Question about Canon ImageRUNNER 1670F Copier
Canon image runner 1670F
Hi....have a Systet error E003. Any ideas of how to fix??? Thanks, Bob
  • 4 Answers
The problem is :
During printing, the main thermistor detects less than120C°/248F for 1 sec or more continuously.
Replacing the fixing film unit.
See you,
Samir?
Posted on Jul 24, 2008
Cual es el fusor de una copiadora Image Runner 1670f
Canon Ir 1670 doesn't use fusor; it uses fixing film; part number is FM5-0992-000 @ 120V this issue happens frequently in these machines.
Roger
Dec 06, 2011 | Canon ImageRUNNER 1670F Copier
Machine will not do anything. says system error EOOO. what do i do?
E000 is an error for fuser related problems. the error history indicates any of the following error codes 4 times E001,E002,E003. Action : clear the error Execute #4 printer reset under #7 printer in service mode to clear the error, then off and back on the power.
Apr 16, 2010 | Canon ImageRUNNER 1670F Copier
System error E000
The problem discription is very long to be shared here, basically what you have to do is reset the copier
E000
The error history indicates any of the following error codes 4 times: E001,
E002, E003.
Action 1) Clear the error.
Execute '#4 PRINTER RESET" under '#7 PRINTER' in service mode to clear
the error.; then, turn back on the power.
It might be a good idea to get a service manual to get a good insite, here is the link for it;
http://www.techmanualarchives.com/canon-ir1630_1670-service-amp-parts--manual-25159.html
Feb 22, 2010 | Canon ImageRUNNER 1670F Copier
Cannon image runner 2200 error code E000002-0000, how do I fix it?
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
Sep 25, 2009 | Canon imageRUNNER 2200
Cannon copier image runner 1670f
the machine have toner,can you print a document.replace toner
Nov 04, 2008 | Canon ImageRUNNER 1670F Copier
Won't Print
Did anyone change some thing in the computer?? Or added new software?? Also, did someone change the user setting on the copier, Maybe to just a copier or just a fax??? Do some huntting and get back to us
Jun 25, 2008 | Canon ImageRUNNER 1670F Copier
Canon Image runner 1670F will NOT receive faxes
scroll through menu and look for powersave options using keypad and display
Jan 15, 2008 | Canon ImageRUNNER 1670F Copier
I have a Canon Image Runner 1670F
That is a fuser problem,lamp,or thermister.
Jan 10, 2008 | Canon ImageRUNNER 1670F Copier
Canon ImageRUNNER 1670F Copier Logo
152 people viewed this question
old marine
old marine
