Question about LG Studioworks 700S 17" CRT Monitor
Lg 700e monitor's screen is flickering and the video size is reducing to 1/4
  • 16 Answers
SOURCE: for lg monitor warranty
this monitor having 3 yr warranty
according to the serial no it have warranty till April 2008.
Posted on Feb 06, 2008
ginko
  • 19396 Answers
SOURCE: LG 700E monitor's power LED blinking continueously, no display
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 22, 2009
I had a similar post about an LG 505G. Just bought a new LCD monitor and decided to open the monitor before putting it on permanent storage. I noticed a bloated capacitor in the control board just adjacent to the low voltage power supply. It was a 1,000 mFd 10V cap. So what the heck I desoldered it and replaced it with a spare 50V capacitor of the same rating I had lying around. I assembled the unit plugged it in and VOILA!!! the monitor was working again. Hope this helps.
Posted on May 09, 2009
pgmadhav
  • 145 Answers
SOURCE: blinking of moniter 700e lg
I think that two capacitors in the powers supply circuitry(incise the monitor) has gone bad. Just open and you'll see them.
This should solve your problem.Best of Luck.Please rank me appropriately. If you want any clarification, Please get back to me
Posted on Jul 27, 2009
  • 95 Answers
SOURCE: Green light flickering & Sunset red screen display.
You've got components that have gone bad, probably from age and the normal heat inside a CRT monitor case.
I hate to say it, but it's really not worth fixing. You can usually find a used but working 17" monitor for under 20 bucks.
Posted on Sep 27, 2009
LG 700e crt monitor is showing all in rainbows!!!!
Remove any speakers or magnets that you might have near the monitor as they can cause visual distortion on your monitor screen.
Mar 05, 2014 | LG Studioworks 700S 17" CRT Monitor
Video shrink to half the size of montor
you can solved your problem by your self but i am not sure it will work 100%.,1st UNPLUG power cable for safety! just open your monitor back cover via crew driver., now you should see some adjustable plastic scree on board plug your monitor with power and witch pc. now try to adjust plastic crew one by one. you will find the screen re-sizer crew. hope it will work. if this is now work then you should visit a good local engineer.
Dec 11, 2013 | Computers & Internet
Lg 700e monitor settings
the correct settings for LG 700E CRT Monitor. Sometimes, the settings ofthe monitor change automatically. Also, even after resetting the monitorsettings, sometimes, they remain same. So, I'll tell you the correct settingsfor LG 700E CRT monitor. Let's move to the main part.
So, Check the following settings.
ForBrightness and Contrast:
http://is.gd/dMBn9
For Position:
http://is.gd/dMBub
For Size:
http://is.gd/dMBBU
For Shape:
http://is.gd/dMBDC
http://is.gd/dMBGe
Oct 20, 2012 | Computers & Internet
Sep 27, 2009 | LG Studioworks 700S 17" CRT Monitor
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
LG 700E MONITER britghtness and flicker
trace abl from fbt to video preamp ic.
replace ic if nothing found bad.
Sep 23, 2008 | LG Studioworks 700S 17" CRT Monitor
LG 17" MONITOR MODEL 700E (COLOUR & SHAPE PROBLEM)
THE PRESCRIBED ARROWS ARE FUNCTIONING WELL FOR INCREASING THE VERTICAL SIGE OF THE DISPLAY OF THE MONITOR.BUT THE HORIZONTAL AROWS WHEN OPERATED ARE NOT ABLE TO INCREASE THE HORIZONTAL DISPLAY OF THE MONITOR TO FULL SIGE. PLEASE GIVE APPROPRIATE SOLUTION.
THANKS
Aug 14, 2008 | LG Studioworks 700S 17" CRT Monitor
LG Studioworks 700S 17" CRT Monitor Logo
167 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
