Question about Whirlpool GHW9100L Front Load Washer
I am in the middle of changing the back drum bearing on a Whirlpool Front load washer Duet modelGHW9100LW1 and I have the back drum out of the machine but I am unable to separate the inner drum from the outer drum. I did take off the spring clip.Any suggestions?
  • 4 more comments
  • l_vandehey Oct 16, 2010
    I already had the drum out of the washer and took off the clips and the drum is in 2 pieces. I need to separate the inner drum from the outer plastic drum. Do I need to take off the spring clip located by the shaft? If I do, how do I get the pieces separated?
    Thanks for all your help
    Also, what is a spanner wrench and which nut are you talking about. I removed a large nut that held the pulley wheel but I do not see any more. Where is it located.
    Thanks
  • l_vandehey Oct 17, 2010
    so far everything is going fine. 1 more problem - the belt keeps coming off. Do i need to get a new pulley? I did notice that the pulley was loose so I added 2 machine bushings before I put the nut on and that seems to stop the pulley from moving back and forth. Now I am concerned that the pulley is bad causingh the bely to keep falling off. After all the use with the bad bearings, I am sure the pulley has some unusual wear causing the bely to fall off. Am I correct on this and will a new pulley solve the problem?
    The belt just falls off. I did notice that there is a loud thumping noise when it starts to spin, but quiets down when it goes faster. Also, when I spin by hand, it goes very smooth. Please let me know how to keep the belt on.
    Thanks
    All I can say is th ebelt comes off. Will a new pulley help that problem?
    after I put the bushing on, the machine went through 1 wash and then fell off during the second wash
    Genius:
  • 1,416 Answers
Hello
The solution below please take it step by step to solve the problem
The drum of a Whirlpool washing machine consists of a number of different pieces attached to form the whole. You will want to remove each piece separately to take the drum out of the machine. By removing the drum, you gain access to other components in your machine, such as the transmission and motor.
Difficulty: Moderate
INSTRUCTION
Tools needed to carry out the assignment/home
  • Bucket
  • Phillips screwdriver
  • Flathead screwdriver
  • Socket wrench
  • Spanner wrench
  1. 1 Unplug the washer from the electrical outlet.
  2. 2 Pull the washer away from the wall to access the water spigots. Turn both the hot and cold spigot to the off position.
  3. 3 Place a bucket under one spigot and disconnect the hose. Allow the water the drain out of the hose. Repeat the process with the other spigot.
  4. 4 Locate the water hose connections on the back of the washing machine. Turn each hose counter-clockwise to disconnect it from the washer. Place the hoses into the bucket and set them aside. This will aid in clean up but is not necessary to remove the drum.
  5. 5 Return to the front of the machine. Use a Phillips screwdriver to remove the two screws connecting the control panel to the washer. The screw locations may vary based on model but will often be in the lower corners. Lift the console up and allow it to flip back on the hinges. It will rest on the back of the unit.
  6. 6 Remove the door switch wire harness. It is located at the top, rear of the washer. Disconnect the harness by pulling the plugs apart.
  7. 7 Locate the clips on the top of the washer that hold the washer cabinet in place. Slide a Flathead screwdriver under the clips and push backward to pop them out of place. Lift the cabinet off the washer base.
  8. 8 Slide the screwdriver under the top piece on the cone of the agitator and pop it off. Twist the debris cup off the agitator. Grab the handle on the cup, twist and lift to remove the cup.
  9. 9 Remove the bolt under the debris cup using a socket wrench. This bolt sits in the middle of the agitator cone to hold the device in place. Once removed, the agitator should lift free from the washer. Grab the bottom of the agitator with both hands; pull the part up and out of the tub.
  10. 10 Look at the tub. You will see clips in various locations that hold the tub cover in place. Press down on the clips and remove them individually. Lift the tub cover off the tub.
  11. 11 Use a spanner wrench to disconnect the nut in the middle of the tub. This holds the inner and outer tub together. Pull the inner tub out of the machine once the nut is off.
  12. 12 Locate the three screws holding the outer tub in place. Remove the screws and lift the final piece of the drum out.
Same way to couple it back to it position.
Hope this is helpful?
Thank you and thanks for using fixya.
Posted on Oct 16, 2010
  • 2 more comments
  • Oloyede Monsuru Oct 16, 2010
    Yes use
    a spanner wrench to disconnect the nut or a Phillips screwdriver to remove the
    nut screws connecting to the drum.
    Look
    at the tub/ drum. You will see clips in various locations that hold the tub
    Then Grab the bottom
    Thanks once again.
  • Oloyede Monsuru Oct 17, 2010
    hello,
    what is the problem like ?
    thanks once again.
    hello,,
    make the comment be clear.
    thanks.
    What is the respond of the washer after the applying the solution giving ?
    Thanks.
Whirlpool duet front lading washer, GHW9150PW4
Could be drum bearings gone Quite a big job hence costly with around 3 hours labour plus parts, some models need half drum as the bearings are loaded in here,leak could be door boot seal at 7 yrs old not sure if worthwhile as its about the end of its working life.Good luck
Apr 06, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Tighten belt on duet whirlpool front loading washer
There is no adjustment for the belt of WP front load. If you hear loud noise when the drum is spinning because the drum bearing was loosen. If you have insurance cover tell them to replace. Else, a cost of repair is expensive.
Oct 20, 2013 | Whirlpool Duet GHW9150P Front Load Washer
When the washer spins, it is making a terrible loud noise. The washer has always vibrated, but this noise sounds more like a bearing to my husband. It also smelled hot at the end of the cycle. If the...
the noise is a drum bearing, it is pressed on the back of the washer drum, until recently you would have to buy a new drum for around $700.00 but there are a few companies out there selling a bearing kit, just go to EBAY and do a serch for whirlpool duet bearing kit. they are not easy to replace but it can be done by a novice with a few tools and allot of pay chance......GOOD LUCK
Nov 27, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool duet washer, inner stainless drum rubs
This sounds like a worn bearing housing or the bearing itself has packed up,either way you would have to strip and check these and replace what is broken
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer, it is loud on spin thumbing noise ?
could be the bearings test the drum by hand for play it can only get worse
Dec 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sounds like a Harley when it spins, still spins though.
If you get a very loud noise coming from the machine, and this noise is louder when it spins faster, then it is not a Harley inside your washer, it is the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer...after problem with it getting out of balance due to not draining and trying to spin with a heavy load, I have since noticed if I place my hand inside the tub..it will spin freely...
Your original problem is likely to have damaged the bearings and the spin tub shaft... the shocks can fail, but that would not affect the fitment of the shaft and bearings.
Apr 21, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9100L Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
