Question about Toys
Have Peg-Perego Buck IGOR 0010 that the dog chewed through the undercarriage wire harness and wires. Soldered same gauge wire to like colored wires (red to red, w-w, blk-blk, blue-blue). Cut wires register voltage when accelerator is pressed, but soldered wires do not. Removed connections and voltage is present again. What am I doing wrong?
  • 156 Answers
SOURCE: wiring specs for peg perego polaris 700
I would contact the repair help at
http://www.shopjandl.com/
They seem to know a lot about these toys
Posted on Jun 23, 2009
jyackle5
  • 8197 Answers
SOURCE: i just bought a li po battery but i have to change
Some company's switch the yel and wht or the red and orange wires so they know it is there product. Just wire it the same as you have now. yel is the wht and red is the orange or reverse.
Posted on Nov 27, 2009
SOURCE: WIRING INSTRUCTIONS for MTH gas station A
A) on the gas station gets one wire from the transformer and one to the activation botton off A on gas station ( acc power from transformer )
B) gets ground from the transformer
C ) to activation botton
D ) to Acc power on transformer
E ) ground on transformer
Posted on Dec 27, 2009
mcdevito75
  • 1970 Answers
SOURCE: I HAVE A 12 PIN CONSOLE WIRING HARNESS UNDER DASH
mcdevito75 here, I would simply compare the pins on the new dash with the old dash. Or compare the new wireing harness with the old, compare the wires at the connector itself, compare both connectors the new harness and old.
Posted on Jul 16, 2010
  • 286 Answers
SOURCE: we have purchased a used
hi this is for the newer version but all is the same as the older style
http://global.pegperego.com/babyproducts-catalog/2010/Young
Posted on Oct 28, 2010
Peg perego gator will not run with new battery and wiring harness. Can you hot wire the motors to see if they run?
Yes, I would connect the battery to each motor and see if they work. You can call the repair desk at 1.801.655.0800 and they can help you. I had problems with my other peg perego and they walked me through it
May 06, 2017 | Peg Perego Toys
Wires under hood chewed by rats
Don't know what you need
Open up the wire harness enough to be able to make a repair
You slide heat shrink tubing over the wire,add wire, any color
but the same wire size or gauge & solder them & then heat shrink
If only the plastic is chewed & no copper wire ,then seal with clear
nail polish & tape real tight with 3M hi temp electrical tape,home
depot has that
Then use the stretchy rubber tape to cover all repaired wires,
unless you like you heat shrink job.
You just match the wire colors & strips that isn't the question
Have the battery disconnected
Sep 14, 2012 | 2003 Buick Century
How to know what wire is positive and what is negative on wiring harness for peg perego John Deere gator
typically white is positive and black is negative, but check the wires with a multimeter and if it shows a positive value then your positive lead of your multimeter is connected to the positive, if the value is negative then your positive lead is connected to the negative
Apr 28, 2012 | Peg Perego John Deere Gator HPX Ride on...
The power cord on mygator has burned up near the connector cord. Can I replace just the power cord end terminal and how.
when our dog chewed on our peg perego charger we tried to fix it, but ended up just getting a new one. I found it at
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-chargers.html
You can also call them at 1.801.655.0800, maybe they will have additional help
Nov 04, 2010 | Peg Perego John Deere Gator HPX Ride on...
Hello, Im trying to rewiremy transmission on a 92 GMC 3500 vandura box van. My don chewed the wiring that plugs into the transmission The plug has 11 wires coming out of it but some of them that he didnt...
Hello tnvolsfan32,
Use the FREE drawing available on the
BBB Industries site to trace out your wiring...
BBB Industries Premium Alternators Starters Power Steering Products
First put the wires together that
DO PERFECTLY MATCH... Then go
back to the drawing and find out what
DEVICE, CONNECTOR or PLUG got
disconnected or swallowed.
Generally wires DON'T CHANGE COLORS
in a wiring harness run... So you definitely
need to look for a LOGICAL EXPLANATION.
Registration is required... these are real
wiring documents...
Each time you return from a WIRING page
make sure you have not
defaulted back into TSBs...
(technical service bulletins)... While usually
quite useful... they don't begin to address any
WIRE-EATING-DOG problems...
If you get confused comment me back...
I can recommend some great tools to help
SPLICE everything back together
Tone Tracer being PRIMARY
Extech TG20 Wire Tracer and Tone Generator Amazon com
Helpful hint: wire must be ISOLATED to trace correctly
(pulled fuse or chewed through works).
Hope this helps
Carnac the Magnificent
Sep 23, 2017 | GMC Cars & Trucks
John Deere Gator not responding with new battery.
I upgraded my Peg Perego shifter and it came with the wiring harness.
I bought it at http://www.shopjandl.com/
Hope this helps.
Jun 20, 2009 | Peg Perego John Deere Gator HPX Ride on...
No spark
If the dog chewed up the coil wire you will need a new coil. How did the dog GET to the wiring? Did you let the dog live? The wires are color coded. Splice the wires color to color. Depending on how badly the dog tore up the wires, you may want to get a new, (or used) wiring harness and re-wire the bike following the pattern of the existing wiring.
Please rate this solution as "FixYa" if it has answered your question.
Mar 25, 2009 | 2004 Kanuni Tigrina 100
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
