Question about Kohler 3386-6 Rialto Skylight Round Front Toilet
One of the screws that secures the toilet seat down seems to be stripped and doesn't allowed the seat to be tighten down. Once I removed it (very difficulty) I realized it came out with a thread insert, that was some how embeded down in the toilet basin. Apparently this type of toilet does not have the traditional hole through the basin allowing a simple hardware combination bolt/washer/nut to be use to secure the seat/cover assembly. Any suggestions on how to keep the toilet seat in place?
    Scholar:
    New Friend:
  • 73 Answers
Consider using a toggle bolt (with wings) and a large stainless steel washer to re-attach the seat.
Posted on Nov 04, 2013
3 Suggested Answers
co7196
  • 3433 Answers
SOURCE: I cannot tighten the toilet seat on my kohler 3386
Give Kohler a call AFTER you read the instructions thoroughly. Good Luck, seriously.
Posted on Nov 09, 2009
heatman101
  • 43501 Answers
SOURCE: Can this bowl be combined with an Eljer Tank? I
No you cannot interchange the tanks... in fact you often can't even interchange tanks within the same brand...
Did you try here???
http://www.plumbersurplus.com/Cat/Toilet-Tanks/762/List?color=Mexican+Sand
heatman101
Posted on Apr 23, 2011
How to stop seat from wobbling doesnt seem to have screws that fo into seat just a place for seat to sit on and then some cap to put over but nothing seems to tighten it.Im tired of falling off the toilet
First lift the covers off where the bolts should be (they should lift towards the tank). Are the bolts in place? If not, go to your neighborhood hardware store and look for replacement hardware. (Most stores will have staff willing to help you find the right parts.) Is the bowl damaged so that the holes seem large compared to the holes in the seat anchor points? Are the seat anchor points damaged?
The bolts should have nuts (and possibly washers, but not all models use them) underneath the bowl. Screw down the bolt while holding the nut from turning (so you need an adjustable wrench or appropriately sized wrench). Again see the local hardware store for the hardware if you do not have the nuts. Keep the seat centered as you tighten the bolts. (Alternate tightening until it is stable - do not tighten one bolt all the way down before doing the other side. You risk overtightening and cracking the bowl.)
I hope this helps.
(if the seat is damaged, you may want to replace it. If the bowl is damaged you must replace that.)
Jun 10, 2010 | Kohler - Toilet Seat - Moondance -...
The toilet seat is super loose and I am unable to tighten.
reach under and hold wing nut or nut while tightening screw if plastic screws are stripped any hardware or home store carry replacement screws
May 31, 2010 | Toto Carlyle 1-piece Elongated Bowl Toilet
My toilet seat is loose but there are no visible external securing parts. Its a Banyo suite with gentle self closing lid mechanism. How can I tighten it up and secure it back in place?
where the hinges sit, use a small screwdriver and prise off the top chrome cover.Under neath are the securing screws for the seat. tighten these carefully until seat is secure, then replace the covers.
May 13, 2010 | Home
My toilet seat is loose but there are no visible external securing parts. Its a Banyo suite, with gentle self closing lid mechanism. How can I tighten it up and secure it back in place?
When the seat is closed there should be two plastic extensions about one and half inches long, lying flush on the base. Open these with a small screwdriver, like a ****-shell. There should be a regular head screw there and correspondingly underneath the screw, a nylon nut. hold the nut and tighten the screw.
Please rate this answer for me. Thank you
Mar 21, 2010 | Home
Loose toilet seat
If the screws don't tighten the either the screw threads are stripped or the attachment nut is stripped. Take the screw and nut to any hmoe repair center and get new ones. remember don't over-tighten then screws as this will crack the unit.
Feb 11, 2010 | Toto Drake ADA Compliant Toilet with...
Toilet seat
Here's what I did. Unscrew them as much as possible. Then I used a bolt cutter and hacksaw to cut away as much of the plastic seat holders as possible. I could then remove most of the seat, and get better access to the screws. I then raised the loose screws enough to cut them with a bolt cutter. Soft screws cut easily. The screw heads are now out. Now, tap down on the screw/anchor and it falls into the bowl. It will stay there. The remaining problem is that you need anchors to secure the new toilet seat. Kohler wants $50. I have a usable but loose seat. Never again-Kohler.
I strongly recommend using a boltcutter. A hacksaw will tear up the bowl.
Nov 25, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Toilet seat come loose and no obvious way to tighten??
well there should be 2 hinges rite behind seat. you wont see the screws cause they are under a plastic cover. take a flat head screw driver and pry up cover. lil cover should lift up towards tank. then you should see screws. the nut is under bowl you have to bend down then look up to see them or do what i do and feel for them. take big flat head or big philips screw driver and while you hold nut titen screw. hope this helps. duane:)
Oct 05, 2009 | Duravit Starck 3 Wall Mounted Toilet with...
Loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Sep 06, 2009 | Home
We have 3 soft closing Toilet seats.Newly installed.One has become very loose. Asking agent/ shop , they showed me how to remove on another modle. Press on white inside lift seat off etc and ecposes the...
Reach under the bowl of the toilet and feel for a rather large wing-nut bolt on each side of the toilet. You must hold these with your hand and tighten the screws with a screwdriver. If you don't hold these wingnuts, then the screws will keep spinning forever and never tighten. Run your hand directly below the toilet just below the screws and you will find them. VERY EASY FIX!
Aug 01, 2009 | Villeroy & Boch Home
Kohler 3386-6 Rialto Skylight Round Front Toilet Logo
213 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
