Question about Kohler - Toilet Seat - Moondance - K4717-CP-D8
Our seat is lose. How do you tighten the bolts? We can't see how to reach the nut.
4 Suggested Answers
  • 68 Answers
SOURCE: how do you tighten bolts
The caps are at the back of the toilet seat. Just under the cap cover are the bolts. You will need a meduim sized flat screw driver. Hold the nut on the bottom and use the screw driver to tighten.
The covers pry up with a small screw driver IF they are square.
If they are more circular with ears they rotate counter clockwise about 30 degrees, Then lift the lid off.
Please rate this response and Good Luck, Phil
Posted on Dec 29, 2008
  • 51 Answers
SOURCE: broken bolt on toilet seat
your new seat will have bolts and nuts with it.
Posted on Jan 12, 2009
  • 744 Answers
SOURCE: Removing rusted nuts from bolts to replace toilet seat
Try:
* Penetrating oil...let it soak at least 1/2 hour
* If the nut is stripped, try either grabbing it with vice grips
* If all else fails, either grind it off, or use a nut splitter. Nylon is pretty soft, so it should be relatively easy to break
Posted on Apr 28, 2009
How to remove back seat of hhr 2006
Rear Seat Replacement
showgif.do?image=1592810
Callout
Component Name
Notice: Refer to Fastener Notice in the Preface section.
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Preliminary Procedure Remove the rear compartment floor stowage compartment tray. Refer to Rear Floor Trim Plate Replacement .
Nut, Rear Seat (Qty: 6)
Tip
Roll the seat forward enough to get access to the nut that attaches the center seat belt assembly to the floor.
Tighten
45 N?·m (33 lb ft)
Bolt, Rear Seat (Qty: 3)
Tip
  1. Adjust the seat forward or rearward to access the bolts.
  2. Remove the plastic trim pieces to gain access to the nuts.
Tighten
45 N?·m (33 lb ft)
Rear Seat Assembly
Oct 28, 2015 | Seat Cars & Trucks
How do I tighten the arm rest bolt on a 2002 Toyota Sequoia?
Apply pressure on the interior nut by pulling the bolt towards you why carefully tightening.
Aug 28, 2014 | 2002 Toyota Sequoia
Huffy stalker 18 speed, I can't tighten the stem.
If you are talking about the handle-bar stem, the bolt you need to tighten is right in the middle of the post. It may have a snap-on plastic cover over it. This will be the head of a long bolt that reaches down inside of the stem where the nut is shaped as a wedge that serves to tighten inside the tube of the front fork. If you are talking about the the seat-post, then your seat-post might be of too small diameter.This page shows a good picture of the handle-bar stem bolt and wedge nut.
http://www.bikewebsite.com/bikeoh.htm
Mar 03, 2013 | Cycling
The seat has come lose and the bolt is not catching on anything so the seat is not secure
Please replace the bolt and nut of the seat with a new one and add washer in order to tighten the seat as required.
Mar 27, 2011 | Cycling
One side of the toilet seat has come loose and can be partially lifted
It'll take getting down on your hands and knees in front of a toilet, but oh well. :-) Look beneath the side that is loose. There will be a threaded plastic bolt coming down from the top of the toilet to below where you are looking. On this threaded bolt there is a nut that needs to be tightened. Reach up and tighten it as tight as you can with your fingers. To make it even tighter, use a pair of pliers... then just snug it firmly. For ease in getting it off another time (e.g. should you want to replace the seat cover), I suggest first taking the nut OFF. Then take plumbers silicone tape (found in the plumbing section at any hardware store; it looks like white thin, thin tape) and wrap the bolt with it. Note: you need to take pull the bolt out completely to do this. After wrapping it with silicone tape, insert it back into the hole, and then twist the nut back on; snugging-up with a pair of pliers. This will keep the nut from working itself off, and will make the nut come off easy should you ever desire. Good luck.... :-)
Feb 27, 2011 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
The toilet seat is very loose and I can't figure out how to tighten it. Please help! Its about to come off completely Thanks
Usually there are plastic caps that snap down over the bolt head.
Shut toilet lid and get down close with a flashlight.
Seat attaches in two places.
Reach underneath and you can feel two bolts with nuts.
You don't need to see them, just feel with your hand.
The bolt head is covered with a plastic cover.
The cover is added for aesthetic purpose only.
Use small screwdriver or fingernail file or nail or scissors to pry up the cover and reveal bolt head.
Use bigger screwdriver to tighten bolts.
You may have to keep one hand on underside to hold nut while turning bolt clockwise.
Another trick is use hand to push bolt all the way up, and then finger tighten bolt most of the way, and use screwdriver for last few turns.
Tighten bolts good and tight, but don't overdo it.
Bolts will come loose again and you can tighten more later.
Dec 13, 2010 | Bemis 1200 Slow Elongated Toilet Seat,...
How to stop seat from wobbling doesnt seem to have screws that fo into seat just a place for seat to sit on and then some cap to put over but nothing seems to tighten it.Im tired of falling off the toilet
First lift the covers off where the bolts should be (they should lift towards the tank). Are the bolts in place? If not, go to your neighborhood hardware store and look for replacement hardware. (Most stores will have staff willing to help you find the right parts.) Is the bowl damaged so that the holes seem large compared to the holes in the seat anchor points? Are the seat anchor points damaged?
The bolts should have nuts (and possibly washers, but not all models use them) underneath the bowl. Screw down the bolt while holding the nut from turning (so you need an adjustable wrench or appropriately sized wrench). Again see the local hardware store for the hardware if you do not have the nuts. Keep the seat centered as you tighten the bolts. (Alternate tightening until it is stable - do not tighten one bolt all the way down before doing the other side. You risk overtightening and cracking the bowl.)
I hope this helps.
(if the seat is damaged, you may want to replace it. If the bowl is damaged you must replace that.)
Jun 10, 2010 | Kohler - Toilet Seat - Moondance -...
Missing bolt for toilet seat
A standard toilet seat bolt should be fine. There are some with a rubber boot that expands as tightened but you should be able to reach the nut by reaching into the tank and under the lip. The new nut & bolt should be plastic so they won't corrode.
Apr 19, 2010 | Eljer Toilet Onepiece Canterbury ...
Middel seatbelt will not loosen
I think you have to remove headrst bfore folding seat back down. You may have to unbolt seat from floor. 4 bolts.
Rear Seat Backrest —Split Bench Removal
NOTE: The 40% rear seat backrest must be removed before the 60% rear seat backrest.
  1. Remove the 40% rear seat backrest.
    1. Remove the nuts and bolts.
    1. Remove the backrest.
  1. Remove the 60% rear seat backrest.
    1. Remove the nut and bolt.
Installation
NOTE: The 60% rear seat backrest must be installed before the 40% rear seat backrest.
  1. NOTE: Do not tighten the nut and bolt at this time.
    Install the 60% rear seat backrest.
    1. Install the rear seat backrest.
    1. Install the nut and bolt.
  1. NOTE: Do not tighten the nuts and bolts at this time.
    Install the 40% rear seat backrest.
    1. Install the nuts and bolts.
60/40% rear seat backrest
  1. Tighten the 60/40% rear seat backrest nuts and bolts in the sequence shown.
40% Rear Seat Backrest
  1. Tighten the 40% rear seat backrest nuts and bolts in the sequence shown.
Jun 11, 2009 | 2005 Ford Escape
Diagram of front end for '94 F150 Ford
this is a 96 f150 suspension, 4x2, not 4x4.
Item Part Number Description 1 N806246-S56 Nut and Washer 2 5A333 Retainer 3 18124 Front Shock Absorber 4 40949 Bolt 5 N62048 Nut 6 N806496 Nut 7 18126 Lower Shock Bracket 8 805033 Bolt 9 3B404 Caster and Camber Adjuster 10 800937 Nut 11 5414 Front Spring Insulator 12 3105 Front Wheel Spindle (RH) 13 3106 Front Wheel Spindle (LH) 14 3050 Front Suspension Lower Arm Ball Joint 15 3B008 Steering Arm and Drag Link 16 800895 Nut 17 642569 Cotter Pin 18 383489 Nut 19 3006 Front Axle 20 388727 Bolt (F-150) 21 389574 Bolt (F-250, F-350) 22 606085 Bolt 23 605920 Bolt 24 3405 Radius Arm 25 34992 Nut 26 5A307 Lower Spring Seat 27 5414 Front Spring Insulator 28 18183 Front Shock Absorber Mounting Bracket 29 34992 Nut 30 5310 Front Coil Spring 31 5B315 Upper Spring Seat 32 18198 Insulator A — Tighten to 34-48 Nm
(25-35 Lb-Ft) B — Tighten to 18-23 Nm
(13-18 Lb-Ft) C — Tighten to 32-58 Nm
(23-42 Lb-Ft) D — Tighten to 60-80 Nm
(44-59 Lb-Ft) E — Tighten to 68-92 Nm
(50-67 Lb-Ft) F — Tighten to 112-152 Nm (83-112 Lb-Ft) G — Tighten to 112-152 Nm (83-112 Lb-Ft) H — Tighten to 340-460 Nm (250-339 Lb-Ft)
Jan 29, 2009 | 1994 Ford F150 Styleside Supercab
Kohler - Toilet Seat - Moondance - K4717-CP-D8 Logo
180 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
