Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture. Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set. Please let me know what you will find to assist you further.
I am pleased you found my flash light test useful. You have a ballast or back light problem. Probably just the ballast unit, so well worth repairing as the expensive bit is OK. Check the ballast unit before seeking lamps.
If Fan is running when you turn TV on and keeps running then its OK ,Ballast Board is what turns Lamp on, Is Lamp Lighting at all?
Encompass Parts Distribution has Ballast board for $62.00
Be sure to give the whole model # to TV Ending in WXXaa
WAX/XAA or WX/Xaa HLR6167wxxaa or wax/xaa or wx/xaa
1-800-638-3328 You can also go to their website and type in your model # for List of Parts and Free Service Manual.
Check the Lamp Fan if it is defective Lamp will try to light but will shut off, And the Ballast board is what turns Lamp on, For Part number o to Encompass parts distrubtion and type in your model they should list the ballast board and PN Then go to Ebay Look under Electronics type in PN, I got mine for $65.00
Lamp for $85.00
Lamp Fan is defective or its your Ballast Board part# 1-468-798 ,If Lamp Fan is OK it will be the Ballast. Look for one on E-Bay under Electronics /Parts
If Fans are OK and color wheel is running then it is the Ballast Board Call Encompass Electronics or visit website 1-800-638-3328 they will have part number and price I found Ballast board for my DLP for only $65.00 on E-Bay Depends on who has what for sale.
you either need another Lamp which is very possible or Ballast Board. Ballast board is what turns Lamp on, pull back watch to see if there is a Ark coming from spark cap on Ballast board if so Lamp if not Ballast board call Mats for lamp 1-800-628-1118 OR Go to E-Bay for Lamp and Ballast Board Look under TV Parts After rereading your Post I think Lamp! Samsung OEM Had Alot of defective Lamps and do not hold up!
This is a DLP projection that has a ballast and color wheel along with a lamp. The three flashing lights on the front are a diagnostic code. The exact meaning is listed in the owner's manual under troubleshooting. I don't have the manual for your model with me at the moment, so I can't look it up. Since the unit works OK for a while, it suggests that a component is failing under heat stress. This is often the ballast. The ballast is the part that provides the power for the lamp similar to the ballast in a flourescent light. Check the manual for the code and post it here. Also, because your model uses 2 different ballast/lamp combinations, you will need to get the lamp number off of the lamp. Please post that here too.
In the meantime, check the rear area for any obstruction in the air flow. There should be a fan in the rear that needs to be clear of debris and can turn freely. With the set unplugged, try turning hte fan by hand. It should turn easily and continue on its own slowing down to a stop. If it stops suddenly, the fan may be defective and not moving enough air to keep the lamp cool.
