Question about Yamaha RX-V2090 Receiver
How to run outdoor speakers from my in house receiver
Hi,I have an older yamaha rx-v2090 receiver and want to run some out door speakers near my pool.How can I do this where only the speakers outdoors come on and not the whole system in the house and outdoors.thanks for your help,Tony.
    Novelist:
    Champion:
  • 218 Answers
If you have a button for A and/or B speakers on the front of your unit, then use the A (or B) speaker connections for the inside speakers and B (or A) speaker connections for the outside speakers. Then of course you just select either A or B depending on where you want the sound to come out. If you select A and B then it will come out at both locations. If you don't have A/B speaker selection available on the unit, then you will need a speaker select switch (from Radio Shack) or else wire up a four pole double throw toggle switch to do the job.
Posted on Jun 03, 2008
Main speakers do not work on yamaha 2092
is the speaker select button pushed in?
Jan 08, 2014 | Yamaha RX-V2090 Receiver
Hellow, I own a rx-v2090 , everythings works, the problem is if i crank the volume to 11 to 12 O' clock position, it looses the base and half a minute later it shut itself. please can you explain to me...
Sounds like from what you describe is that your speakers ohms might be to low for the Receiver and making it over heat.Take a look at your speakers ohms rating and then look at what your Receiver is rated for most receivers can handle down to about 6 ohms nothing lower.There are some out there that can handle lower but from what I can see about yours it handles about 8 ohms.
Jun 16, 2011 | Yamaha RX-V2090 Receiver
Zone 2 stopped working for no apparent reason. Are there settings that I could have messed up or is it in the cables?
I have the RX-V1065. yes there is alot of settings that can be messed up with one wrong click on the remote especially if u have kids. If this problem happened while it was playing and no one messing with remote could be equipment. I dout your wires were messed up or the speakers bad cause receiver has overload protection for that and would display it unless someone tripped over wires and they came unplugged "kids" But try checking all settings on receiver first. Good luck
May 23, 2010 | Yamaha RX-V2090 Receiver
Main speakers A and B not working...
Please preform Test Tone check and adjust front speaker level that seems very low.
Feb 20, 2009 | Yamaha RX-V2090 Receiver
Is there any DTS decorder player that suit with Yamaha RX-V 2090? Thank you.
Try the Technics SH-AC500D Digital Surround Processor. Its outputs should match the inputs on the RX-V2090. I own both units, though I am using a DDP-1 with the Yamaha receiver. I use two separate amps with the Technics to achieve surround sound using my good vintage stereo system (two of them actually - one for front and ane for rear). The Technics is a nice piece of kit.
Aug 13, 2008 | Yamaha RX-V2090 Receiver
How I connect DVD Player thru Yamaha RX V2090
please check your input source in tv and confirm right selection-check interconnect cables.
Jul 21, 2008 | Yamaha RX-V2090 Receiver
No zone 2 sound coming from yamaha amp rx-v861
Had same problem. A and B speakers are basically connected together, and there is no way to get the same volume out of each speaker. This is not a multi-source receiver like Onkyo. Zone 2 needs to go to a seperate amplifier and select teh correct source on the fornt,
Jun 29, 2008 | Yamaha RX-V995 Receiver
Two possibilities for the no sound on the main speakers:
1) May be caused by the lack of the pre out main in jumper on the back of you reciever.
2) Check to make sure the -10db selector is not stuck between positions.
Dec 16, 2007 | Yamaha RX-V2090 Receiver
No Sound
Three things to look for for the no sound problem:
1) Make sure the pre-out main-in couplers have jumper wires in them
2) Make sure the mute is not engaged
3) make sure the speakers wires are inserted properly. you need to unthread the five-way binding posts before inserting the wire between the post nut and receiver.
Aug 31, 2007 | Yamaha RX-V2090 Receiver
RX-V2090 Bass Output Problem
A couple things to check on the no bass problem:
1) Make sure your center speaker is set for normal, not large.
2) Make sure your speakers wires are in phase (+ conn. to + and - conn. to -).
Jun 23, 2007 | Yamaha RX-V2090 Receiver
Yamaha RX-V2090 Receiver Logo
210 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
