Question about Audiovox AVP7000 VCR
How is the tv and vcp removed from a 99 Dodge conversion van? They both seem to work with the exception of the dew feature on the vcp keeping me from finding out if a tape will indeed play. Thanks!
  • 1hitwunder Oct 16, 2010
    I am looking for a solution to getting my vcp and tv to play and I cannot find out if the vcp is even attached to the tv in the normal way from behind because they are in two separate slots. I unscrewed the wood frame around the vcp but the player doesnt just slide in and out of the slot so I need to know what has to be removed around that area to get to the backs of these items for more research. My first so called expert answer was only to check for loose screws and I sure hope that isnt all for 6 bucks because obviously, that is just about um, duh quotient.
    Thanks!
  • 712 Answers
Check for any screws to be loosened that attach them together.
Posted on Oct 16, 2010
How to remove tv from explorer conversion van?
That is one problem with an after market conversion. If you know who did the conversion, you can contact them. If not look for screws that are present on the base of the set. Be advised that the aftermarket install might use non conventional methods of using fasteners.
Feb 12, 2013 | Cars & Trucks
How to change top radiator hose on 1997 dodge conversion van with a 5.2 motor
theirn will be a clamp on the radiator side at the top of the radiator remove this clamp follow the rad hose back to the engine side and you'll see another clamp remove this clamp also twist hose from both the radiator and engine side and pull as twisting this will remove the hose then repeat process for installation make sure engine is cold while changing after reinstallation add proper coolant start engine add more coolant as needed
Sep 01, 2012 | Dodge Ram 2500 Cars & Trucks
I have 2 handicapp vans with TV's. I need to upgrade them to digital I suppose since neither works now. Where do I get the device for mobile conversion and operation?
If you continue to operate the same TVs...you will need to purchase a conversion box. This conversion box will except digital signals to analog and provide an outstanding picture to your already installed TVs. You may have to search for a battery type device for the van you have. But I'm sure you will seek and find. Check at a reputable electronic store....the discounts stores more than likely will not have these! Good Luck!
Jan 24, 2010 | Televison & Video
Not able to remove shroud cover for fan blade on 1994 dodge van
Remove a/c compressor and flop it out of your way.
Nov 27, 2009 | 1993 Dodge Ram 250
1500 Conversion Van AC stays on, van overheats. Pulled the AC clutch fan relay and it fixed the overheating thus far, but really need the AC this time of the year. Please help.
ONE SUGGESTION COULD BE TO SWAP THE RELAY FOR ANOTHER TO SEE IF THIS FIXES THE PROBLEM. IF IT DOESN'T, THEN PERHAPS THE COMPRESSOR CLUTCH IS STUCK IN THE CLOSED POSITION. UNPLUG THE CLUTCH TO SEE IF THE COMPRESSOR STOPS. HOPE THIS HELPS. PLEASE KEEP ME POSTED. THANKS FOR USING FIX-YA AND FOR AN HONEST RATING. GOOD LUCK
May 26, 2009 | 1999 Dodge Ram
Get error 99 message
err 99 is moisture or dew inside the camera.
May 07, 2009 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
Putting serpetine belt on my dodge ram conversion van
Should be a diagram on radiator core support,which is where the radiator bolts to, should be a diagram tag or when you open hood it may be on inside of hood look up when you open hood if its not on core support,should be on inside of hood.It will show exactly how the belt goes on
Apr 08, 2009 | 1998 Dodge Ram
Owner's manual
Try Walter Miller auto literature it is an ebay store he has many owners manuals. You may find that all that is available is a owners manual for the 2003 Dodge Ram and that the conversion info is only items installed on that van. This is how alot of RV-Conversion Van are.
Mar 31, 2009 | 2004 Dodge Ram 1500
318 Dodge Van, knocking sound when idling?
It will be an engine out of the vehicle major repair.
Aug 05, 2017 | 1983 Dodge Pickup
Audiovox AVP7000 VCR Logo
150 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
