Question about Peg Perego John Deere Gator HPX Ride on Toy
How should I connect the wires to the motors? Our Peg Perego John Deere tractor lost its ability to go. I saw voltages on the motors when disconnected from the motors, but no voltage when connected. I replaced one of the motors and it started working. However, I may have mixed some of the motor connections when hooking it back up. Now, when in 1st gear, the (new motor for the) right wheel spins fast and the left doesn't spin. When in 2nd gear, they both spin, the right fast and the left slow. I may have wired it incorrectly, or I may need to replace the left motor as well. I believe the colors are red, white, black, and blue. How should they be connected to the motors for proper operation? If it's easier to describe without colors, what should the voltages be at the motors when in 1st or 2nd gear for proper operation? Thanks.
    An expert whose answer gotĀ voted for 100 times.
    Habit-Forming:
  • 156 Answers
Hi, you might have fixed this already, but I usually email the repair department at help@mypegperegoparts.com if i need any help with my kids toys.
hope this helps
Posted on Nov 05, 2010
Battery is full on my sons peg perego john deere but it wont run
did you verify the battery voltage with a multimeter, could have a bad charger that gives a green light making one think that the battery is fully charged, also check the fuse on the battery
Dec 14, 2015 | Peg Perego John Deere Turf Tractor
John deere farm power tractor not moving, battery is fully charged and putting out 12 volts
check the voltage at the foot pedal, if you have 12 volts there, then check at the shifter, if you have 12 volts there then check at the motors, if you have 12 volts there then you have bad motors
Mar 15, 2013 | Peg Perego John Deere Farm Tractor and...
Can i put a 12 volt lawn tractor battery in the tractor
Wiring could be an issue when upgrading batteries. Also, if you manage to properly connect a larger voltage battery, you may (probably will) overheat and destroy the motors.
Sep 24, 2012 | Peg Perego John Deere Turf Tractor
Peg perego john deere tractor charger indicator light does not light up and tractor does not take a charge - brand new
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show
any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
Sep 02, 2012 | Peg Perego John Deere Gator HPX Ride on...
How should I connect the wires to the motors? Our Peg Perego John Deere tractor lost its ability to go. I saw voltages on the motor wires when the wires were disconnected from the motors, but no...
white and black on one motor and red and blue on the other motor you can change which way the wheel spins by swapping the two wires around on the motor
Oct 16, 2010 | Peg Perego John Deere Turf Tractor
Peg Perego John Deere tractor 12volt will only work in reverse. Will not go forward in the slow or fast speeds
check all wre connections are not dirty or loose!
lift out pedal swith to check there too!
Cheeers Rob
Aug 16, 2009 | Peg Perego John Deere Turf Tractor
Peg Perego John Deere Gator HPX Ride on Toy Logo
236 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
