Question about Garden
Jack creeps down wit screw as tight as it will go.
    Brigadier General:
  • 4,088 Answers
The piston rings may be leaking fluid past them, the release valve seat or needle may be damaged, or the pump seals may be leaking back fluid. Repair is usually to tear down the entire jack and inspect each part for faults. It might be cheaper to just replace the jack if it is one of the Asian-made jacks. Hope this helps!
Posted on Oct 16, 2010
93yz250,got the motor rebuilt,and it ran good 4 about a week,it reeved up on it's own i shut it down now the pain in the ... wont start bk up . it's got spark,comp good ,carb seems 2 b good,theres...
I doubt the repair shop has done anything wrong. Yes, it sounds like an air leak between the carb and the head. Try tightening the mounting screws and bolts. Also check the tightness of carb screws on the choke etc.. Now check tightness on the head bolts and other mounting hardware on the head. Be sure the throttle is operating properly and the cable is not kinked or pinched.
Aug 19, 2011 | 2004 Yamaha YZ 250 F
I have a RD-TZ30 derailleur, runs great in all gears except the 6th. I have adjusted up and down 5 to 6 time on the adjustment according to the manual. It keeps trying to jump. Im at my wits end. Any...
Perhaps you have a tight link. Is it always the same place on the chain. Can you duplicate the problem in a static setting, say, with the bike suspended so you can 'pedal' it and observe what is happening at the rear?
http://www.parktool.com/blog/repair-help/tight-link-repair-ct-3-ct-5-ct-6-ct-7
or the B-screw adjustment could be such that the upper pulley is touching the cassette.
Or the RD may be bent out of alignment with the cassette.
Damaged/worn teeth on the cassette?
http://www.sheldonbrown.com/derailer-adjustment.html
See "Skipping/Autoshifting"
Frame flex/cable stiction?
Jun 30, 2011 | Shimano Xtr Rear Derailleur
I think my av elements on my husqvarna 36 chainsaw are too soft. The throtle trigger handle seems not to be tightly secure to the main body of the saw. Also the screws that attach the metal handlebar wont...
The screws into the tank to secure the top handle are self tapping, so if they will not tighten then yes the threads had stripped, you may be able to aquire some over sized screws to cure this, the saw has four rubber anti vibration mounts, and two bumper rubers either side of the tank to stop sideways movement, the later machine had a rubber around the right hand side of the top handle also to stop side ways movement, To change the rubbers you need to remove the starter cover, two of the securing screws also hold the l/h rubbers, remove the alloy chain catcher on the r/h side, and the cover plate top r/h side held with a single screw, the tank should now drop far enough to remove the rubbers, they are screw into the tank wit a self tapping screw on the back, you will need a special tool to remove them part no. 502510002, do not pull the tank too far down or you will stretch the fuel hose.
Apr 29, 2011 | Husqvarna Garden
Elevation adjustments do not seem to hold or the scope moves slowly over time. I'm not certain. Windage works fine. Looked at manual on the web and the scope must have changed design because not...
Most of the time a scope that creeps off its zero, has a loose mount screw and or loose mounting ring. Check the mounts all screws. Some times the opposite is true. The mounts are to tight and in a bind. Then during firing the receiver heats up an tweaks the scope enough to cause creep. If the scope is always on zero when cold and creeps off after a few shots, she is in a bind. Make all adjustments to the scope base and rings with a cold gun. Loosen the front ring screws first then re-tighten then loosen the rear doing the same. Then try and re-zero the gun. If the gun never comes back to zero, you end one day shooting hi to the right and try again the next day shooting in the same spot try to re-tighten all screws. Screws from mount to gun then scope rings to scope body.
Jan 02, 2011 | Nikon 39x40 Matte Nikoplex Buckmaster...
I am having problems shifting from first to second. It gets stuck in neutral and will not go to second.
Let's try adjusting your clutch. Follow the clutch cable down until you find the rubber bellows. Slid the bellows up and you'll see the cable adjuster. Loosen the lock nut and adjust the cable as short as it will go.
Now, remove the derby cover. In the center of the clutch assembly you'll see an adjuster screw and a lock nut. Loosen the lock nut and turn the adjuster screw inwards until you feel pressure against the screw. Don't force the screw as you will start to release the clutch. Once you've went in until you feel resistance, back out 1/2 to 1 full turn. Lock the lock nut down.
Now at the cable adjuster, adjust the cable out until you have about an 1/8" freeplay at the lever. Lock the lock nut. Now, test the clutch to see if it's dragging. Pull in the clutch, put the tranny in first gear, hit the start button. If the bike tries to creep forward, the cluch is dragging and you need to tighted the cable just a bit. If the bike does not try to pull forward and you can find neutral with the engine running, your clutch is working like it should.
If this does not solve your problem, the shifter pawl in the transmission may need to be adjusted. This requires special tools and an educated touch. This job would be better left to a professional.
Good Luck
Steve
May 07, 2010 | 2000 Harley Davidson FXDWG Dyna Wide Glide
We have a v illeroy and bch cistern that cracked
yes i can,,,he done the scews up to tight that hold then down and the move ment in them is cracking the screw holes out, undo the screws a little that hold them down and maybe put in some rubber washers as well,,,you only sit on them, its not a jig your doing
so they realy dont need to be done down tight only just to hold them thats all,
Jan 12, 2010 | Villeroy & Boch 6610 11 Subway...
How do i remove alternator on 1998 contour 2.0 engine
From underneth through the pass. wheel well. It's easier if you remove the cv axle, to get the bolt in the back and to get it out. It's a tough job on a lft good luck.
Sep 27, 2009 | 1998 Ford Contour
After opening, my automatic garage door creeps back down a bit
There is a sensitivity switch for both directions, open and close. If you access the garage door opener in the ceiling, you will see two adjustment screws for calibrating these. I would highly recommend following the instructions in your manual, as these are life safety adjustments! Your sensitivity for closing the door is adjusted to the positive. You just need to back it off a little. Place a 2x4 on the floor of the garage where the door comes down. and when the door hits the 2x4, it should automatically come back up. If not, you adjusted it too far. Hope this helps. and remember, check the manual for your specific adjustment procedures.
Mar 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garden Logo
80 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
