Question about Brother HL 1440 Laser Printer
The pages do not come out clean. There is a gray toner shadow over entire page.
    Genius:
  • 1,325 Answers
You need service to this printer -- changing the rollers and a nice cleaning will help
bring it to a service centre
Posted on Oct 16, 2010
Samsung clp 315 printing shadow images
Ghosting appears often because of bad toner. If cartridges have been refilled, they have wrong toner in them. If drum has worn out it will usually tell you. All parts for this machine cost too much. If toner is not the problem, probably best to get a new machine rather than pay to get it fixed. Brothers are cheaper to run.
Sep 01, 2014 | Samsung CLP 315 Laser Printer
Printer leaves look of burn marks as granular shadow over page
If the paper really is being burnt then there is a fault with the fuser roller temperature control. This would also make a smell. If this gray sheen is made of toner then this may be the laser unit not putting out enough power. The optics could be dirty. One thing to try before attempting repair- Reduce the print density to minimum in the printer advanced settings. This increases the Laser power. Good luck
Sep 22, 2007 | Lexmark C524 Laser Printer
Dirty pages
sounds like a dodgy black toner - is it a 3rd party toner - had this quite a lot myself at work with cheaper cartridges. to print a cleaning page just flick through the menu to diagnostics or print quality - in here you should find some cleaning tools of the machine
Oct 11, 2013 | HP LaserJet 5550 Printer
There is a faint background shadow covering the
remove toner/drum unit from the printer. remove toner from drum unit and shake toner cart. side-side to loosen toner inside. On top front of the drum unit there is a purple/blue button that will slide right-left. Do this a few times to clean the wire. If there's a lot of loose toner, take a vacuum and clean carefully. Put everything back inside. With front door still open, hold GO/Control button down until all lights have lit, then let go, close front cover.
If you still have the shadow over the page, it's most likely the toner cart and you need to buy a new one (or recond.-refill) at someplace like Office Depot or Staples.
Jan 20, 2010 | Brother HL-2040 Laser Printer
HP Laserjet 5P shading edges of page
This is probably due to a defective cartridge, Charge Roller or Transfer roller.
Check the cartridge for a band of toner still on the drum.
Check the Charge roller for oil or smudges, this roller should be a lighter color and should be relatively free of toner or marks.
Same as the Transfer Roll, which will be dark, though excess toner should be evident.
A relatively smooth straight line is generally the cartridge.
A rather wavey or broken line is most likely the rollers.
You can however attempt to print a large amount of pages (25-50) in an attempt to clean the parts, however if either part is defective they will need to be replaced and no manner of printing will clean them.
Apr 14, 2009 | HP LaserJet 5p Printer
Old LaserJet 4L working perfectly. Just bought new generic toner cartridge and now getting shading over entire page, turning paper an almost-even gray, darkest at left edge. I'm suspecting cheap cartridge...
You're right about the cartridge and I suppose cleaning it means all the toner that the generic cartridge dumped. Turn off the machine, take out the cartridge and use a vacuum cleaner and a soft brush to get that extra toner out. After that use a soft cloth (not terry) to wipe down the inside.
Apr 06, 2009 | HP LaserJet 4L Printer
Shadowing/graying with printing
Hi fa1103:
Gray background
1. Do not use media that has already been run through the printer.
2. Try using a different type of media.
3. Print a few more pages to see if the problem corrects itself.
4. Turn over the stack of media in the tray. Also, try rotating the stack 180°.
5. Open the Configure Device menu at the printer control panel. On the Print Quality
submenu, increase the TONER DENSITY setting. See the user guide.
6. Make sure that the environmental specifications for the printer are being met.
try these steps to see if they work for you.
pdouglasss
Dec 23, 2008 | HP LaserJet 2420dn Printer
Gray pages
It is a high voltage problem, normally caused by the toner cartridge, but if you've already replaced this i suggest you clean the cartridge contacts in the printer, if this doesn't work you will need a replacement HVPS (high voltage power supply)
May 14, 2008 | HP LaserJet 1300 Printer
HP 2420dn printing gray and shadows
maybe the scan unit need to clean first you most sure that the toner cartridge is original and new then start clean th scan unit reflector d9b88f3.jpg
Mar 12, 2008 | HP LaserJet 2420dn Printer
Brother HL 1440 Laser Printer Logo
190 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
