Question about Clarion DB358RMP CD Player
Soud from speakers on the left is distorted hear when i up the volume
    Scholar:
  • 127 Answers
It could be your radio is audio is set wrong or you have blown the speaker from the distortion of the radio being set wrong
email caraudioquestion@gmail.com
Posted on Oct 16, 2010
Keeps blowing speakers on left front channel
What exactly do you mean by "middle volume settings"? Where is the volume control physically, where are the channel levels set and what is the crossover point? After the crackling appears , do you switch speakers to the right channel to see if speakers are actually damaged or if the receiver is producing the distortion?
Jan 22, 2014 | Pioneer VSX520 Receiver
Only right side volume working wehn volume is low, when volume is high both sides work but distorted
It may mean that the connection for your left side speakers are loose or they are not connected properly. you can also try plugging the speakers to another music source (ipod, stereo, etc.)
If the same problem happens it is most likely a faulty wiring on the left speakers.
PS - if your computer volume software has the balance option make sure it's in the middle and not set to have output on just the left or the right side.
Hope this helps!
May 12, 2011 | Logitech R-10 Computer Speakers
Terrible sound, sounds like speaker blown. Got it 2 days ago.
If this is a "new to you" TV, keep reading. If it is a brand new TV, I'd be on the phone to the store to have a replacement ready for delivery / pick up. You do not want to be repairing a TV that is 2 days old.
The first thing to do is determine if the distortion is coming from the speaker or if it is on the signal going into the speaker. Do both speakers sound distorted or only one?
You didn't include the model number of your TV, so I can't speak to specifics. Look for a terminal on the rear of the set identified as "speaker" or "external speaker". If provided, there will be one set of terminals marked for the left and one for the right external speaker.
Connect a speaker directly to the terminals marked for either the left or right speaker (connect to the one that sounds distorted if only one of the built in speakers works correctly - other wise pick either speaker terminal pair.). Speakers that have RCA plugs on them, have built in amplifiers, require batteries or or to be plugged in to an outlet should not be connected here.
Alternatively, you could connect a pair of stereo headphones or earplugs if your TV offers a jack for them. It would have a headphone icon or say "phones" above the jack if one is provided.
Once connected, turn the TV on, lower the volume and set the TV to enable the external speakers / disable the internal speakers. This may be done via menu item selection or a small switch near the speaker terminals. Slowly increase the volume to listen to the quality or clarity of the sound coming from the speakers you connected. If they sound distorted, the problem lies with the audio amplifier in the TV. If they sound OK, then there is a problem with the speakers in the TV.
If you can't return the TV, you may have to see about using the left and right audio line out or HDMI jacks to send the audio to an external amplifier and speakers to hear the program.
I hope this was helpful and good luck! Please rate my reply. Thank you.
Apr 06, 2011 | Sanyo 42 in. LCD TV
2005 Chevy Silverado Bose stereo operators manual, how do I set the EQ presets?
My left front speaker sounds distorted at low volume but sounds ok when I turn up the volume.2005 Chevy silverado bose stereo and speakers
Apr 30, 2010 | OEM Systems Car Audio & Video
My left speaker is loose
The symptom you are describing is exactly what is known as a "BLOWN" speaker or the voice coil has "shorted", this is caused from the volume being up to loud, heating up the voice coil and frying it, in the future if the bass/sound is distorted then turn the volume down just enough to stop the distortion and this will save the speaker.
As far as getting a replacement speaker, you will have to contact the manufacture to get a replacement.
Good Luck !
Apr 21, 2010 | Philips FWC577 CD Shelf System
I have a problem with my car speaker/tweeter
Sounds like you have the ground and live possibly the other way around from the head unit to the speakers. The reason for you hearing it from both the tweeter and the speaker is that the tweeter is connected in parallel to the speaker.
Swap the wiring and try it.
Mar 21, 2010 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Car 6-9s soud crappy with new deck
what do you mean? distorted? low? echoey? i know you checked the wiring but try one more time. did you use a wire harness? remember the speaker wires out the radio with the black line on them is the negative side. make sure whatever color wire from the stereo that you plug to the car factory wire to, and know if it was positive or negative when you go plug it on the speaker.
May 25, 2008 | Sony Xplode P5 Turbo Subwoofers Car...
Speaker capabilites
I would say between 75 & 80. Or better yet, Just as it starts to sound distorted, then turn it down just a bit until it sounds good again. Clear i mean. Also if you want more volume out of that or you need it louder for whatever reason, you can hookup the output of the television to an Audio Receiver and turn it up extremely loud. Rock and roll. Good luck. Guru Jay
Feb 02, 2008 | Televison & Video
Distorted and low volume voices - Mr French
hi, first u will have to determine if the center output is bad or the cntr speaker is bad, to do so do not disable the center, simply remove the speaker wires and check if there is noise, if not means speaker is bad, if still noisy then output is bad,u will then need a technician to get the job done.. letr me know..
Jan 26, 2008 | Infinity CC-1 Center Speaker
Clarion DB358RMP CD Player Logo
35 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
