Question about Hayward 1hp Power Flo Matrix Above Ground Pool Pump # Sp1592
I am trying to remove the impeller on a SP158015, to change the leaking seal to the motor shaft. Is the impeller threaded?
    Novelist:
  • 116 Answers
The instruction below may vary slightly for your model pump, but should give you the info you need to get the impeller off and get to the seal... To remove the impeller you need to lock the motor and unscrew impeller. Depending on the motor, you remove a cap in the middle of the tailpiece and hold with a wrench, or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under the thermal overload switch and then turning impeller. If the impeller has a bolt or screw in the middle remove that first. It should be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (it should be counter clockwise standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you unbolt the motor from the seal plate, pull the seal plate away from motor (this removes half the seal), and then pop the other half of the seal from the seal plate. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Posted on Oct 16, 2010
How to replace impeller
take bolts out to separate wet end of pump and motor then remove screw if one on impeller sometimes they are backwards threads take screw out then unscrew impeller while holding shaft of motor that should be a regular thread separate backing plate from motor change seals then revese
Jul 06, 2014 | Pool & Spa
Pentair 011523 pump shaft seal is leaking. How do you remove the impeller and motor?
Separate the plumbing portion of the pump from the seal plate which is attached to the motor. The bolts will be a 9/16 inch hex head, that are visible facing the motor. Remove those bolts. That will then allow you to pull the motor and the seal plate away from the plumbing portion of the pump. Remove the diffuser which is covering the impeller, and then the impeller will need to be unthreaded off of the motors shaft. The motors shaft, will need to be locked. You can do this by removing the Cap on the backside of the motor and you can use whatever tool required to keep the shaft from spinning. Once you are able to lock the shaft, you can read the impeller... Note* some styles will have a screw in the middle of the impeller securing it to the motors shaft? This screw is Backwards thread, not normal thread. If your pump has this screw, need to remove it first, then you will be able to unthread the impeller off of the motors shaft.
once the impeller is removed, you can then remove the two halves of the shaft seal. Very carefully reinsert the new shaft seal into the proper places, just the way they were prior to you removing them.
Reassemble in backwards order as you disassembled everything.
good luck
Sep 04, 2013 | Pentair 011523 WhisperFlo High Performance...
How to remove impeller on Pentair ultra-flow pump
Remember to remove the impeller locking screw (left hand thread) before attempting to unscrew impeller.
May 05, 2013 | Pool & Spa
Winding noise with some water leaking from the motor seal. Water still flowing but sounds laborous.
The shaft seal more likely than not needs to be replaced. If your shaft seal has been leaking for any length of time, the bearings could be damaged and this should be replaced. The whisperflow uses a PS1000 shaft seal and is fairly easy to replace (most seals available online or at most swimming pool retail stores). It is best advised not to run the pump until you have had this inspected by a licensed pool technician or have changed out the seal.
1) Make sure breaker/power to pump is off. 2) Remove the six bolts holding the wet end to the seal plate. 3) Remove the diffuser to expose the impeller. 4) Remove the screw in the middle of the impeller by turning clockwise (left hand threads). 5) Remove the dust cap at the rear of the motor and use a wrench to hold the shaft while you remove the impeller by turning counterclockwise. 6) Once the impeller is off, remove the four bolts holding the seal plate to the motor. 7) Press the old seal out of the seal plate and clean it thoroughly. Remove the ceramic part of the seal from the impeller and clean it thoroughly as well. 8) Apply a thin coat of lube (I prefer Magic Lube or Lube Tube) to the seal plate and impeller where the new seal will go. 9) Remove the new PS1000 shaft seal from the box (being careful *NOT* to touch the ceramic or carbon face with your fingers), press the metal part into the seal plate carefully, try not to bend the metal and make sure its completely seated against the seal plate. 10) You can now install the seal plate back onto the motor and secure with four bolts. Press the ceramic part into the impeller, use cardboard or paper between your fingers and the ceramic face. 11) Once you have seated the seal into the impeller, hold the motor shaft and thread the impeller on until snug, then reinstall the stainless screw, remember it is left hand thread so you'll have to turn it counterclockwise. 12) Reinstall the diffuser over the impeller and then install the wet end onto the seal plate using the six bolts, don't overtighten them.
Check the pump for operation and you should be good to go!
Dec 07, 2010 | Pentair 011515 WhisperFlo FullRated Energy...
How do you remove the impeller from the motor shaft?
If the shaft seal has been leaking the impeller stem may have split due to corrosion. This makes it very hard to un thread the impeller. After removing the face plate, try sliding a screwdriver into the front of the motor thru the vents. You should be able to seize the armature from turning by doing this. Then use a large channel lock wrench and try and un screw the impeller CCW. If this doesn't work you have to break the impeller off. See my previous post.
Oct 16, 2010 | Waterway Spa Pump Executive 56 Frame 4hp...
Pump seal is leaking water. I removed the screws holding the pump together. How do I remove the impellor to get at the seal?
This is from one of my previous posts, may be some extra steps, but should cover what you need... Turn off the electric first. Now split the pump in two by removing the large clamp or 4-6 bolts holding the two halves together. (not the 4 bolts holding the motor to seal plate, but the the bolts holding the seal plate to the seal plate housing). Once you remove the clamp or bolts, the motor with seal plate, diffuser, and Impeller can all be pulled back away from the pump. Then disconnect the electrical from the motor and you can pull the motor with the seal plate, and impeller all the way out and work on it. To get to the impeller, you need to remove the diffuser (plastic housing that goes around the impeller) usually by a series of 3 to 6 small screws. To remove the impeller you need to lock the motor and unscrew impeller. Depending on the motor, you remove a cap in the middle of the tail piece and hold with a wrench, or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under the thermal overload switch, or removing the capacitor for even easier access. Once you've locked the shaft, you can just unscrew impeller. If the impeller has a bolt or screw in the middle remove that first. this screw will be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you unbolt the motor from the seal plate, pull the seal plate away from motor (this removes half the seal), and then pop the other half of the seal from the seal plate. Make sure to replace the shaft seal, and use a tiny bit of pool lube on the rubber parts when installing, but keep the white ceramic, and black graphite surfaces 100% free of any dirt, grease, etc while working with them. Installation is pretty much just the reverse. Install half the seal into the seal plate. Install the seal plate onto motor and bolt into place. Install other half of seal onto shaft. Screw impeller onto shaft and install screw (if one was there to start with) in center of impeller (reverse thread). install diffuser over impeller make sure it is centered and doesn't rub the impeller hub. Install new diffuser and valute o-rings. Hookup wiring before re-attaching to rest of pump. Clamp or bolt back together. Pour plenty of water into pot to prime and flip the motor on for a sec or two. Pour some more water. Install pot lid. You should be good to go. Keep in mind there are many different pumps and some variations to the above instructions, but the above should cover most situations. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 03, 2010 | Dynamo ABOVEGROUND POOL PUMP - 1.5HP -
How do you remove the empellor from the motor shaft? The seal is leaking. I have the 4 screws loose holding the pump casing. Does is slip off the motor shaft or is it threaded on?
First off, are you sure it's the shaft seal leaking and not the Valute (the large o-ring or seal that is in between to two halves of the pump) seal? To clarify, if you get your head down and look at the bottom of the pump while it's running you should be able to see the water coming from the joint between the seal plate, and the seal plate housing, or just behind that from the bottom of the motor probably from the vent holes in the motor housing.
Now to answer your question, assuming it is the shaft seal leaking.... You may have already done some of these steps, if so, sorry - just ignore, but it may help others. To get to the impeller, you need to split the pump into two (the wet end from the dry end) This is done by either removing a large clamp, or removing 4 to 6 bolts depending on the pump. (I'm not talking about the 4 bolts that hold the motor to the seal plate, those come later see below) Once you do this the Motor, seal plate, impeller and diffuser will all pull back away from the front of the pump. At this point it's best to disconnect the electric and remove the whole assembly so you can work on a table or bench. Before removing the impeller you need to remove the diffuser which is screwed over the impeller onto the seal plate with 3-6 small screws. To remove the impeller you need to lock the motor and just unscrew impeller. Depending on the motor, you remove a cap in the middle of the tail piece and hold with a wrench, or remove a cap that covers the whole end and grab the shaft with a wrench (usually 7/16") by sliding it under one of the components (not sure exact part off top of my head have to look at it) and then turning impeller. If the impeller has a bolt or screw in the middle remove that first. It should be reverse thread so make sure you don't turn the wrong way and break or strip. If there is no screw, or after you've removed it, just spin the impeller off (it should be counter clockwise standard thread). If you can't do it by hand and assuming you don't have an impeller wrench, be very careful and use a large pliers, pipe wrench, or strap wrench to loosen it. After that you unbolt the motor from the seal plate, pull the seal plate away from motor (this removes half the seal), and then pop the other half of the seal from the seal plate. One thing to note and/or clarify... in your description you said you have the "4" screws loose... As I mentioned above, most pumps have either a large clamp or 6 bolts holding the two halves of the pump together. In your case I believe it's bolts. Some have 4, but most have 6. Then there also 4 bolts that hold the motor to the seal plate. Just want to clarify that you split the pump in two and remove the diffuser, and impeller, before removing the motor from the seal plate. I haven't worked on a Waterway in awhile, but there are basically the same as many other pumps. You may have 4 bolts, just wanted to clarify from the motor mounting bolts. If something looks different on your pump from my description let me know by leaving a comment and I'll clarify asap. Good Luck!
Sep 19, 2010 | Waterway Champion 1 1/2 Hp 230v Energy...
My Hayward just hums when I turn it on and after a few seconds the breaker pops.
You will need to disassemble the pump and check the impeller. remove any debris and try turning the impeller by hand. If it does not move or is dragging, you will need to overhaul the pump. Possibly a shaft seal leak has damaged the motor bearing(s). Replace the shaft seal and motor bearings. If the motor is badly deteriorated, you might need to replace the motor. Note... the impeller turns counterclockwise to loosen. you may need special tools to grip and hold the motor shaft and the impeller to prevent damage to the impeller. If the impeller is seized on the shaft from rust, you may have to break it to get it off. reassemble with teflon lubricant on the shaft threads when reinstalling the impeller. This will prevent seizure later.
Apr 10, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Need to know how to remove the impeller.
remove back cover of mtr. hold shaft with large screw drver. remember some modles have rev. threads
Dec 08, 2009 | Jacuzzi Impeller, L - 3/4 H.P
1hp whisperflow pump, seal change. How?
Make sure breaker/power to pump is off. Remove the six bolts holding the wet end to the seal plate. Remove the diffuser to expose the impeller. Remove the screw in the middle of the impeller by turning clockwise (left hand threads). Remove the dust cap at the rear of the motor and use a wrench to hold the shaft while you remove the impeller by turning counterclockwise. Once the impeller is off, remove the four bolts holding the seal plate to the motor. Press the old seal out of the seal plate and clean it thoroughly. Remove the ceramic part of the seal from the impeller and clean it thoroughly as well. Apply a thin coat of lube to the seal plate and impeller where the new seal will go. Remove the new PS1000 shaft seal from the box (being careful not to touch the ceramic or carbon face with your fingers), press the metal part into the seal plate carefully, try not to bend the metal and make sure its completely seated against the seal plate. You can now install the seal plate back onto the motor and secure with four bolts. Press the ceramic part into the impeller, use cardboard or paper between your fingers and the ceramic face. Once you have seated the seal into the impeller, hold the motor shaft and thread the impeller on until snug, then reinstall the stainless screw, remember it is left hand thread so you'll have to turn it counterclockwise. Reinstall the diffuser over the impeller and then install the wet end onto the seal plate using the six bolts, don't overtighten them.
It is a good idea to replace the tank o-ring when taking to pump apart, but if the o-rings are in good condition, just apply a light coat of lube and reuse them.
This is a general guide for replacing a seal, if you have trouble removing the impeller, you may need an impeller wrench and a tool to hold the motor shaft.
I hope this helps, if you have any specific questions, email me at mail@leisurepoolservice.com
Oct 28, 2009 | Pentair Pool & Spa
Hayward 1hp Power Flo Matrix Above Ground Pool Pump # Sp1592 Logo
388 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
