My acer netbook doesn't list my touchpad in the control panel
  • 3 Answers
Did you look under Mice and other pointing devices? Should list Synaptics PS/2 TouchPad
Driver files are in C:\Program Files\Synaptics\Syn TP\
Should be 21 files. If not, then I would suspect the device was uninstalled.
Posted on Oct 16, 2010
My touchpad doesn't work on my aspire one D255 netbook. The wireless mouse works but the touchpad doesn't respond to any touch. How can I make the touch pad work? Is there a function?
Hi!
If the touchpad worked well before and suddenly doesn't work any more, it is most likely it was stopped by pressing the key combination FN F7. To be sure please press the same combination again and check if it works.
If it still not work, please check if the touchpad drivers are installed on you netbook.
To do so, please open device manager. (opening the device manager could be done in more different ways, e.g. click START button and, depending on your operating system enter devmgmt.msc in the Run box for windows XP or in the Search programs and files box in windows 7).
Now, under mice and other pointing devices you should find your touchpad.
If the touchpad is not listed in device manager, drivers for it have to be installed.
Drivers for your netbook's hardware are on the acer support page.
Hope it helped,
Bogdan
Aug 28, 2011 | Computers & Internet
Acer Aspire One Netbook Touchpad
fiddle with your cursor settings in control panel under mouse settings
Mar 14, 2010 | Computers & Internet
Touchpad not responding in netboook
There's a little button right above the touchpad. If the light on this button is orange, the touchpad is disabled. Press it again until the light is white again and your touchpad should work.
Nov 17, 2009 | Acer Aspire One Netbook 8.9" Notebook
How do i adjust the sensitivity of the touchpad of acer 4730z?
Go to START, CONTROL PANEL, click MOUSE.
Now click POINTER OPTIONS tab and in here, you can adjust the speed and precision of the mouse pointer.
Nov 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
I have a asus Eee pc904hd and the touch pad is turned off the cursure is locked i have pressed the fn f3 but no luck
Check in control panel.
GO to start menu->control panel.
Then find touchpad utility and enable touchpad if it is disable.
If still it not works then reinstall touchpad driver.
Let me know if you need further assistance.
Thanks.
Oct 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
I have a Acer Aspire One, and the when I try to click any link with just tapping my finger on the mouse pad nothing happens...I can move the mouse around but not click anything..
Go to control panel > mouse > on the upper tab, there should be a tab for device settings. Open that up and it should list your touchpad, highlight it and click on the settings button. In there enable "tapping" on the touchpad. Click apply and ok. If the touchpad does not show up under device settings or there is no device settings tab, then the driver for the touchpad is missing or corrupt. In the control panel, go to device manager and scroll down to mice and pointing devices, if the touchpad is listed there, right click on it and click Un-install, but keep the driver if there is one. Reboot the machine and windows will be forced to reinstall and update the driver. Let windows search for a new driver if it wants to. You should be back in shape.
Oct 16, 2009 | Acer Aspire One AOA110-1113 Netbook
My touchpad will not respond when I tap it anymore. I have to use the left button. I used to be able to tap or double tap the touchpad and it would act like the left mouse button. All of a sudden it...
On the bottom bar by the clock, if your computer is newer there should be a small icon that controls your mouse. Simply right click on it and check the box "tap to click" or similar. Hope this helps!
Please rate me if i am helpful.
Thank you.
Yboyandrei
Aug 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire Netbook..Can't use keys or right/left click.
go to control panel then mouse properties you will see the buttons the left & right then click the task that you want to do.
Aug 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
I've had the acer one for 2 weeks. While using it today, the single and double click functions of the touchpad stopped working. The touchpad still moves the arrow around the screen and the left and right...
Hello cskpuels,
It sounds like the touchpad is working ok but probably needs some setting(s) adjusted. The touchpad settings can be accessed through the windows control panel. But before going to the control panel it's useful to review the touchpad basics for single and double clicking. They are as follows:
•Tap once on the main touchpad for single click.
•Tap twice for double click.
•The lighter the touch, the better the response.
•Tapping harder will not increase the touchpad's responsiveness.
•Opening the Control Panel
The Windows Control Panel can be opened by:
Selecting *Start > Control Panel (on Windows Vista)
- OR -
Start > Run > Type 'Control' and select OK (on Windows XP)
*The Enter key may be used on the keyboard in place of touchpad clicking*
In the Control Panel, do the following:
•Select Mouse [Enter] (Brings up the touchpad properties sheet)
•Look at the Buttons tab in the touchpad properties sheet.
•Adjust the settings and test the touchpad until you get the response you desire.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Aug 01, 2009 | Acer Aspire One Netbook 8.9" Notebook
My acer aspire touchpad frozes
right click My Computer >> Manage >> Device Manager.
See if the drivers are installed
May 22, 2009 | Acer Aspire One PC Notebook
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
