Question about Nintendo Wii Console
I can,t connect my wii to my modem. what am i doing wrong i connected the usb but it keeps saying theres an error #51422
  • 100 Answers
Http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp this is to set up connection should help
Posted on Oct 16, 2010
I m trying to connect Internet but I m getting the error code 51422 Please help what should I do?
1. Make sure that you are using the Wii LAN Adapter made by Nintendo. LAN adapters not made by Nintendo likely will not work with the Wii console.
2. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off.
3. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
4. If possible, try another Wii LAN Adapter.
Aug 23, 2011 | Nintendo Wii Console
HI,I CANNOT GET A MOVIE TO PLAY IT ALWAYS SAYS ERROR CODE;51422 WHAT AM DOING WRONG
Hi im gonna go ahead and assume its a Nintendo Wii your using and you want to use it to play Netflix or some other online movie service.
That error code suggests its not connected to your network. Just follow the steps in this linkt o get it back up and running again.
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
Aug 11, 2011 | Nintendo Wii Console
Error code 51420 on my wii console. I am trying to establish a connection to the internet. I have a router which is working properly because i can get on the internet now. I have ran my ethernet cable...
Error Code: 51420 The Wii console is not able to connect to your wired router or modem.
  1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
    1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
    2. Select "Wii Settings".
    3. Click the left arrow to get to Wii System Settings 3
    4. Choose "Wii System Update"
    5. Choose "Yes" to connect to the internet and perform a Wii system update.
  2. Make sure that you are using the Wii LAN Adapter made by Nintendo. LAN adapters not made by Nintendo likely will not work with the Wii console.
  3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
  4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off.
  5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
  6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
Jun 22, 2011 | Nintendo Wii Console
Trying to connect with a wired connection that works because i know i use it for my xbox but it says something like code error 51420
not every USB to Ethernet adapter works for the Wii. Here's what I've found from Nintendo's site. You may need to connect with your Wi-Fi and update it first.
Error Code: 51420
2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
Apr 03, 2011 | Nintendo Wii Console
I am trying to hook my wii to the internet and it is saying unable to connect error code 51420 and i need free advice or help.
For any help click here
Jan 04, 2011 | Nintendo Video Game Consoles & Games
Just keeps saying error code:51420
Aug 18, 2010 | Nintendo Wii Console
Unable to connect to internet
Jul 06, 2010 | Nintendo Wii Console
Error code 51420
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
oishuk13
Dec 26, 2009 | Nintendo Wii Console
How do i get connection 24 on my wii?
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.....
Mar 09, 2009 | Nintendo Wii Console
Internet connection
Hi duncan_d,
There's one thing to check, if you can, try and access the internet with the wii and then on your laptop access the routers set-up page and just check the wii has an active session, it might also be a good idea to assign the wii a static IP address.
Assuming this is still not working, turn the Wii completly off (at the wall), leave for 10 seconds and turn back on. The Wii has a version of a linux operating system running on it, by rebooting it reloads a lot of modules, it might have been that the module that controls the usb or the network had stalled.
Beyond that, it would be a case of calling ninetendo. I know there are a lot of issues with the Wii's networking.
Jul 19, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
126 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
