Question about Sony Handycam DCR-TRV840 Digital Camcorder
My sony cam will not relese the tape inside, pushed out but will not open, camera is froze in this positition. What should i do?
  • 321 Answers
Thats your mechanism alignement or a sensor the servo control chip do not see the position of the mechanism or the tape is stock inside some where , due to a faulty capstan belt,its difficult to tell
where is the prolblem exactly i didnt have in hand,anyway its common to what i explained
you will need a tech to do so..iys not a big job for a good technician
hope that will help...
regards Alan
Posted on Oct 17, 2010
Error message "push the reset switch"
Pull the battery out to reset it. Get a DV tape cleaner to clean out the tape deck.
That should solve both.
Aug 20, 2008 | Panasonic PV-GS300 Mini DV Digital...
Sony handycam will not open tape tray
The spring inside may not be sensitive. Try not to break open as you do not want to break teh mechanical arm and try to push the tray gently in the "spring". The tape will come out eventually
Mar 22, 2011 | Sony Handycam DCR-HC48 Mini DV Digital...
I accidentally inserted a tape in backwards and/or upside down, and it appears to be stuck in there. I can't get the metal casing that encloses the tape to raise up and open. When i push the 'open/eject'...
You should open the tape holder meatal ther may be 4 screw! take it off! and release your tape! don't do it again with the power on it might get damage inside! enjoy man n try it!
Oct 29, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
I have a Sony Handy CAM 8 CCD-FX310. It will eject, but when you place a cassette in the slot and gently push it closed, the top will not retract down. it makes a slight spinning noise and then ejects...
I had the same problem with a Sony FX410, not much different than a FX310. With my camera all i had to do was to push the top down with a gentle push, it would engage and play and record normal. Don't force it hard, just a light pressure to help the cradle down. Most of these Sony cameras are crappy when it comes to loading the tape, most if not all the Sony's i've had end up with this problem, no matter what model you have. I've taken my camera competely apart and could not find the problem for not pulling down the tape, don't know if it can be a sensor or what, i never could find anything broken or loose or misalign, i oiled all the joints and moving parts with a light dab of thin oil, it worked fine except for that darn cradle not pulling down the tape.
Another thing that causes this is when the tape is to tight? In other words the tape should have a slight **** in it, i once ran into this big problem when the tape would not load and the camera kept ejecting it over and over. It was when i tried a new tape that i noticed how well it loaded yet the other tape wouldn't load. So i pulled out the tape and poked that little hole on the back right below the left hand pick up reel, i then turned the reel with my finger and gave it some slack, not much just enough to see the tape a little loose. I then reloaded the tape and it worked like a charm, seems that if the tape if to tight the camera won't accept it as the reels need to adjust back and forth for a few seconds, its that wacky sound you hear when you load a tape, seems like it has to adjust the tention inside the take up reels. Hope this might help you some?
Oct 08, 2010 | Sony Video Cameras
Hi there I am getting code c31-23 can you please
This is one of the most common problems on sony camcorders. It is caused by the loosening or loss of the rubber roller inside the tape drive mechanism. Try tapping the top of the cam when the tape is inside. If this doesnt work, open the tape deck and look inside to see if you can spot a single rubber roller inside. If not, then the roller has worked itself loose or gone AWOL missing..:(( However, fear not...the solution for this is to go to an office supply store and obtain one of those compressed air cans used for dusting off keyboards and such. Amazingly, the plastic tip on the compressed air can (where the air comes out) can be used as a replacement for this rubber roller. It fits the metal spindle that formerly held the roller perfectly and allows the cam to function without the rubber roller and without the dreaded C31:23 "your camera is dead and useless and will no longer function" evil Sony message... Check out this link for a discussion of this problem: http://wvstephens.blogspot.com/2008/05/sony-handycam-c3123-3123-error-easy-fix.html
Jul 28, 2010 | Sony Handycam DCR-TRV140E Digital...
The tape carrage wont load the tapes but it will go into the load position without.
I have a sony cam myself. If the cam is empty, you open the outer door(swings out), and the load/unload mechanism rises up and pops open allowing tape insertion. When a cassette is placed into the mechanism, you press where it says "push" and then the drive pulls the tape down and into the unit. Then the outer door is closed and you're ready to tape. IF YOU PUSH DOWN ON THE TAPE WHILE IT'S BEING PULLED INTO THE UNIT IT WILL STRIP GEARS INSIDE. The gears are made of nylon to prevent serious damage to motors and other circuitry. This transport setup cannot be forced at all. If any type of mis-alignment occurs, the mechanism is supposed to stop and back up--allowing the problem to be corrected. If it is damaged, the cam must be repaired. There is critical timing involved in replacing the tape carriage.---Rick
Sep 10, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
Error C:31:23 on Sony trv27
Jun 12, 2009 | Sony Handycam DCR-TRV27 Mini DV Digital...
I cant put a tape in!
when mechanism pops out to eject, wait until it completly comes out, deattache battery immediately, and Pull lever as per below mentioned picture. Cassette door will be open and place cassette. Close it and attache the battery. Camera is ready to Record or Playback.
Feb 25, 2008 | Sony Handycam DCR-TRV18E Mini DV Digital...
Sony Handycam DCR-TRV840 Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
