Question about Dryers
Squee in the drum when its turning. its a moffat.can i grease it
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Oct 16, 2010
How do I take apart Moffat Dryer Model RVSR363EH7WW
It is very easy ,just lift top and remove front and pull drum out of dryer and do reverse to put them back
Feb 26, 2015 | Dryers
Moffat washer (mcch6110hww GE?) trips breaker shortly after start of cycle. Can this be repaired?
Sounds like your drum brake is engaging. Fixing it is fairly cheap. YouTube it and watch a few videos on how to do it if your fairly handy.
Feb 01, 2013 | Washing Machines
I have a moffat dryer and the drum won't turn, but the motor seems to hum like normal.
You probably have a broken belt that goes from the motor to the drum
Aug 19, 2010 | Dryers
How to replace rear wheel bearings
If it has drum brakes, you'll need to take off the center dust cap, remove the cotter pin, remove the nut and washer holding the drum on. The outer bearing should fall out, the inner bearing usually stays in the drum, due to the grease seal. With the front bearing and washer off, put the drum back on and install the nut, then pull the drum, allowing to the nut to catch the inner bearing as you pull off the drum, and that should leave the inner bearing and seal on the spindle. Pack the new bearings with grease, install the inner one in the drum and tap in the grease seal in place, but the drum back on and install the outer bearing on the spindle, the wash, nut, cotter pin and dust cover. Tighten the nut snug and turn the drum a few times and snug up the nut. Don't overtighten it.
Apr 29, 2010 | 1991 Volkswagen Jetta
I need to replace the front seal on the drum of my Moffat dryer (model # RCKH315EHWW, and am wondering if that is something that I would be able to do myself? Or, how much can I expect in labour? I already...
The drum gasket is WE9M26. To install it, it is the biggest job compared to any dryer gasket of hundreds of dryers that I have worked on.
See RCKH315EH0WW at:
http://partsnet.geappliances.ca
In summary:
-Remove top
-Remove console (some plugs require a tiny screwdriver to pry off. Do not pull on the plugs too hard.)
-Unscrew front panel (some screws are on the front of the bottom panel. Do not remove yet)
-Remove both side panels (cut off zip ties)
-Remove front panel
-Remove air director (big white plastic part)
-Do NOT remove drum. The belt is too difficult to reinstall.
-Apply contact cement in the groove in the air director. Install new gasket.
-When reassembling, line up the duct with the rectangular groove in the air director.
Good luck and congrats if you succeed!
Jan 20, 2010 | GE Dryers
My asko frontloader squeeks when the drum turns
It may be the seal needs to be greased (waterproof grease) where the drum shaft goes into the support bearings in the outer drum case--major tear-down! Check the front bearing for looseness or roughness while you are there. Make sure the motor drive belt is not causing the squeak first. Good luck!
Dec 16, 2009 | Asko W660
1952 Moffat Bake Stove
I have a working 1952 moffat stove with warming oven if interested
Oct 27, 2009 | Kitchen Ranges
I need a operations manuel for and E32 moffat
Try this site. http://www.moffat.co.nz/Catalogue/SalesPDF/E25.pdf
If this isn't it let me know and I will keep searching. Hope this helps.
Aug 27, 2009 | Moffat E32 Full Size Electric Convection...
Moffat heavey Duty Dryer
Hi and thank you for your request.
Assuming the marks were not there before you put them in the dryer, then there are a couple of possibilities for the marks appearing.
Check that none of the clothes lifters or ribs as they are sometimes called in the drum are not loose, as the clothes could get caught in any gaps,make sure that there is no large gap between the drum front and the front of the dryer, as again clothes could get caught here,,check to see nothing is stuck on the drum itself that could transfer onto the clothes.
Make sure the drum is free to turn and that there is no unusual noise coming from it, if it does appear to be noisier than usual ,then it could be the drum rollers or bearings are starting to wear and this could transfer grease and the like onto your clothes.
Hope these suggestions help with your prob.
Plz feel free to leave any comments and rate my suggestions.
Thanks
Jan 05, 2009 | Dryers
Dryers Logo
193 people viewed this question
Top Dryers Experts
