Question about Stoves 720EF Electric Double Oven
Diplomat cooker model no. adp4230 ( Softline) I am looking for the wiring diagram for the grill energy regulator switch. Or a picture.
  • james697 Oct 16, 2010
    Hi, not very helpfull i was looking wiring details for the grill switch and not the element
    Thank you.
    President:
  • 1,796 Answers
hI!! THE CORRECT NAME IS: SD1 GRILL ENERGY REGULATOR, cost is £21.61 And to replace it, just watch this video.
http://www.apart4u.co.uk/video-tutorials/cooker-repair-videos/how-to-change-your-grill-element-in-a-bosch-neff-and-siemens-cooker-or-oven.html
Thank You for using FixYa! Don't forget to rate this post!!
Posted on Oct 16, 2010
  • Rene J Solis Oct 16, 2010
    NO PROBLEM, GIVE ME A FEW TO GET THEM TO YOU
I need Instruction Manuel for A Diplomat ADP3120 Softline 600EM Lamona fitted oven
Google it or ask the manufacturer if they have one available
Sep 09, 2016 | Ovens
My grill in my Tricity Bendix cooker is not working?
ISOLATE THE MAINS VOLTAGE TO THE COOKER AND GRILL, if it has a plug unplug it.
There is a regulator on the switch, you will need a tester, if this is working and continuity through the switch reducing as you increase or rotate the switch, that's working. Go to the back top a regulator is attached to the chassis of the cooker inspect for exterior damage, if not check continuity it should only conduct in one direction, and not to the chassis, if it is conducting in all , or opposite directions replace the component. You should be able to collect one from a small electrical repair shop.
Hope this is helpful.
Regards
John
Nov 01, 2014 | Ovens
I need to set the time on my diplomat softline oven
If you operate the grill with door closed, cut-out will come into operation and the grill will not light. pull oven out of the wal,l undo the screws that are in the galvanized cover, lift up the cover and press the red reset button. put it all back together & it should be okay.
Sep 14, 2011 | Ovens
My LED display has disappeared on my Diplomat split level cooker, although my ignition is still working to light the oven and grille. Any solutions to this problem please?
ISOLATE MAINS POWER BEFORE REMOVING
The LED display uses low voltage input, often a connection problem causes the display to stop working, check wiring carefuly, as small light connectors is used. If all wiring connections look and feel secure, you have to dig deeper, a multimeter would be handy, to measure input voltage, but a level of understanding electrics or even better electronics would be required. If unsuccessful referr to whitegoods.co.uk for a replacement you will need the model and serial numbers to check for the correct part.
Hope this has been helpful.
johnf1
May 17, 2011 | Ovens
Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Nov 29, 2009 | Ovens
I have moved into a property that has a diplomat cooker. I am looking for instruction booklet for it can you help
Diplomat are no longer trading. These appliances where fitted with MFI kitchens who have also gone
Oct 19, 2009 | Ovens
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
Diplomat softline oven with separate grill
grill will not light, door was shut when grill was on.
Nov 05, 2008 | Ovens
Electrical connections on indesit cooker
Is it just a 2 wire connection element?
Feb 29, 2008 | Ovens
Stoves 720EF Electric Double Oven Logo
228 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
