Question about Samsung TL 105 Digital Camera
The lens of my samsung is stuck wont go back in. if i press the power button, it turns on for a couple second s then turns off. but it doesnt take pictures. what do i do?
  • Samsung Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Oct 16, 2010
I have a Canon PowerShot A430 camera. When I turn it on, the lens doesn't open and it shuts off. The message on the screen says " Lens error, restart camera." Please advise. Thanks
The Lens Error is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
You can reset the Camera back to factory default by performing the following steps:
Press the power button.
Press and hold the MENU button for more than 5 seconds. Default Settings will get displayed.
Use the arrow buttons to select OK and press the FUNC./SET button. This will reset all the settings back to factory deafult.
This should resolve the issue. If the issue persists, service may be required.
Thanks for contacting FixYa
Aug 10, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
Lens stuck open
hey, I had the same problem when I accidentally droped my camera, some parts in the mechanism are probably broken or jammed.
Most likely repairs required.
Apr 13, 2008 | Samsung Digimax S600 Digital Camera
My camera wont turn on. i press the power button, but it only blinks and doesnt turn on. why?
Having received no response in over a month, I assume this is no longer a problem.
May 27, 2010 | Sanyo Cameras
Samsung pl50 camera - lense wont go back in and wont turn on
The problem with mine was that the lens motor was somehow stuck. I gently pulled the lens out as I turned the camera on. It went back to normal afterward. Hope this helps
Feb 01, 2010 | Samsung PL 70 SL720 Digital Camera
My samsung L830 camera has jammed with the lens open and
Just had this happen to my L100. First, take out the battery and wait a couple hours for everything to cool down and discharge. Then place the battery back in. Then plug the USB cord into the camera and PC. Then turn the camera on and it should be okay. Just worked for mine.
Jul 15, 2009 | Samsung Digimax L830 Digital Camera
My samsung l830 camera lens is stuck open and when i press the power button it beeps 3 times and remains blue then does nothing
If the lens on the camera is stuck out, look to see if it's a little crooked. If it is, try to gently straighten it. If it still won't retract, try to gently push it in as you turn the power on.
If it won't turn on (the green light blinks and it beeps 3 times) push and hold the 'power' button and the 'play' button at the same time for a few seconds - it worked for my S730. Good luck!
Jun 28, 2009 | Samsung Digimax L830 Digital Camera
Lens stuck after dropping camera
Probably it can be fixed, but if the lens gears are too damaged the repair could be much expensive and you would prefer to buy a new one.
Take your camera to a qualified technician to check the price of a repair.
May 23, 2009 | Samsung Digimax S730 Digital Camera
The Lens Stuck in extended position on my kodak easyshare v-550
Hi there, welcome to FixYa.
L-83 is a type of lens error. There are a few different types of errors with causes ranging from a broken gears (they're plastic), to sand or dirt getting in the gears preventing them from turning. So, here are a couple things you can do to fix this yourself before turning it in to shop for repair.
1) Get an air compressor and put the nozzle up to the space between the lens and the body of the camera and blow it out real good. Then turn the camera over (lens down) and tap the lens on a hard surface. You may have to do this a couple of times.
2) Press the power button on the camera, and while it's flashing it's lights, bang the side of the camera on the palm of your hand a couple of times. That may free the gear up.
If it's not something blocking the gears from turning, then it could be that the guide pins on the lens may be out of their tracks. If this happens, then the lens will not move at all.
Press the power button and grab the lens, give it a tug and a twist. Don't be afraid of it, you want to manuever those pins back into their tracks. You should hear a click when they fall back into place. If you hear the click, then stop pulling on it. Power it off and back on to see if the lens retracts.
If these three suggestions won't work for you, then you should turn it in for repair. Perhaps the teeth on the gears are getting stripped off, and it's pieces of the gear themselves that's getting trapped in the other gears.
Hope this helps you. Thanks for coming to FixYa.
Rob
Mar 14, 2009 | Cameras
Camera lens stuck out and wont turn on
I purchased my Canon SD 1000 a couple months ago and as soon as I owned it one month I had lens problems. Stuck shut stuck open and now its still stuck open. I take care of my camera and carry it in a case all the time. This is my second rodeo and there wont be a 3rd,
CANON IS DONE GETTING MY MONEY
Jan 20, 2008 | Nikon COOLPIX L2 Digital Camera
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
Samsung TL 105 Digital Camera Logo
225 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
