Question about Canon imageCLASS MF8180C All-In-One Laser Printer
Asking to change paper size.
Message come up to check paper size and change paper size to A4 eventhough A4 paper is in machine. Also says cassette : LTR even though all is set to A4
Tks. Pat
  • 2 more comments
  • JohnKap Jun 11, 2008
    Mine does the same thing, except that it keeps printing and reprinting the last word document I sent to it.
  • j_czar_89 Jul 11, 2008
    Yo tengo el mismo problema
    y cuando cargo papel en el caset
    imprime una pagina de prueba
  • gfergus71 Nov 05, 2008
    I've have the same problem as above. Do you have a solution? please
  • Anonymous Mar 08, 2009
    I have the same problem "Change paper size"
y cada ves que cargo papel en el caset, sale una impresión de prueba
Posted on Jul 11, 2008
Canon IR1022if copier can't print in Legal size(8.5inx13in) using bypass or even paper cassettee
Did you trying hitting an Ok button, green button, etc to confirm legal size paper, maybe it wants you to confirm paper size. Also legal is 8.5x14, did you select legal or enter the size as a custom page?
May 22, 2014 | Canon IR1022IF 220-240 VOLT, 50/60HZ
Red light flashes, screen says "load correct paper: A4." The paper is alreay loaded. I cannot print.
When <LOAD CORRECT PAPER> appears on the display, the size of the paper in the paper cassette or multipurpose tray is different from that of the paper specified in <PAPER SIZE> for <CASSETTE> or <MP TRAY>. You need to load the correct size paper or change the paper size in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
Check if the size of paper loaded in the paper cassette or multi-purpose tray meets the paper setting specified in the machine.
check the following:
1. The paper size specified on the printer driver screen
2. Paper loaded in the machine
3. The paper size set in <PAPER SIZE> for <CASSETTE> or <MP TRAY>
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 16, 2013 | Canon ImageCLASS D1120 All-In-One Laser...
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
WHAT DOES LOAD CASSETTE PAPER CODE A4 ERROR ON A CANON MF3240 . WHAT DOES THIS MEAN? THANK YOU
I talked to tech support at Canon, and he explained that the document I was trying to print was originally scanned with an A4 paper size, and my printed is set to Letter paper size, thus producing the error code. A simple solution is to "uncheck" the box that says "choose paper source by PDF page size". It worked!!
Jan 18, 2010 | Canon Office Equipment & Supplies
Messege * load mp tray * but tray has plenty of
MP tray is not the cassette it this flap that pulls down above it.
The machine will revert to asking to place paper in its MP tray when the information it is receiving about the document from whatever program tell it that the size is not the same as what the cassette is set to...
so, check page size in of document in word program or whatever you are using
also check paper type and size settings match those you just checked in the printers properties under printers in control panel.
If you put a piece of paper in the MANUAL BYPASS TRAY bot the cassette it will print on that.
To get evverything back to normal, turn off printer, delete jobs in print que, change paper size of document in word/excell/etc is set same as paper type in printer, print again.. all should be good...
p.s. these are good quality printers that why I bother to answer you... cheers
Nov 12, 2009 | Kyocera FS-2000D Laser Printer
Kyocera FS-2020D won't print
You have to go to setting to change the cassette paper size , what happen is : in the setting that cassette has different size value, so when you try to print A4 it ask you to load it in the bypass or the Mp. all what you have to do is: go to cassette setting or comon setting and change the cassette siz to A4, and it will fix your problem.
Thanks for using Fixya
Oct 08, 2009 | Office Equipment & Supplies
How TO change paper size dc 3535
Enter in the user tools mode or mechanically in the paper cassette.
Sep 01, 2009 | Xerox Office Equipment & Supplies
CHECK PAPER SIZE
On the front panel:
Press the down arrow twice (Tray Menu)
Press the right arrow twice (MP tray size = C5)
Press either up or down button until display reads 'MP Tray Size = A4'
Press the start/stop button. Green light shows & A4 selected
(See pp 248 - 252 of the manual)
Dec 10, 2007 | Epson Aculaser C1100 Printer
Keep getting "11 load letter in tray 1" message
Are the print jobs being sent to printer all the same page size?
Are they all print jobs sent letter page size and your printers cassettes are set for A4 or something?
Your printer is asking for letter size paper, because any paper it has is not set to letter  and document that it is trying to print has been sent as that size.
Check what options you have on print driver on pc as far as Tray defaults, paper type and size settings
Check printer settings via its keypad as to tray defaults, paper size set for each tray and paper type, some printers have paper size switchs on their trays too.
Oct 26, 2007 | IBM Network Printer 12 Laser
Canon imageCLASS  MF8180C All-In-One Laser Printer Logo
694 people viewed this question
old marine
old marine
