Question about Refrigerators
Hi sir, my whirl pool gets cold in freezer but not ine refrogerator i have checked refrigerant but nothing moves
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 17, 2010
My Maytag refrigerator is not cold at all...any advice?
Check make sure the air flow under the refrogerator is not blocked Frank Walton Tamaqua Pa.
Jan 13, 2018 | Maytag Refrigerators
Water is pooling in the bottom of the freezer. it appears to have a plugged drain
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Amana ABB1921DE Bottom Freezer...
Roper Refrigerator. No ice maker. Freezer on top. Water pooling in refrigerator. keep refrigerator in garage.
heatman101
Jun 20, 2011 | Roper Refrigerators
Water is pooling on the refrigerator floor below my crispers and some is actually forming ice. I've made sure there is nothing blocking ventilation, but it still happens.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Apr 23, 2011 | Microwave Ovens
I purchased whirl pool refrigerator sept2004 for guarnty 7 year scheme but now refrigerator have not done cooling
check to make sure compressor is running may be something simple like the relay on compressor... also make sure there is no frost build up on back wall of freezer as this would be a defrost issue and will frost up enough that it cannot move air across coil to cool....
repost with any questions....good luck to you...
Jan 08, 2011 | Refrigerators
Whirl Pool Refridgerator has defrosted, have pretty much taken appart put back together, still will not get cold? Only other thing I can think of is Frion?
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 07, 2010 | Whirlpool Refrigerators
My whirl Pool side by side is not cooling well, I have washed the coils completely and used the recommended thermostat settings, but I have had thawing in the freezer and in the refrigerator,the freezer...
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
GE Side by side refrigerator not working
THE FREEZER FAN BLOWS COLD AIR TO THE FRIDGE SIDE, TO ACCESS THIS FAN YOU NEED TO EMPTY THE FREEZER SIDE AND REMOVE THE REAR PANEL SOMETIMES A WHIRL OF IT WILL GET IT SPINNING AGAIN BUT YOU MAY AS WELL CHANGE IT
Apr 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
