is rings to. If this is on a phone system the call back feature got turned on by someone call that phone while it was in use. By pressing the message button that ext. will ring...answer it and then the light will stop blinking. Also note this can be set multiple times. Another way is if this is on a digital KSU enter the feature clear code *790 that will also clear message light.
If this is one of the consumer line phones the phone company is sending a signal that the voicemail box they are providing has messages. You will need to consult the instruction manual to clear that if the phone company does not provide that service. If it there and you don't know its there the light will keep coming back on. If you need to find your phone try this link.
http://service.us.panasonic.com/operman/Default.aspx?No=0&jspStoreDir=panasonicdirect&catalogId=13401&Ntt=manual&NttRaw=manual&N=779832047&URL=vShopSearch&cm_sp=SiteSearch-_-MainSearch-_-Consumer&Ns=&storeId=15001&Nr=12001&edb=com.panasonic.commerce.search.beans.PNAEndecaDataBean%401908da01&Ntk=MainSearch&cmTag=true
Jul 28, 2009 | Lands Phones
Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Panasonic TV/VCR Remote Problem
Hold down the play/repeat button on the TV itself for 5 seconds. That toggles in and out of demo mode. ;)
Nov 17, 2007 | Panasonic PV-M2048 20 in. Combo
Panasonic Logo Constantly Across Screen
With the Power On, hold down the Play/Repeat On button for 5 seconds. This will toggle the 'feature' on and off.
Nov 06, 2007 | Panasonic PVQ-M2509 Combo
Tv monitor turns blue during forward or reverse vcr search
On some TV's the screen will go blue if there is not a strong, solid video signal present. This is to prevent the showing of very snowy or all snow channels, or garbled, mixed-up external video signals. This is normal. On some VCR's the video signal changes when the FF or REW search feature is used, and this could trigger the TV to go to blue screen. The only way around this if you can enter the TV's menu and turn off the blue screen feature.
Jun 23, 2007 | Panasonic PV-V4020 VHS VCR
Televison & Video Logo
249 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
