Emachines EL1320-01 desktop computer running windows XP. The computer is stuck in an infinate reboot. will not boot in safe mode. will not enter utility partition when I press F11 durring bootup. Need to get into recovery partition to restore system. Help!
Had the same problem. Luckily I'm a Computer Technician so I had the experience to know that you can use a Bootdisk (Such as Dell DSRFix or Partition Magic Partition Table Editor) to temporarily change the partition from 00 to 80 on the Hidden Recovery Partition. This requires you to put the 00 where the current 80 is on the normal 'C Drive' partition. You will most likley need to change the 00 & 80 back to the way it was, after you are finished re-loading the factory copy of windows. Note: If you opt to utilize the Dell DSRFix Tool, you only want to use the Partition Table Editor (not the DSRFix, as this is an E-Machine).
Posted on Apr 19, 2011
How do you get out of safe mode?
Safe mode is normally manually activated by pressing F8 at startup. However if it is stuck, you can try disabling it from the system configuration menu:
If using Windows XP:
1. Start the machine and boot to the Windows desktop.
2. Click Start > Run
3. In the dialog box, type msconfig and press "Enter". This will bring up the configuration window.
4. Click on the "Boot" tab and in the lower left corner under "Boot Options", untick "Safe Mode".
5. Restart the computer.
If using Windows Vista/7:
1. Follow the same instructions as above, however when you click Start, just type msconfig in the search box at the bottom of the Start Menu and press "Enter".
Jul 19, 2014 | Computers & Internet
Disable safe mode
Which operating system and do you have Norton antivirus ???
Turn Off Safe Mode
You rebooted your PC at least 10 times now, and still it refuses to start in anything other than Safe Mode.
Your many attempts to perform a system restore have yet to be victorious. It just will not boot up normally.
According to Microsoft, if you have Norton Antivirus 2001 installed on your computer, it is the root of the problem. Microsoft suggests you disable it.
Restart your computer. Let it load completely in Safe Mode.
Press "Run" on your Start menu.
Once you see the Open box, enter into the provided text box: misconfig.
Then press "Enter" or Select "OK."
Select on the new dialog box that has appeared "Selective Startup."
Select "NAVAP.VxD" on the Static VxD tab.
Remove the check in the check box you now see.
Select "OK."
Remove the check in the check box next to Norton Auto Protect.
Select "OK."
Reboot your system and it will be in Normal Mode.
Turn Off Safe Mode in Windows XP
The purpose of booting your computer in safe mode is to resolve issues.
Only your basic, most dire drivers and programs will run to block viruses and surreptitious software from executing on your system.
But once the issue is resolved, you need to get back to the standard Windows mode. In order to turn off safe mode in Windows XP, you must go through the same steps that you took to turn it on.
Reboot your Windows system.
Press the "F8" key several times as soon as you see the first Windows XP logo appear on your screen as the computer is booting.
This will bring up a black screen that displays the "Windows Advanced Options Menu."
Press the down arrow button on your keyboard to scroll down the list.
Select "Start Windows Normally" and then hit "Enter."
Allow the system to boot.
Enter your Windows XP user password (if you set one) and log in as usual.
Nov 14, 2013 | Computers & Internet
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
Microsoft Windows Vista and Windows 7 users
To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
My eMachines T3882 with Windows XP just reboots over and over
Sounds like a sick hard drive. When it starts to reboot, press F8 and choose Windows Diagnostic Test. It will show a hard drive failure if one exists. If it finds a hard drive error, the hard drive is junk and needs replacing. Once replaced, you can run your restore/recovery disk to install Windows back to the condition it was in when you bought it.
Dec 16, 2009 | E-Machines eMachines Desktop PC
MY EMACHINES COMPUTER IS STUCK IN SAFE MODE
hi ...
whn you say the computer boots up in safe mode..
in this list you should have an option called as load windows normally (similar to this)
use the arrow keys and select it.. and then press enter and please do let us know what happens..
it should ideally work...and if it boots up to your desktop please investigate..
Aug 20, 2009 | eMachines ET1161-07 Desktop PC
Hard drive won't reboot. Stuck in a loop.
start the machine press f-8 select "safe mode" press enter run chkdisk/r
May 22, 2009 | E-Machines eMachines Desktop PC
Emachine w3107 reboots when windows xp loads
These kinds of issues are most often related to driver conflicts. First thing you need to do is reboot your PC while holding F8, until you receive the menu about booting in to Safe Mode. Try booting in to Safe Mode.
If you can get in to Safe Mode, disable any new devices you have recently installed, reboot again, this time letting it try to boot all the way to Windows.
If it reboots again, go back in to Safe Mode and disable/uninstall something else.
Basically, it is a process of elimination. Safe Mode loads a very minimal set of system drivers, so if you can boot in to Safe Mode but not in to full Windows, the problem is one (or more...) of the drivers that load in Windows but don't load in Safe Mode.
Mar 19, 2009 | E-Machines eMachines Desktop PC
Only getting EMachines/Windows XP Logo when boot up T3882
you have not set the cdrom as first boot device in the bios (press F2 or Del on boot up to get in bios), choose cd as first boot device, save settings and restart the pc with your cd in the drive and then when prompted press enter
Aug 18, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
246 people viewed this question
David Payne
David Payne
