Question about Refrigerators
The motor is running, but the temperature on the freezer and the refrigerator go up. Worked a couple times by unplugging and replugging. Now, cannot change the temperatures on the digital thermostat.
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 17, 2010
Refrigerator is not restarting when it cuts off
Anthony, the key question is: "What is the freezer portion doing"? IF the freezer is cold and the 'fridge is warm, it's an airflow issue between the two. If BOTH are just shutting down, I'd look at the fan motor underneath, clean the dust-bunnies and if the fan is shutting off, replace it. Additionally, IF shoved back into an alcove where it can't breathe, remove things stored on top and pull it out from the wall a couple of inches!
Oct 10, 2015 | KitchenAid Refrigerators
The refrigerator warning beeper is going off and the temperature is slowly rising. the freezer is working fine. it is a samsung model RB2055BB
Unplug for 24 hours and replug. After 2 hours of running, temps of fridge and freezer should be close to normal and water pan should be nearly full. If so, suspect your defrost heater as needing replacing, and note that unit will behave as-is for a few days and then your symptom will return, confirming the need for the new heater. Change the small inexpensive clip-on thermostat at the same time.
Dec 21, 2014 | Samsung Refrigerators
Fluctuating Freezer and Refrigerator Temperature
check the freezer evaporator thermistor on the top left corner clipped to the evaporator,if its not 16k ohm when at 32 degrees in a glass of ice water after 4 minutes it will defrost too many times and cause this issue,you need to unplug the J1 connector on the mother board in the rear behind the cover and check terminals 4 & 5 un the plug,not on the board though
Feb 07, 2013 | Refrigerators
Ge refrigerator won't cool. compressor doesn't come on
The compressor is gone, only option replacement.
Apr 18, 2012 | Televison & Video
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frig stopped cooling, unplugged & replugging worked - now what?
hi try out the following settings....
Check your temperature setting.
- Check if no ice present in the evaporator, try the defrosting
- Check vents if air is present if no then check your blower if running or icing evaporator.
- Check your vents if not obstructed with stocks, or the unit is not overloaded with stocks.
- Check if compressor is running continues, if not then you need a qualified technician.
i think after checking this it will work out for u.!!!
thank u
rate me!!
Apr 10, 2009 | Kenmore Refrigerators
Ge artic refrigeratior freezer stainless steel
Unplug / Replug the fridge. If doesn't work might be the mother board in back.
Jul 13, 2008 | GE Profile Arctica Stainless Steel Top...
Will not run
Unplug it for one minute and plug it back in. After a couple clicks it should kick in. If not there are tests you can do at the motherboard
Dec 30, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Touch Temperature Controls not working
Unplugging and replugging worked great! (We left it unplugged for about one minute. The motor started up almost instantly but we still had no numbers on display. I discovered that after replugging, you need to touch one of the up or down arrows for the display to reappear. What a lifesaver this was! Thanks so much.
Apr 09, 2006 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
