Question about Asko T731 Electric Dryer
How do I know if my heater element is faulty? My dryer won't heat up. The ducts and lint trap are clean, and the drum and belt work just fine.
  • Asko Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 16, 2010
Samsung Dryer dv203aes/xac will not heat. Drum is rotating and lint was cleared from exhaust.
Check the following:
1. Does it have 220 volts (yes it runs, but dryers run on 110 volts)?
2. Check the heating element and the safety thermostats located on the heat element canister. Low air flow from any restriction like lint build up or mashed ducting or blocked air exhaust vent cap can either trip the safety stats or burn out the element. Clean dryer and exhaust ducting thoroughly and replace bad parts before placing back in service. Poor air flow is the number one problem with "No Heat" dryer issues.
Sep 20, 2016 | Samsung Dryers
Dryer wont heat up
Small 3oo f fuse mounted on the heater element is probo blown from over heat due to vent blockage.
Dec 30, 2015 | Roper REX3614KW Electric Dryer
Why does the dryer take an hour and a half to dry a load of clothes
GE dryers usually have more than one heating element. Your machine probably has one failed heater and one good heater. The dryer will not get hot enough with only one heater working.
Unplug the machine! Check the heaters for continuity with a multimeter and replace if no continuity.
If the heaters are good, a faulty operating thermostat can also cause this symptom. It can turn the heaters off before the machine reaches the normal operating temperature.
Poor air flow can also contribute to slow drying. Check for lint buildup blocking airflow inside the machine and the vent duct.
Apr 28, 2010 | GE DBXR463EDWW Electric Dryer
It shuts off before the cloths are dry
Most likely either the lint trap needs to be cleaned out, the exhaust piping needs cleaning or you have faulty heat sensor / circuit breaker.
Be sure to clean the lint trap before every load may even try cleaning it out half way through the cycle too.
Good luck.
Aug 24, 2009 | Dryers
The dryer is overheating.
Fresh air is drawn in past the heating element into the drum out through the lint trap and exhausted outside the building. If the dryer protection systems are operating properly they will sense the over temperature and shut off power to the heating element via thermal switches. This will cause the elements to cycle on and off and reduce the drying ability.
Things to check.
First make sure you fill the dryer only about half full of clothes, usually the dryer capacity is around twice the washer capacity for this reason.
Second, make sure your lint trap and exhaust duct work from inside the dryer all the way outside are free from lint build-up. You should clean or have the dryer duct work cleaned either every year or two depending on the amount of drying you do.
Third, suspect is the dryer thermostat stuck in the on position. You may be able to test your drying temperatures by selecting (cold) fluff air setting, then the low setting and so on to see if that's working properly. If you can read electrical drawings, usually the manufacturer includes a diagram inside the control panel for service techs to refer to. You can test the flow of air out of the dryer by removing the hose from the exhaust, it should have a good volume of air when the dryer is running. After hooking the hose back to the exhaust duct work, check outside the building for the same air flow and don't forget to clean any outside flaps that keep the rodents out of the duct work.
Keep your lint low by not over drying your clothes. You will cut down on lint and prolong the life of your clothes! Dryers are one of the simplist appliances to figure out, unless they have complicated electronic control panels.
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
Frigidaire FEQ332ESO electric dryer: No Heat
There are usually two thermocouples in the dryer. One is somewhere at the front of the machine, under the lint trap, and the other is either right next to the heating element or behind the drum. They are usually a rectangular or diamond-shaped metal plate with a 1/2 inch high by 3/4 inch diameter cylinder on them. There are only two electrical leads on it. Unplug the leads and check with a continuity tester. If there is no continuity, the thermocouple is burned out. The most common cause of this is an obstruction in the exhaust hose at the back of the dryer to outdoors or a tight bend in that hose.
Mar 09, 2017 | Dryers
Overheating dryer
blowing when the tube is off usually = dryer fan ok, and is a sign that the duct is blocked past that point,
most commonly there is a blockage in the vent hood, the screen that keeps bugs and rodents from gralling up the exhaust, is also very good for catching any lint that squeezes past the lint filter.
most exterior hoods can rmove the screen for cleaning
any flexible ducting is a likely ara as well, the corrugations make a lint trap
check also that the duct from the heater element into the drum is not dislocated or blocked
Oct 23, 2008 | Amana Dryers
Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Jun 28, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Asko T731 Electric Dryer Logo
76 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
