Question about Maytag Neptune FAV6800AW Top Load Washer
Nf error code - Maytag Neptune FAV6800AW Top Load Washer
  • 526 Answers
If there is no water in the wash basket/tub you may have a bad water inlet valve. Try filling with a water mix Hot/Cold will the wash tub will fill and proceed.
If you need further troubleshooting support post back...........**** or Rich
Posted on Oct 21, 2010
What does nf mean
NF = No Fill
Washing machine displays a 4E or NF Error Code
Last Update date : 2015.06.17
The 4E or NF error code indicates a water inlet problem or the machine cannot feed itself with water. Make sure the source water tap is turned on and check the water pressure.
To troubleshoot this error further, follow these steps:
Note: The steps below generally apply to all types of Washing Machine (Top Load, Front Load, Washer and Dryer Combo)
Step 1: Turn the machine OFF.
Step 2: Turn the water tap OFF.
Step 3: Remove the water hose from the tap and dispense the water into a sink.
Step 4: Remove the entire hose.
a. Check for Kinks.
b. Check for Clogs.
Step 5: Check if water supply is good.
Step 6: Check, remove, and then clean the first mesh filter (Brush under running water).
Step 7: Check and clean the second mesh filter.
Step 8: Test the unit by turning it on and by performing a normal wash cycle.
Step 9: If the issue persists, unit may require service. Inquire about the Warranty and Service Booking procedures for the unit.
May 06, 2016 | Washing Machines
Nf code and donnot continue to next cycle
Samsung Washer Error Code NF (Fixed ...
www.appliancerepairlesson.com/.../samsung-washer-error-code-nf-fixed/
Jan 11, 2014 - What does the error code NF mean on a Samsung washer? ... You can set the washer to any cycle and test each solenoid for proper voltage. ... Next would be to check the screens on the back where the water hoses connect. ..... Hi, you don'thave any power to the water valve wires when it should be filling?
Dec 15, 2015 | Frigidaire Affinity ATF7000E Front Load...
What does nf code for a Samsung front load washer mean?
Water Inlet problem.
a. Check for Kinks.
b. Check for Clogs.
Washing machine displays 4E or NF Error Code
Dec 02, 2015 | Samsung Washing Machines
What is Nf code
Dits a no fill error so you probably need to replace the water inlet valve. The link below goes into it in more detail. Samsung Washer Error Code NF Fixed
Oct 24, 2015 | Samsung SW62ASP Top Load Washer
FRONT LOAD WASHER samsung model WF338AAW/xaa
please see the cause and proceed to test the water inlet valve can be defective and replace it.use the common sense,see the diagram
God bless you
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Sep 19, 2012 | Washing Machines
HOW TO FIX NF CODE IN MAYTAG WASHING MACHINE
Hello & Welcome to FixYa
NF error in your Maytag is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
Oct 02, 2011 | Maytag Neptune MAH5500B Front Load Washer
Nf error code
The NF error codes stands for no fill. This is usually caused by hard water deposits in the fill valve screen. Youl will need to disconnect the water lines to the back of the washer and clean then out thoroughly. This should solve you problem, please rate my response if it helps you:)
Dec 02, 2010 | Kenmore Elite 45986 Front Load Washer
Nf error code sporadically
Tell me, do you notice the water filling and going against the "glass" door and going straight to the overfill trap bellow the door?
Let me know.
Dec 30, 2008 | Samsung WF203ANW Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
80 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
