Question about Ovens
I have a Bosch double oven and it continues to heat even when I turn it off. I then flip the breaker to turn it off. When I flip the breaker back on a code pops up (VO515 HOO47 F155 C2K2EAC) then the oven starts up without me touching anything. Please help
  • Ovens Master
  • 3,051 Answers
Hello there again
I know you rejected the chat and that is all right
Here is the part and what it looks like it may be a different color
Posted on Oct 16, 2010
Oven is two weeks old. Town had a power outage we reset at breaker but still just beeps once and nothing happens
power outages cause power surges when the power comes back on
this surge generally manages to fry the power/control board
I suggest that you get the services of the service centre to come out and check it out.
May 30, 2015 | Bosch 27" Double Wall Oven HBN56
How do I get the ovens working if the clock works, but they do not?
You'll have to make sure that the clock has been set for Manual cooking and not inadvertently set it on Auto. However if your breaker tripped because of a fault on your oven the internal switching of the timer may have been damaged as a result of the fault.
Nov 10, 2014 | Viking VEDO205 Electric Double Oven
Bosch double electric convection oven: top oven will heat and display code E1 15 once it gets to 350 degrees, will continue to heat with no response to temperature choosen. Set oven to 350 degrees and...
replace the oven temp sensor, it looks like a metal rod sticking out from the inside back wall inside the oven. part here....
http://www.repairclinic.com/PartDetail/Oven-Sensor/650101/1557889
Jan 23, 2018 | Bosch HBL3420UC Electric Single Oven
My frigidaire gallery series oven made a popping noise while heating up dinner in oven and now the whole oven is not working
Hello jnjpelli - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart the unit. If the oven does not turned on, then more than likely there seems to be a power supply issue. Also try checking the breaker and the power connections located on the back of the range. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues
Jan 19, 2013 | Frigidaire 30 in. Electric Gallery Series...
Have Whirlpool electric range super capacity 465 with accubake system oven will not shut off
Karen, We are sorry to hear about your Oven. We are happy to look into your concerns but we will need your your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com.
Jun 12, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
I have a GE Profile JT952series Electric Double Oven and the keypad is not turning on the bottom oven
Check your breaker box to make sure the breakers are ON.. these typically are double throw breakers.. it is possible one of them has been thrown open.. so flip that double throw off and back on.. then check..I have seen one side of these breakers fail.. unusual.. but it happens.. then a replacement is in order.. regardless. visually it may appear the breaker is closed..but upon closer inspection.. one side may be "spongy/open". There are always exceptions..so examine the breaker box carefully.
If one breaker is open..it would be wise to keep an eye on things to determine how it got that way in the first place. If the breaker will not close or throws/pops again..you either have a bad breaker or a wiring problem..in some cases the element may have grounded out..or burned a wire.. etc.
Next thing to check for is a bad element.. Remember..this is a 220volt hot circuit with a high amperage breaker.. BE CAREFUL.. USE CAUTION.. Failure to do so could result in serious injure or DEATH.
Turn off power at the breaker box to the oven.. test the working over to make sure the power is OFF.
Remove the oven racks
Remove the screws at the base of the element
Pull the element toward you
Note how the wire(s) are connected
Disconnect the wires.. checking for broken or lose terminals..if lose or broken..repair.
You will need a volt ohm meter for the following..
Test the Element for continuity. Place each probe on the terminal ends (manual will have ratings) generally if you have continuity it probably works..
Test for a grounded/short.. one probe to element the other to terminal end..if you have continuity.. it's shorted out. Test both terminals
Replace with a new one if needed.. reverse procedure. Turn on the power .. and test for proper operation.
Again.. 220 VOLTS..HIGH AMPERAGE.. USE CAUTION..not doing so could result in injury or DEATH
After you have done the above..and get an all pass..then it's on to controllers and temp sensors.
Best of luck
Apr 19, 2011 | GE Profile JT952 Electric Double Oven
Ge double oven JTP56 top oven heats slow and won't heat up to set temperature. fan comes on after a short time and continues on after oven turned off and never goes off. Oven continues hot even though...
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jun 25, 2010 | GE Profile JTP56 Electric Double Oven
My HBL452 double oven is slow to heat both upper
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
heatman101
Dec 01, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Fan won't turn off & upper oven work in Manual mode
This sounds like a control panel issue, you may have to replace it, about $300.00
Jul 09, 2017 | Bosch HBN 455 Stainless Steel Electric...
Ovens Logo
103 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
