Question about Traeger Industries BBQ075 All-in-One Grill / Smoker
I have a Traeger Pellet Grill model #BBQ075 it won't light and treied the instructions for manual lighting it and that wouldn't work. The pellets do feed thru, just won't light
3 Suggested Answers
  • 332 Answers
SOURCE: The pellet auger on my traeger doesn't feed pellets
Call Treager direct
They have a great customer service dept and if you have an issue with a motor or control board they are really good about sending replacements
800-372-3437
If this helps please leave a comment
Posted on Mar 30, 2010
SOURCE: I turned off my grill
Whenever you finish using your Traeger it is always best to lift the lid and turn the controller down to the smoke setting and allow the temp to drop for a few minutes. This will also slow down the delivery of fresh pellets into your firepot thus starving the fire of fuel.Once the temp drops below 200 deg F than shut off the controller. If you have any wind blowing remove your Traeger out of the draft of the wind and the fire will go out on its own.
Posted on Sep 19, 2011
Auger is not working . How do I trouble shoot
You may want to try vacuuming the area around the burn chamber or turn the auger to see if it is froze up. Same thing as a pellet furnace.
Apr 13, 2016 | Traeger Lil Tex, Elite, Deluxe Pellet...
Burner not working
Traeger Industries burner not working Grills & Smokers ...
www.fixya.com > Forum > Tags > burner not working > Grills & Smokers
Traeger Industries grills & smokers burner not working related questions and answers. Ask your ... Question about BBQ075 All-in-One Grill / Smoker. 1 Answer ...
Traeger Industries water pump not working Grills & Smokers ...
www.fixya.com > ... > Tags > water pump not working > Grills & Smokers
Traeger Industries grills & smokers water pump not working related ... Question about BBQ075 All-in-One Grill / Smoker ... our auger stopped working how can we fixthis. it is not the electrical .when you put pellets in the burner it will light and ...
Support - Traeger Wood Pellet Grills
www.traegergrills.com/support.html
Traeger Pellet Grills, LLC. ... Why won't my grill light? ... Why is my grill running so hot on smoke? .... Large Commercial Trailer. Download manual. View All ...
FAQS - Traeger Wood Pellet Grills
Jan 01, 2016 | Traeger Industries BBQ075 All-in-One Grill...
I keep getting an error msg. When it finally starts, it shuts off with the Err
Hi Terry,
This may help... ...from Treager's site FAQ
"My Unit Goes Out On Smoke
  1. Open the cooking chamber lid and remove cooking grill, angled drip pan and U-shaped firepot cover. Look and see if there is a large accumulation of pellet ash in and around the firepot. If there is, it will need to be cleaned out. Do this ONLY WHEN THE GRILL IS TOTALLY COLD! Replace U-shaped firepot cover, angled drip pan and cooking grills and resume cooking/smoking process.
  2. If this does not remedy the problem, please contact the Traeger Service Department."
From my personal experience, cleaning out the pellet ash is needed when the smoker will not hold a high temperature regardless of the thermostat setting.
In your case, the fire pot may be packed with pellet ash and pellets from the auger jamming.
Good luck.
May 29, 2015 | Traeger Industries BBQ070 All-in-One Grill...
My trager grill is smoking a lot in the pellet hopper
That could mean that pellets in the augur have caught fire and it can work its way back to the hopper. Then you really have a problem. Are you sure the fan is running?
You should be able to hear it. The fan helps keep the heat from working its way into the augur. If it's not running, you should also be having trouble controlling the temperature.
Traeger has specific instructions on its website for testing various components including the fan and customer support can assist you with this problem.
Here's a link to the Traeger website: http://www.traegergrills.com/. I'd suggest you get in touch with them ASAP because you definitely don't want to deal with burning pellets in the hopper.
Jul 05, 2014 | Traeger Industries BBQ100 All-in-One Grill...
Traejer pellet grill auger jammed up
Contact Traeger customer service at http://www.traegergrills.com for parts and installation instructions. Also check out the FAQs. There are instructions on replacing and aligning the augurs.
Mar 23, 2014 | Traeger Industries BBQ070 All-in-One Grill...
Traeger pellet stove minuteman MPW070 user manual
does the auger in my mpd070 pellet stove have a carrier on both ends
Feb 08, 2014 | Kitchen Ranges
I couldn't get the temperature to regulate. The digital readout showed it getting hotter and hotter, then the GFCI would blow. I finally got it to work but I don't know how I did it. The next day I tried...
I answer quite a few questions about Traeger Pellet Grill/Smokers, but this is a new one. My best advice is to contact Traeger's Technical Support Dept @ (800) 872-3437 and let them sort it out.
Apr 04, 2011 | Traeger Industries BBQ070 All-in-One Grill...
Why is smoke coming out of the pellet box. Temp is set on smoke and it is rising up to 380 degrees
Not sure which Model Traeger Grill/Smoker you have, but they all work pretty much the same way.
The following is a link to the model BBQ055. It should help you solve the problem, which simply may be an incorrect adjustment. If that doesn't help call Technical Service @ 1-800-872-3437.
http://www.traegergrills.com/Media/pdf/Manuals/BBQ055_Manual.pdf
Feb 14, 2011 | Traeger Industries Grilling
Pellets keep feeding. cant control temp.
Are you trying to grill or smoke? In ether case, once the pellets ignite and the temperature you want has been reached, the switch should be turned to off. That should stop the auger pellet feed.
Also, are you using Traeger Pellets. They are the only one designed for this grill/smoker. If you're using heating pellets for a pellet stove, that also would cause that problem
If you've lost your Owners Manual, here's a link to it in a downloadable and printable pdf format.
http://www.traegergrills.com/Media/pdf/Manuals/BBQ070_Manual.pdf
Hope this helps. Please let me know.
Feb 06, 2011 | Traeger Industries BBQ070 All-in-One Grill...
Traeger Industries BBQ075 All-in-One Grill / Smoker Logo
594 people viewed this question
Top Traeger Industries Grilling Experts
Gary Kenady
Gary Kenady
Craig Butler
Craig Butler
Paul Carew
Are you a Traeger Industries Grilling Expert? Answer questions, earn points and help others
