The DVD player makes a squeaking noise and then says no disk? There is a disk, and also I plug I'm my xbox using the hdmi cable and it just goes on blue screen saying no support in the little box?
Ajkill
  • 2035 Answers
SOURCE: hdmi switcher
First check individually if they work ,then connect to HDMI switch ,then change the position of the switch if it is a manual switch or connect the cable to the dish and check the dvd works...............
Posted on May 29, 2008
SOURCE: portable dvd doesnt play movies
Try cleaning the lasers lens with an anti static cleaning wipe. I used " nice'n clean" that I had purchased from Walmart to clean my laptop screen. My dvd player started back playing after gently wiping the laser lens.
Posted on Apr 21, 2007
SOURCE: blue screen with HDMI
Check the power supply modular cable connection that is by itself in the upper right corner.  On the one my son-in-law has the double yellow jumper wire that connects to this plug in two locations was loose (not properly inserted) in the modular connector and had worked it way out.
Posted on Oct 26, 2007
  • 1153 Answers
SOURCE: No High-Def via monolink(HDMI) connection
Troubleshoot first by self diagnosis
Posted on Dec 16, 2007
SOURCE: HDMI input
The green screen is caused by light hitting the back of the tv. Either move the tv to a location where direct sunlight will not hit it or put up strong curtains. As for fixing the problem, do a search for JVC green screen reset on AVS Forum, its easy to do just dont have the info with me now. Keep in mind if direct sunlight hits the back of the tv it will do it again. I have put up some good curtians and ensure not to open them when watching the tv. Hope this helps. I am Hayward, have a nice day.
Posted on Feb 20, 2008
No power when plugged in in any socket.
Solving HDMI Problems - HOW TO GUIDES
www.hdtvsupply.com > HOW TO GUIDES
Rating: 4.7 - ‎2,086 votes
The hdmi cables carries a low DC voltage while connected. ... If so, reset it to match the native resolution of your TV or video projector (such as 720p or .... Source Device:Any Blu-ray Player, DVD Player, Gaming Console (PS3, Xbox 360), ... Power cycle:Power off / Power on equipment (At the wall socket since some LCD's ...
HDCP / HDMI Handshake Troubleshooting and Guidelines
site.hdtvsupply.com/hdcp1.html
The hdmi cables carries a low DC voltage while connected. ... Source Device = Any Blu-ray Player, DVD Player, Gaming Console (PS3, Xbox 360), Apple ... Power cycle = Power off / Power on equipment (At the wall socket since some LCD's ...
Amazon.com: Customer Reviews: Belkin Conserve Socket ...
www.amazon.com/Belkin...Socket.../B003P2UMQ2
Amazon.com, Inc.I wanted to completely turn off my subwoofer amp, blu-ray player, PS3 and .... but my Mac uses next to no power and my PC normally gets shut down after use). ... I hereby give up any and all hopes regarding Belkin support. ... I plugged her television in to the main outlet and her Wii and dvd player into two of the other ones.
[PDF]Blu-ray Disc™ / DVD Player - Manuals, Specs & Warranty
https://docs.sony.com/release/bdps3100_bx310.pdf
Sony Corporationin this Blu-ray Disc/DVD player is harmful to eyes, do not ... be unplugged from the wall socket immediately in the event ... operating in conjunction with any other antenna or ... However, there is no ... as power-supply cord or plug is damaged,.
Jan 26, 2016 | Televison & Video
Trouble connecting my insignia 32in.Tv To my DVD player
Yes you can use Just the red,white and yellow cable from your dvd player to the tv....now make sure you have it connected correctly...sometimes its easy to confused the yellow and white connections. make sure your tv is turned to Input that you have used for connecting the cables on the back....such as...input 1...select input 1 on your tv....or if it says dvd...then select dvdv on yoru tv..You can use a HDMI cable...just plug HDMI from your dvd player to your tv and select HDMI on yoru tv..Good luck
Mar 08, 2015 | Insignia IS-LCDTV32 32 in. Television
Cannot get surround sound to work with Philips hts3106/f7 andonic tcp50g25. It works fine for Blue ray via the hdmi out of philips dvd/receiver, but not for xbox or cable etc (only works in stereo).
i have the same system. all you have to do is when you connect your xbox 360, press the surround button on the remote and then use the arrow buttons to change it to dolby music pro2 or multi channel audio. same goes with any device you connect. hope it helps. In my case the xbox is connected to the Tv via HDMI and bluray player is connected to xbox via compoent cable
Nov 26, 2011 | Philips Audio Players & Recorders
Samsung ps wx30 surround sound system. speakers are plugged in to dvd player. dvd player is connected to tv via hdmi cable. speakers only work when using dvd player and not tv/sky etc.. am i missing some...
Hi,here is my simple solution...
To listen your TV on your
samsung ps wx30 surround sound system ,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out " of your TV unit
** to "AUX input " or "TV" OR "Any input" of your
dvd player or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
dvd player corresponding your RCA or Optic connection or HDMI ..
There you go..Your TV sound is on the
dvd player By this means whatever you watch on the
TV (
tuner, satellite , Xbox , etc..) ,it's sound will come thru your
dvd player.
Hope this helps!..if more he?p requires pls let me know..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Audio Players & Recorders
Trying to hook a dvd player up how do i do that
There are three ways subject to what your DVD player and receiver can support.
1. Connect the stereo output of the player using a pair of analogue interconnects. The outputs are usually color coded red and white (for left and right). Simply plug in the interconnect and connect the other ends to a matching pair of inputs on the Receiver. Then make sure you select the correct input on the Receiver for the sound to come through.
2. The second method is to take advantage of surround sound audio (Dolby 5.1 for example) on the DVD. You will of course need a surround sound speaker system connected to your Receiver to take advantage of this. You'll need 'either' an Optical or Coaxial cable. These are both single cables that carry the digital audio form the player to the Receiver. Check your manual to see which ones your equipment has. Alternatively look on the back of the DVD player, the digital output is usually marked quite clearly. Obtain a suitable cable, and plug into the DVD player and the other end into the Receiver. Again make sure select the correct input on the Receiver. You 'may' need to go in to the menu settings of the DVD player in order to tell it to output the digital signal.
3. HDMI - If you DVD player, Receiver AND TV all have HDMI connections then this is by far the easiest. You'll need 2 HDMI cables. The first one goes from the DVD player into the Receiver, the second goes from the Receiver to the TV. Again make sure you select the correct HDMI input on the Receiver and the correct HDMI input on the TV and that should get you going!
Hope this helps?
Jun 13, 2011 | Audio Players & Recorders
Xbox and dish network problem
if you have like a dvd player then try hooking the xbox up to it in the front where the video is for the 3 plugs then try to plug dish network in the back of the dvd where the ant in plug is at then take the cord from the dvd player and plug it in the back of the tv if this dont work let me know
Aug 08, 2009 | Microsoft Xbox 360 Console
Xbox 360 dashboard will not show using Yamaha RX-V663
I had this issue once before, recheck all the conenctions on the tv, and make sure that the HDMI plug in for the TV * if its the older model * make sure it is placed to HDMI not TV.
Please let me know how it goes,
Thanks
Justin
Please rate me
Jan 07, 2009 | Yamaha RX-V663 Receiver
UPCONVERT DVD PLAYER HDMI PROBLEM
I have the same issue with this player hooked up to a Samsung 58 inch 1080p plasma.
Jun 06, 2008 | Televison & Video
HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 http://www.newegg.com/Product/Product.aspx?Item=N82E16812168003&Tpk=HS-41A0) to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Feb 04, 2008 | Audio Players & Recorders
Televison & Video Logo
264 people viewed this question
Top Televison & Video Experts
Electro Med Services...
