Question about Miele 24 in. G656SCi Plus SS Built-in Dishwasher
Miele turbothermic G 575 SC Electronics problem?
1. The maskin kept heating water for hours, did not continue.
2. Now the program stops (uses hours) and the water is cold. The machine empties when I turn the programme nob forward.
bjorn
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
Check the bottom tray of the unit. If water is there and the float switch is activated the drain will run and nothing else. Get rid of the water so the float switch goes off and you should be back in business. If it happens again you may have a leak somewhere and should get it looked at.
Sgt 48
Posted on Jun 04, 2008
Miele G 694 SC Plus Dishwashers : Cannot exit Test Program
Ok,if you unplug it,it should reset it.
Mar 09, 2014 | Dishwashers
G 646 sc pump still runs when programme is off
I had the same problem, the drain pump kept working even on the off program. After a little investigation i found out that there is a leak sensor that triggers the drain pump continually until it does not "sense" water anymore.
Firstl i tried to open the rear panel with no success.
Next i tilted the dishwasher to the left and let all the water drain out, plugged the dishwasher back to electricity and it worked!!!
I hope it will help you.
Jan 02, 2013 | Miele 24 in. G646SC Plus Free-Standing...
Miele Turbothermic G579SC Dishwasher Intermittent Problem Dishwasher works fine on approximately 30 per cent of times it is used. This percentage seems to be about the same whatever program is selected...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Feb 07, 2011 | Miele Dishwashers
Trying to find the dimensions of the Miele G694 SC Toughtronic Turbothermic Dishwasher. It doesn't appear to be the standard 24 inch size and wanted to verify the dimensions before I replace it with...
if you go to the Miele website you should be able to download the manual for the machine if you don't have one and in the installation part of the manual this should give you dimensions. if not Miele service dept should be able to help.can't give you tel number as i am not sure where you live. the website will direct you though.
Dec 03, 2009 | Miele 24 in. Touchtronic G694SC Built-In...
Intake/drain light is flashing
When this happens with my dishwasher it usually means that the drain is clogged with food/debris.  To fix 1) remove bottom dish rack from machine 2) using a small cup, scoop out as much water as possible 3) remove inlet drain cover and unsnap the plastic insert and remove 4) rinse the plastic part and reinstall 5) start machine 6) if light still flashes, repeat steps 3 4 and 5 and restart
Jul 18, 2009 | Miele G892SC SS Dishwasher
Miele G892 SC dishwasher not heating/cycle won't stop
Miele have cold inlet only. Either element is open circuit, or the relay that switches the element has failed. My money would be on the element first, then the relay. The machine will sit in that mode forever as it is waiting for the temperature of the water to reach a certain temp before telling the electronic unit to move to the next part of the wash. If you need assistance in how to test & how to get to these parts just let me know. But you will need an ohm meter to test the element. Regards
Aug 20, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Miele 24 in. G656SCi Plus SS Built-in Dishwasher Logo
1,803 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
