I have the Prowler 4.1, and I don't have a lin-in input showing on the equalizer. Plus I do not get anything out when I plug into the line-in jack.
  • Glenn Overfield Oct 19, 2010
    I didn't think it was worth investing in the system. It is an old Windows Me system, works well otherwise.
  • 712 Answers
How old is it?
Posted on Oct 16, 2010
Studiomaster manual
On the rear panel there are two jack socket marked: Left and Right Insert.
These are connected to the graphic equalizer using two insert cables, one for each channel ( L & R). The cables have a stereo 6.35mm jack plug which plugs into the mixer, the cable splits into two mono jack plugs marked tip (or send) and ring (or return). The send (tip) connects to the input of the graphic equalizer and the return (ring) connects to the output of the graphic equalizer. How it works: The stereo jack interrupts the signal in the mixer and sends it to the equalizer, the equalizer processes the signal then sends it back to the mixer. Typical cable is shown below. If the equalizer has a different type of socket, phono for example you will need jack to phono adapters or insert cables with suitable plugs. Hope this helps.
Apr 05, 2014 | Audio Players & Recorders
How do i hook up my Ultragraph Pro 6200 equalizer to my Europower PMP5000?
You use special "insert cables" to insert the EQ into the path from teh mixer to the power amps. Thee cables have three 1/4 inch jacks and are a Wye type cable that connect the TIP of the TRS jack to the TIP of the plug to be plugged into the OUTPUT of the EQ channel. A second cable ties teh RING of the insdert jack into the TIP of a plug that lugs in the INPUT of the EQ. You need two of these special cables for stereo operation.
Apr 30, 2011 | Behringer Fbq6200 Ultragraph Pro Equalizer...
Hi, When I push the start button on my prowler 720 control box, it automaticlly goes from green to red. When disconnect the prowler from its control box it stays green. Is there something on the prowler...
The power cord pins are numbered, 1 through 4. So are the transformer plug holes (the female pin holes in the "power pack"). For example, if you don't match number 1 to number 1, the green power light on the transformer will light for about 5 or 10 seconds, but the robot will sit there... well, like a powerless robot. Match the pin hole numbers and you have a working robot!
Apr 22, 2011 | Pentair Prowler 720 Pool Cleaner
Im having problems installing my equallizer i have it hooked up to a amp. do i put the jacks to the 4 inputs or the 2 outsput jacks
Hi, the equalizer input is from the head unit preamp outputs and the equalizer output goes to the input jacks of the amp. There should be only 2 channels in and 2 (or sometimes 4) out of the equalizer. If you need more help, please provide model numbers of the head unit, equalizer, and amplifier and tell me all of the speakers you are trying to hook up.
Mar 26, 2011 | Car Audio & Video
Amp out and amp in for bose eq.hook up
  • 1
    Examine your receiver to be sure it has a tape monitor loop. Receivers with a tape monitor loop will have a button or switch on the front for "Tape Monitor," and have two sets of RCA connections on the back, one labelled "Tape In," and the other "Tape Out."
  • 2
    Take the two cables that are provided with the 901 speakers and insert one end of the first cable into the "Amplifier Input" jacks of the equalizer. Connect the red connector to the R input and the other connector to the L input. Connect the other end of this cable into the "Tape Out" connections on the receiver. Again, hook red to R and the other to L.
  • 3
    Connect the second cable between the "Amplifier Output" jacks of the 901 receiver and the "Tape In" connections on the receiver. Follow the guidelines in Step 2 for R and L connections.
  • 4
    Plug the 901 equalizer into a 120-volt electrical outlet. Your 901 equalizer is now installed.
  • Read more: How to Install a Bose 901 Equalizer ' eHow.com http://www.ehow.com/how_4813156_install-bose-equalizer.html#ixzz19vfsJTQu
    Jan 03, 2011 | Bose Audio Players & Recorders
    Audio-Technica freeway 200 Series VHF Wireless System - I had problems connecting the wireless system with a quarter inch to a xlr. The sound system made a very loud disturbance sound. What cable do I use...
    XLR connectors are a two-wire plus ground system. Using a 1/4 inch to XLR adapter may not connect the wires correctly to your sound system input.
    The A-T Freeway 200 Series has a 1/4" output jack. This would indicate a line level. A cable to connect the tip of the 1/4" jack to pin 2 of the XLR and the sleeve of the 1/4" jack to pins 1 and 3 of the XLR should work. The XLR should be plugged into a device that accepts line level.
    Ideally, you should plug the 1/4" into a 1/4" or RCA jack that is designed for line levels.
    Dec 14, 2010 | Audio Technica ATM33A Fixed Charge...
    Phono plays lower in volume than cd and tuner. Sounds ok i guess but is about a quarter to one third lower in volume. Is this normal ? Can I plug phono into cd jacks to check if any better ?
    Hello. As per the post before me, if you have a receiver with a Phono input(many receivers don't have one anymore) the output of a phono cartridge is around 30 millivolts, vs 300 millivolts for a CD(10 times the amount) or any other line level device. A Phono preamp, also has RIAA(recording engineering standards)Equalization that provides the proper equalization for a Phono cartridge. As per the other post, yes, it will sound very low, and unnatural sounding. If the input you are plugging the turntable input into, doesn't say Phono, you can purchase an inexpensive Phono preamp made just for this very issue. You can try Radio Shack, or find something of better quality on the Internet.
    Regards,
    Dave
    Jan 11, 2010 | Pioneer VSX-453 Receiver
    How to connect phono leads
    1. Step 1 Check the back of your Stereo for recording input(in) and output (out), your cassette deck may be plugged into these jacks.
    2. Step 2 Connect the RCA/Phono wires to your equalizer's input and output jacks on the back.
    3. Step 3 If your cassette deck or some other component is plugged into the recording jacks in the back of your amplifier, unplug it and plug it into the back of the equalizer under monitor jacks. Be sure that the "out" from the cassette deck goes to the "in" of the equalizer.
    4. Step 4 Now, take the wires from the equalizer and plug them into the amplifier in the same manner: "in" to "out" and visa versa.
    5. Step 5 Once all your wires are connected be sure the "tape monitor button" on the amplifier is on. Turning it off will disable the equalizer. You can still monitor your recording devise or cassette deck by the "monitor switch" on the equalizer.
    Mar 12, 2009 | Audio Players & Recorders
    No clue how to connect my equalizer
    FOR EXAMPLE IF YOU WER HOOKING IT TO A CD PLAYER,, YOU WOULD PLUG RCA JACKS IN THE LINE OUT ON THE CD PLAYER,, THEN PLUG THEM IN THE EQ WERE IT SAYS LINE IN OR AUDIO IN,,THEN TAKE SOME RCA JACKS PLUG IN THE EQ TO AUDIO OUT, THEN TO YOUR RECIEVER,, IN CD ,,AND VISE VERSA ,,WETHER ITS A TV OR PHONO,, ANYTHING,,
    Sep 25, 2008 | AudioSource EQ-100 Home Equalizer
    ACER X191 Monitor - Speaker input?
    go monitor back side and Saw of spk input point .input point name is line in .then insert the jack and connect ur pc lin out put point for Sound
    Dec 13, 2007 | Acer X191WSD Monitor
    Computers & Internet Logo
    21 people viewed this question
    David Payne
    David Payne
