Question about Craftsman Garden
2007 craftsman dys 4500 model # 917276905 rear axle seal leaking, need to repair and add hydraulic fluid
    President:
  • 1,851 Answers
Call your local sears company parts house they will fix you up.
Best of it
Posted on Nov 03, 2010
LEAKING OIL right transaxle
Johnny, Transaxle needs a new seal. you can get or order your seal from any local small engine repair shop. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
TORO Wheel Horse Hub Removal and Transaxle Seal Replacement
Replacing oil seal on rear axle of Lawn Tractor 917 288250 ShopYourWay
2007 Craftsman 917 287210 Lawn Tractor with leaking Transaxle
Rebuilding lawn tractor transaxle Part 1 of 2
lawntractor transaxle seal Google Search Ord
Aug 25, 2016 | Garden
I would like to see a diagram of the pully under the engine.
Rod, Check the attached links,manual,instruction and guides for Lawn tractor. Good luck
917288320 CRAFTSMAN TRACTOR Manual Sears PartsDirect
craftsman dys 4500 belt diagram Google Search
How to Change Replace Main Transmission Drive Belt Craftsman Lawn Mower...
May 23, 2016 | Garden
I need the blade belt routing for dys 4500 42" cut
Mike, Check the attached links,instruction and guides, Good luck
Replacement Parts Accessories Sears PartsDirect
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0701547.pdf
EASY CRAFTSMAN DECK BELT INSTALLATION
May 07, 2016 | Sears Garden
2007 Sierra, Loss of Brake fluid with no visible leaks.
if you have a hydraulic clutch ( no transmission offered) check the slave cylinder for leaks ( some cars use the brake master cylinder as a reservoir for the hydraulic clutch)
check the brake booster to master cylinder mounting for leaks or the rear seal of the master cylinder may be faulty allowing fluid to pass to the booster chamber
check for a leak under pressure at the rear flexible rubber hose from the body on
Apr 05, 2016 | 2007 GMC Sierra 1500
How to add brake fluid international 574
It has hydraulic brakes, you will have to bleed the brakes. There is a bleeder screw on top of each rear axle, and it looks like a grease zerk.
This procedure will require a clean bucket and 1/4, 3/8 or 5/16 inch clear tubing that will fit over bleeder screw nipple.
To bleed the brakes run the tractor until the Hytran hydraulic fluid reaches operating temperature.
Run engine at fast idle 1400-1600 RPM, block rear wheels.
With tubing connected to nipple on bleed screw and other end in clean bucket, loosen bleed screw and let hydraulic fluid drain until you are air bubble free, then close bleed screw. Repeat on other brake. Do not pump brakes while bleeding.
Check and if needed, Top off the hydraulic fluid with clean fluid, make sure transmission fluid level is full or over full. Also check for leaks at the bottom of dash and along the top of transmission cover. The brake lines run from under battery box along the top of transmission and then go to the rear axles.
You might have to repeat the bleeding process to get all the air out of the lines, if the bleeding works but only lasts a few days then it probably has leaking seals in brake pistons.
Jun 27, 2014 | Garden
Diagram for drive belt Craftsman DYS 4500
Most of the time,it is under the left foot rest,if not, try the right side. You can usually,locate it in the Owners Manual,for your model tractor. Hope this works for you. Sincerely,Brad Locke 11/23/15
Aug 13, 2012 | Craftsman Garden
Im leaking transmission fluid and i dont think i have coverage to repair it
Generally the trans pan is first to leak on any transmission. If the perimeter of the pan espeacially the mounting bolts are wet with red fluid change the filter and gasket. Add transmission fluid as recommended in the owners manual also
If the leak is between the engine and the trans the front pump seal or pump seals need replacement.
If leaking at the axle shafts the axle seals need replacing
Jul 29, 2010 | 2008 Mitsubishi Lancer GTS CVT Sedan
Rear brake drum leaking on my 1989 ford bronco 2 y did it happen and how do u fix it
The drum isn't leaking, either the wheel cylinder is leaking or the line is leaking
Oct 07, 2009 | 1989 Ford Bronco II
Garden Logo
604 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
