Question about Cameras
My brother sending me packed toshiba camileo s 20, digital camera, i have purchase sd memory card n insert properly but this camera still messaging that memory full, on both still and vdo mode, also showing same message without sd card, so wat can i do now to use this camera, thanks khalid aziz (lahore pakistan) my email address< tricon_construction@hotmail.com
    Brigadier General:
  • 11,967 Answers
You must format the internal memory while there is no card in the camera.
Posted on Oct 17, 2010
Toshiba Camileo H30 only records onto built in memory. When I put in an SD card, gives an error message (a yellow exclamation point inside a folder). Please help. The camera is brand new. Regards, AL
The first suggestion would be to check if the SD card is the correct one, and if it is correctly installed. On my Hi-Def Hard Drive Camcorder, when properly installed, the SD card looks like it's "up-side-down" - with the little metal sensors upward. It is easy to accidentally put it in - what seems to me is "right-side-up". Then I see an error message and need to flip it over.
You might also check to see if the metal sensors on the SD card are all intact. Sometimes one of the little metal sensors are slightly out of line or maybe bent.
May 15, 2011 | Toshiba Camileo H30 Hard Drive Camcorder
Ny Toshiba Camileo P10 is reading "card locked"
Take a look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Feb 19, 2011 | Toshiba Video Cameras
Memory card error
Having gone over a month with no response, I assume it was just a matter of SD versus SDHC cards.
Jul 17, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
C190 does not read the sd card even when sd card format is ok . it is giving a message 'memory card requires formatting' 'please format memory card or insert another card' however inserting a new...
Hi sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 20, 2010 | Kodak Easyshare C190 12MP Digital Camera...
    Memory card Sandisk 4GB gives error memory card
    The S50 uses SD cards. Your 4GB card is actually an SDHC card, and will not work in the S50. You will have to confine your choices to cards 2GB and smaller.
    May 15, 2010 | Pentax Optio S50 Digital Camera
    The camera works fine without a card in, but when the memory card is put in it doesnt. i changed the card and no difference. PLEEASE HELP
    The cause and solution may include one of the following:
    1. The card may not be certified SD. Please purchase a certified SD memory card. For example: Sandisk, Toshiba, Panasonic, etc.
    2. The card may be corrupt. Reformat the memory card.
      CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
    3. The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
    Feb 13, 2010 | Casio Exilim EX-S500 Digital Camera
    SD card - memeory card parameter error
    Some camera's, especially older ones, have a limit as to the maximum size of the memory card that they support. Look in the manual to see what the camera can support.
    Jun 12, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
    Cameras Logo
    59 people viewed this question
    Top Cameras Experts
    Steve
    Are you a Camera Expert? Answer questions, earn points and help others
