Question about Kenmore 64202 Electric Dryer
Kenmore 110.64202200 dryer the heating element comes on very hot for about 15 seconds then shuts off. it repeats this cycle about every five minutes.
  • 11,896 Answers
Do all the cycles work correctly which would assume the timer is working. If all the cycles are working correctly, then test the power to the heating element. If the power is constant, then the element is bad. If the power cuts out, then follow the wires and test the component that it is connected to.
Posted on Oct 16, 2010
Speed queen dryer agm4199w heats up and shuts of
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Oct 12, 2014 | Dryers
How to replace a heating element on a Kenmore Elite Oasis ST dryer
Sounds like you need to replace the timer one the dryer not the element but to make sure I would do a little trouble shooting to rule out the element or heating coil turn on dryer cycle like normal for about 30 seconds then open the door to feel for heat if you do feel heat its your cycle/timer knob if you don't feel heat then it's the coil or element witch are the same also first always check your lint trap and ducts going outside the dryer make sure you have proper airflow through ducts vents. clogged vents ducts ect. Cause over heating of element coil causing a safety fuse to shut down heating coil/element but will not stop cycle also moisture censors detect moisture causing cycle to continue on hope this helps.
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
I have a kenmore 90 series Model number 100.66904692 s/n MH4501730 Dryer runs for maybe 10 to 15 minutes then shuts off. When you push the start button you can hear a clicking sound. After it sets f
YES NOT UR THERMAL FUSE.
BUT MAYBE AN OVERHEATING ISSUE
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Jun 14, 2014 | Kenmore Dryers
Leq2152ee1 dryer does dry but keeps stopping if put on any setting over 15 min. Dryer stops single beep and top four lights blink.
MAY BE BAD MOTOR WITH BAD WINDINGS USUALLY STOPS AFTER 20 MINUTES OF USE? OR HEATING ELEMENT IS OVERHEATING? DUE TO BAD VENTING? THERMAL CUT OFF KEEPS SHUTTING IT DOWN?
May 08, 2014 | Frigidaire GLEQ2152ES Electric Dryer
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
Having heating problem with Roper REX4634JQ0 dryer?
probably have a weak hi-limit thermostat on the element housing or cycling thermostat on the blower housing
Apr 26, 2012 | Roper Dryers
Dryer starts with heat. After 10-15 minutes, when dryer calls for more heat, here a metal clicking noise, flame does not ignite. When it's clicking, I can look down the back from the top and see a glow....
Your gas valve coils are defective. Part #694539 and 694540 are required. Once the coils get hot they collapse internally and the gas valve shuts off. This is a common problem when valve coils get weak from use.
Nov 09, 2009 | Whirlpool LGQ9857L Gas Dryer
Kenmore dryer shuts off after five minutes
The vent box inside the dryer still has lint in it. You need to reach way inside to get at it. Turn power off.
Jul 22, 2009 | Dryers
Dryer heats up and then cools off, won't stay hot.
sounds like either the heating element or limit switches are going out on you
Feb 21, 2009 | Kenmore Dryers
Kenmore 64202 Electric Dryer Logo
138 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
