Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
No cd, my pc doesn't connect to the router, no signal to internet
  • D-Link Master
  • 7,733 Answers
Vista have new router wireless network shows connected but not receiving packets
The problem is might be your computer is CONNECTED,but there are no network activity so you're receiving no packets
If you can't connected to the internet,then that network probably doesn't has an internet access on it
Aug 26, 2012 | Acer Aspire 7720-4428 Notebook PC
D-Link router switches off internet connection when tv/DVD remote is used
Hi, Your question is not so clear. For giving the proper solution I need to know something. As per my knowledge a fiber optic cable doesn't connect a router directly without a Media Converter. Secondly please tell me the model number and the brand name of your television. Third do you configure your internet connection on your television through IP address??
Jun 06, 2012 | D-Link DIR-300 Wireless Router
Hi, I'm trying to connect to a wireless network. When I connect to the network it says I'm not connected but also says
You should first reset your router then if that doesn't work you should run a Virus scan. If either of those don't work then you may be dealing with a WiFi card failure.
Apr 03, 2012 | ASUS F3E-B3 PC Notebook
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
Dlink DIR-600. I'm in an apartment where we're all connected to the internet through a router in another apartment (i.e., there's another router between the Dlink & the Internet). In...
It is pretty strange that only one PC is not able to find and connect to the network. All I can do is give you a few suggestions to check the Network and the PC Settings.
-The SSID Broadcast and DHCP Server should be ON from the router, so that the network/ router would be visible to all the nearby machines and could assign IP automatically.
- Try to move the PC closer to the router and see if it can find the signal (the PC wi-fi card may not be power enough to receive the signals)
- Make sure that there are no obstacles such as concrete walls, metal cabinets between the router and PC. This reduces the signals and the PC fails to recognize them. Based on my on-site experience, I suggest that you may relocate the router to another location depending upon your network environment. It has always helped me a great deal. Placing the router at the desk level, avoiding obstacles such as concrete pillars, walls, steel cabinets etc in the signal path have remarkable effect on range and overall performance of the network.
- Change the LAN settings of the PC to defaults.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | D-Link DIR-600 Router
My Belkin router cannot connet to internet. The internet lamp doesnt blinking.
you dont have a ISP connection.. or your cable is loosing.try to unplug and plug it again properly. if the lamp is not blinking.. im sure it doesn't receive a signal came from your internet connection.
Jul 05, 2011 | Belkin (F5D5231-4) Router
When watching a movie using my wii console. everytime i log on the internet w/ my computer. I loose wi-fi connection to the wii. and get an error code 52230
Error Code 52230 means that your router or Internet Service Provider is having difficulty assigning a DNS or IP address to the Wii. What this usually means when you had a connection and it drops is that you aren't getting a clean signal connection between your router and your console. First step, unplug your modem and your router wait 30 seconds and plug them back in. If that doesn't work:
Various factors affect connecting a Wii to the internet with a WiFi connection as well, including signal strength, distance from the wireless router to the console and obstacles such as walls and ceilings that interfere with the signal. If you're using a G router and you have your Wii too far away or, has obstacles (walls and ceilings) in the way, it will not connect. You should use an N-Router if there is a significant distance between the console and the router or if there are obstacles.
In your case it could be the wireless adapter on your computer is interfering with the Wii. Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker.
May 11, 2011 | Nintendo Wii Console
Lost setup disc(CD)......have a WRT120N Cisco/Linksys....and really cannot install it to connect wireless for gaming on Playstation 3 and for internet/email on Laptop.....Wondering if I could get a...
can you "see" your wireless in "available wireless networks" as you did before? if so you may just need to restart your pc if you haven't since you moved it. if that doesn't help you can check the router settings...
open internet explorer and at the top type "192.168.1.1" that should bring you to the log in page. clarkcanhelp_3.jpg
if you never changed it, try user-admin and password-blank. if that doesn't work try admin-admin, admin-password.
when you get in click on the wireless tab and make sure its on/enabled.
then go to security tab and make sure you lock out others from accessing your internet. clarkcanhelp_0.png
hope this helps
Apr 18, 2011 | Linksys WRT120N Router
I have two ParkerVision WR1500 4-port Wireless DSL/Cable Routers. The first one I have connected my Ethernet Cable from my modem to the WAN port. This is where I get my Internet Signal. My understanding...
You won't get internet connection that way because there is no connection between the first parkervision and the 2nd one.
Best way is use only one parkervision router. Connect WAN port to modem for internet, 1st lan port connect to your pc and 2nd lan port connect to 2nd pc in other room. 2nd way is, use only one parkervision. Connect WAN port to modem for internet, 1st lan port connect to your pc, setup wireless SSID and connect your 2nd pc to this router for internet wirelessly. Assuming your 2nd pc has wireless capability.
Apr 13, 2011 | ParkerVision SIGNALMAX WR1500...
No internet signal between router and desktop pc.
have you plugged everything in with the modem off and the router off?
have you tried unplugging the linksys for a sec then plug it back in?
also have you checked the pin connection on the plug on both the computer and the router?
what are the lights indicating?
Oct 14, 2008 | Computers & Internet
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
