Question about Olympus SP800UZ Digital Camera
When I put freshly-charged batteries in and turn it on, I get the "battery empty" message and the camera turns off The batteries are good. It also works fine with the ac adapter. Any ideas?
  • mnicotera Oct 17, 2010
    I kind of figured it was an internal problem. Just wanted to confirm that with somebody who knows more about it than me. Thanks for your answer!
  • 10,515 Answers
This is a common problem with these models. This is an internal failure and needs repair. However, you could follow below steps to see if this would fix the problem :-
1. Pull the battery out. Clean the connectors with a cleaning solution or fine sandpaper.
2. Try to pull out the SD card and see, if the camera responds properly.
3. Make sure that the battery connector pins are not broken or tilted. Any breakage to these could result in the above mentioned error.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 16, 2010
Camera does not recognize batteries.
Your batteries are worn out and need replacing for new fresh ones. They are charging, but not holding the charge. If they are new, they are fakes or worn out.
You can buy batteries which have a higher capacity, more MaH (milli-amp hour) than your current ones.
Having a quick Google, it is a known problem.
try this ... i had the same problem with the same camera and this fixed it.
remove the battery, and remove the memory card ... then re-install the battery & turn on the camera.
this process seems to reset the camera, if the battery ran too low.
now you can re-install the memory card & battery and resume normal operation.
be sure to check for the small flashing green light on the back of the camera (next to the "flash" indicator symbol). it should be blinking when the camera is charging.
i hope this helps you.
nikon coolpix battery exhausted message Google Search
Feb 10, 2018 | Nikon Coolpix 4600 Digital Camera
Flashing 0% battery and won't turn on
I had the exact problem with the blinking top menu. I found that my memory card had gone bad. one i put in a fresh card the camera operated normally.
Aug 27, 2012 | Canon EOS 60D Digital Camera
Change the batteries message keeps appearing even with fresh batteries. The camera turns on then immediately turns off What's up?
This actually a really common problem among Canon point and shoot cameras. There are a couple of methods that have worked well for others.
1. Open the battery compartment and remove the batteries. Then take a regular wooden pencil and place the eraser end down onto the battery contacts. Rotate the pencil to remove any corrosion. Sometimes a lack of proper battery contact will result in the low battery indicator.
2. Take a toothpick and wedge the tip under the battery contact and break it off. This will put more pressure between battery and contacts.
You can also try installing 3rd party firmware at http://chdk.wikia.com/wiki/CHDK_in_Brief
This is a bit technical and will probably void your warranty, but might be worth the try.
May 08, 2011 | Canon PowerShot A460 Digital Camera
My nex tech binoculars will not turn turn on . Batteries are good
Was the camera dropped??
If it wasnt dropped try changing the batteries.
install a new or fully charged battery/batteries into the camera.
1. If the camera is on, turn it off.
2. If any accessories (memory card, lens, USB cable, camera or printer dock, etc.) are connected to the camera, remove/disconnect them.
3. Remove the battery/batteries from the camera.
4. Verify:
That you are using the correct battery/batteries for the camera
That the battery/batteries are correctly installed
That the battery/batteries are fresh or fully charged
Follow the battery installation and charging instructions in the camera User Guide
5. Turn on the camera.
Feb 08, 2011 | Cameras
Can't turn it on. Batteries are fresh.
Make sure or check out following thing :-
1) Direction of your battery might be wrong, Check out and put it again.
2) Check whether (Memory Card/Battery Cover) is properly closed. 3) Clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust ) 4) Load new or fully charged battery.
5) Turn ON the camera, again firmly.
Else, Your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 05, 2010 | Canon PowerShot S2 IS Digital Camera
"Battery Empty" Message
extra dose 12V power pinch for 3 sec
Jun 18, 2009 | Olympus FE-20 Digital Camera
Battery empty message
Put brand new batteries in. The battery empty message means there is no "juice" or power left in the batteries. If they are recharagable batteries, "re-juice" them (charge them).
Nov 24, 2008 | Olympus FE-230 Digital Camera
Battery Problem
the problem for the camera turning off or acting weird is the batteries. you need Alkalyne Batteries
Nov 19, 2008 | Olympus FE-210 Digital Camera
Camera will turn on and then turn off, while screen continuously flashes
I have had this problem with both a DSC-P72 and a DSC-P92 (same camera but 5 Mega pixel1.gif) They do need real good batteries, when the camera shut’s down I can run MP31.gif players or flashlights with those batteries for quit a while before those devices are dead.
I was traveling overseas once and installed “fresh” carbon batteries and the camera wouldn’t work at all. I had no photos on that trip until I found some alkaline batteries.
I even have bought 2 “dead” cameras1.gif to find that they work fine with REALLY GOOD batteries. So try it again before dumping the camera.
Feb 14, 2008 | Sony Cyber-Shot DSC-P92 Digital Camera
Battery problem
did you use comapny authorised battery if not go for it
Apr 24, 2007 | Canon PowerShot S1 IS Digital Camera
Olympus SP800UZ Digital Camera Logo
138 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
