Question about Dometic Rooftop RV Air Conditioner
Will not shut off
Dometic(duo therm) roof top (brisk Air) air conditioner comes on when switch is turned on and stays on no matter what the temp setting. the thermostat is a dual heat and air control. the furnace works fine and shuts off at requested temp.
the thermostat has been replaced still have problem on the ac side
  • argregoire Jun 04, 2008
    My ac will not cut off as well. Has a Duo Therm Analog control center. Runs constantly and cools, but not matter what the temp is the unit will not cut off.
    Novelist:
    Champion:
  • 230 Answers
Sounds like a stuck relay on the unit itself. Maybe there is a short in the control wire that comes from the thermostat that activates the fan.
The thermostat probably has one hot wire at all times. The thermostat then chooses which wire to send the voltage down based on your selection. One of those wires is probably for the fan only. Make sure that it is in good condition (no bare, pinched or wires)
Posted on Jun 17, 2008
I have a Dometic 15K roof Ac on my FW. After the AC reaches therm temp, the compressor and the fan turn off, but the fan starts right back up again and runs until you set the thermostat on off.
That is normal operation, only the compressor cycles, the fan stays running to keep air circulating for better temp control. Otherwise the rear of the space could get 5 degrees warmer than the front
Feb 23, 2015 | Dometic 459516 459516.XX1C0 Brisk Air...
Duo therm heat pump blowing hot air only
relay module or communication cable from t-stat issue.
Apr 02, 2014 | Dometic 459186 Duo-Therm Brisk Air...
Dometic 457915 roof air wont shut off automaticly
check fan wiring on board possible bad control board
Jun 13, 2012 | Dometic 457915 Duo Therm Brisk Air...
I have a duo therm brisk air model 57915-001 leak
Could be the drain path is clogged.. Take the cover off & see if you can get it cleaned..
Jul 09, 2009 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
634 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
