Question about Ryobi Cultivator
I want to be sure I have fuel line in correctly
Fuel line is leaking towards the rear of the car
Not enough information but try my best to help ! Make sure not leaking above fuel tank and it is definitly is a fuel line visible for possible repair.The fuel line might be able to be spliced and a coupler used an clamped to hold the line together an auto parts store should be able get correct fittings.relive any pressure from the lines before repair.
Hope this helps :-)
Oct 06, 2015 | 1998 Honda Accord
How to replace fuel lines on ryobi rlt30ces line trimmer
Hope this is what your looking for.
Please rate me
Thanks,
Feb 15, 2013 | Ryobi Garden
Not getting fuel to carb
You need to make sure you have connected the fuel lines uo correctly i.e the fuel line from the tank with the fuel filter on the end must go to the fuel inlet side of the carb not to the primer.
Aug 27, 2012 | Poulan Garden
Have a gas smell near top of motor-is there a gas line from fuel pump to fuel injection
Yes there is a line from the pumt to the injectors....and also a return line. It is unlikey to leak a small amount from this, as any leaks there are under pressure and spill massive amounts...Look around for smaller leaks, often in fuel vapor recovery system...Be sure gas cap is correct one and installed correctly.
Oct 20, 2010 | 1990 Toyota 4Runner
Routings of fuel line to Poulan 14 inch chainsaw Model 2025
No drawings or pix, but will try for description--the line from the tank that has the fuel filter is the main fuel source which goes to the upper connection on the carburetor. The lower carburetor connection goes to the intake side of the primer bulb, and the outlet side of the primer goes back into the tank, which has no filter inside the tank. The main problem is determining the correct primer port to connect back to the carburetor. When everything is connected, try priming the carburetor. If fuel fills the bulb, you have everything connected correctly. If nothing happens, try switching the two primer port connections and try to pump fuel again. If still nothing, hook the main supply line from the carburetor over to one of the primer ports and try for fuel again--if still nothing, switch the main supply line to the other primer port and pump again. If still nothing, check for a plugged fuel filter in the tank. If the filter was plugged, then go through the previous procedure again. Make sure to replace the fuel lines with original rubber lines, not plastic. Hope this helps!
Jul 13, 2010 | Poulan 14" Chainsaw
Replaced fuel lines now wont start dont know if lines are in correct position
make sure you prime the line with it NOT attached to carb to make sure its gettting fuel first then try to start
May 30, 2010 | Craftsman 25cc Gas Line Trimmer
Blower would not run at anything above 1/2 throttle. then it would not start at all. put a carb kit in and not it starts and runs at higher rpms but when it warms up it dies. when snapping the throttle it...
If the gas is old, for example, last season, change the fuel ..drain the tank, carb and fuel line.
Also clean the air filter... this can have similar effects on start/run.
Pull the spark plug and clean it also, you can use spray carb cleaner on the tip, and then clean with fine sandpaper.
then replace the fuel with fresh fuel/oil mix.
A good spray can of carb clean will work to clean any build up in the carb jets, fuel line etc...
Oct 30, 2009 | Ryobi Backpack Blower 25.4cc
Featherlite fuel lines
you have a primer bulb correct?
when you push it see which part squirts the fuel OUT that is your return line the other would be the suction or filter side.
May 24, 2009 | Garden
I may have lines on Backwards??
filtered line from tank goes into top inlet at carb. bottom inlet receives line that goes to carb side of primer {draw side} 3rd line goes from push side of bulb bach to fuel tank.
Mar 25, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Ryobi Cultivator Logo
16 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
