Question about HP OfficeJet 6210 All-In-One InkJet Printer
No scan options need to install or run device message when i tryin to can never done this before. Help
  • HP Master
  • 7,733 Answers
Ca you try HP Support & Drivers.
Posted on Oct 16, 2010
Tryin to install my webcam no longer have the software cd and do not know which driver to use
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Aug 22, 2010 | Maxdata Prolynkz World PWC-010 Webcam
Scan document to text
In order to scan to text or pdf, we need to install OCR.
Please follow the below steps to install OCR.
Please open the link and click on download only.
Once we click on download only, we will get an option to save.
Please save it on the desktop and then run.
.You will get an eror message that says "This update does not support any of the HP device drivers that you have on your PC. You do not need this software update
Please do not close that window.
Now, please open the temp folder by performing the steps given below.
: Press and hold the windows icon button ( between the ctrl and alt buttons on the keyboard ) and then press the R button.
: Run window opens up.
Type %temp% in the box and press enter.
I would request you to perform the steps to open the run window and type %temp% in the box and press enter.
The temp folder opens up, once that is done.
Please open all the 7z folders and locate the OCR_webpack folder
: Plaese copy the same folder ocr_web_pack and paste it on the desktop.
Close all the windows.
Please click on OK or cancel the error message.
Now, open the OCR_web_pack folder that you have pasted on the desktop.
Double click on the .exe file found in the OCR_web_pack folder.
This should start installting the OCR software in the computer.
You will get the options, Help (folder), Licensing(folder), Setup(folder), Autorun, hpqbpl1.dat, hpzsetup, setup.
: Open the setup folder.
: You would find the OCR setup.exe file, or set up foler or set up file, double click on the same to start installing the same.
Once the installation is complete, we will be able to scan to text.
May 10, 2010 | Office Equipment & Supplies
When I try to scan with my 2710, I get a message select computer, then you need to run or install hp software for this feature. What do I do?
If this is from the front panel of the printer, the device is not recognizing that the front panel destination list is set up that can be done from the device software
if you are trying to scan from the pc and getting the message this is a communication issue and the easiest solution is to actually uninstall the software and re install
Mar 27, 2010 | HP Photosmart 2710 All-In-One InkJet...
My Officejet Pro 8500 won't scan, says "no scan options"
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Hope this helps. Please rate my response.
Have a good day.
Mar 23, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Refer to device documentation to trouble shoot
you need to set up your scan to option.
this can be done from the hp software
open solution center click settings then scan settings
from there select scan to set up
a window will open and then click on front panel destination list
once again a window will open with a double pane on the left side is your short cut options click on them one at a time click add then once satisfied with options click update the device or ok
if it fails to update reset the printer and try those steps again, or re install just the drivers
if the same message appears then check the settings on your firewall
Mar 22, 2010 | HP Officejet 6310 All-In-One InkJet...
Having a problem with the scan function on my HPC7280
Not too sure on this model, but if there was no options, perhaps the machine has not been set up correctly to scan to a folder or application.
This FAQ/Guide from HP shows you what you need to do to correct set up your printer to make scans.
Dec 11, 2009 | HP Photosmart C7280 Printer
I keep getting the message 'no audio output device'
1. Right click on Mycomputer, select properties
2. Select hardware
3. Select Device manager
4. double click on the sound,volume and controller
5. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
6. then select Action from the menu bar on the top and select scan for hardware changes
**** after doing this.. you can check the follwoing steps for trouble free ******
7. double click system device
8. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
9. then select Action from the menu bar on the top and select scan for hardware changes
10. then it will start scanning your new hardware and ask for the installation drivers.
Jun 28, 2009 | Toshiba Satellite U305-S2812 Notebook
"No Scan Options" Error
Remouve all , restart from scratch, get a fresh driver from HP and reinstall. Happened to me to
Feb 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Scanner problem again -- HELP! junk 'solution' given
try to install and run scan diagnostic utility found here
Jun 20, 2008 | HP Officejet 6310 All-In-One InkJet...
No Scan Options Error Message
Pressing of scan button feature is no longer supported by hp drivers, if installed correctly one scans using scanners and fax
When the scan button is pressed on the printer, nothing happens. The scan button does not work correctly. Solution Scan documents using Windows Fax and Scanning or Paint. Scanning with Windows Fax and Scanning
  1. Click the Start (c00845897.gif ) icon.
  2. Click All Programs .
  3. Click Windows Fax and Scanning .
  4. Click New Scan .
  5. Click File and then click Scan .
Scanning with Paint
  1. Click Windows .
  3. Click Accessories .
  4. Click Paint .
  5. Click File and then click From Scanner or Camera .
  6. Click Scan .
Cause The drivers in the Windows Vista operating system do not support button press functionality on the printer. link to above info from HP
Dec 11, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
Ben Johnson
