Question about Fuji FinePix S7000 Digital Camera
Clicking noise when i turn on my camera it makes a sort of clicking noise which is constant while the camera is turned on.Do you think this is a fault and if so how much would it cost to put right?
Hi,I also experience this but it isn't a fault it is just the auto aperture!You will notice that as you move the camera around the noise kicks in as the light changes.
Posted on Jun 07, 2008
Why is my camera making a clicking noise when I film?
If you're taking stills it is most likely the shutter sound. If you're hearing a steady click when shooting video it might be some sort of timing click to let you know how long you've been recording (i.e. one click per second). Either way, you should be able to turn it off in the camera's settings menu.
Dec 04, 2014 | Cameras
My bathroom Broan exhast w/light makes a constant clicking / tick tock sort of noise when the fan is not running. as soon as I turn the fan on the noise stops and then stops after I turn the fan off, only...
remove the cover and clean anything in the vent , check the fan for anything that could be touching it, as the back draft comes through the vent, something could just be touching the fan blade as this draft makes the blade turn slowly, which would create a ticking noise
Jul 10, 2011 | Broan-NuTone (8663RP) Ceiling Fan
Tamron lens makes a clicking noise
It is dealing with the films. when closing the lens in the fabric, the electrical film changed its position to an unwanted situation. This makes noise sometimes. It is not important for functinality of the lens. But it only gives you an unwanted noise. There is nothing to do because film dries as the times passes. It needs to be changed but is not cheap. So it is better to go on to use it.
May 28, 2010 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
SPEEDLITE 580EX TTL Flash: flash is making a constant beating/clicking noise ...
Loosen the two small screws under the flash on the swivel head. Turn flash on. You may need to twist the head just slightly. Flash bulb moves back and forth in the swivel head when zooming. If you dropped the flash, this may have jarred it from the track. I had the same problem with mine, and the above solution fixed it. Zoom works again and no clicking noise. Let me know.
May 18, 2010 | Canon SPEEDLITE 580EX TTL Flash
It is making a constant strange noise when it is turned on. does it mean it is broken?
Not necessarily.
This camera has an auto lens. Which means it will focus automatically every second, which makes this clicking sound. You can turn this option off:
1: Go into the menu
2: Chose option Cam Settings
3: Switch AUTO focus to single lens and click OK.
Jan 26, 2010 | Kodak EASYSHARE M763 Digital Camera
Clicking noise when i turn left
Sounds like constant velocity joints at the end of the drive shaft, the joints at the end of the drive shaft that allow the wheel to swivel, to turn. Only makes noise when turning left or right and is usually only from one side.
Hope this is of help. jccampbell@eircom.net
Jun 18, 2009 | 2006 Nissan Altima
It has a lens error. Everytime the camera is turned on it beeps and clicks constantly. It eventually shuts off after displaying "Lens error, restart camera." on the screen.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 23, 2009 | Canon PowerShot SD1100 IS Digital Camera
Clicking noise when camera is on
I know this question is almost a year old, but thought I'd post a solution for those using Google Search to try and solve this problem. In the "menu" simply scroll to the "AF Control (Video)" option and change "Continuous AF" to "Single AF" and that should solve this issue.
Dec 26, 2008 | Kodak V803 Digital Camera
Noise inside camera
what sort of noise and is it constant?
Jun 10, 2007 | Canon PowerShot G2 Digital Camera
Ariston frontloader - dial spinning around and won't start a cycle
Your bearings are almost certainly gone which would explain the noise not an easy job or cheap . Normally it would consist of a tub change or at best a bearing hub . As for the clicking round of the selector Iwould suggest poss the heater or brush fault. As ofr price you'd have to ask your local repair man. Worst case sinario approx £200 .00
May 30, 2007 | Ariston Technologies AWD120 13 lb. Washer...
Fuji FinePix S7000 Digital Camera Logo
104 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
