I have a new world stowaway 411, the pilot light is on but i cant get the heating to come on?
    Problem Solver:
  • 8 Answers
CHECK YOUR GAS SOURCE
Posted on Oct 17, 2010
  • classictabby Oct 18, 2010
    Check the fuse. I had the same problem with the same boiler yesterday, changed the fuse (in the switch on the wall next to the fire/boiler) and my boiler is igniting again now.
My Kozy world wall natural gas unit starts heating the ceramic part when I try to start pilot light. Both light then go off when I release knob being held down during the lighting process. What part needs...
Pilot fail censer,if this is a free standing pilot that stays lit all the time then replace the thermonuclear, if it is electric ignition then replace the igniter.
Feb 09, 2018 | World Heating & Cooling
Pilot light is to high and all burner are red but the center and it burnes blue on a list world knw321 what could be problem and how do I adjust the pilot light it is to high
You've got a red flame then you need to shut down the unit IMMEDIATELY!!!!! This due to incomplete combustion and could be due to a lack of fresh oxygen entering into the unit, or the units exhaust is block somewhere in the line. Shut it down now and call an expert!!!!! Gas Flames Yellow vs Blue Gas Flame Colour Temperature
Jan 22, 2017 | World Heating & Cooling
I have a kozy world knw321 and pilot light is to high can this be adjusted i have tried blowing it out other heaters are burning fine but this one is burning to high don't know how to adjust it
Yes,pilot should be adjustable, but problem may be dirty accumulation on pilot fixture. With gas SUPPLY off, remove the grill and clean the pilot orifice and anything that might block air getting to the flame.
Check the hole where gas comes out of the pilot for accumulation of deposits. DON'T enlarge this hole beyond its original size.
On adjusting, you look at the gas valve and find a cap or screw that is identified PILOT adj.The actual adjustment screw is sometimes under the top cap or screw. If you're not sure, call someone who is knowledgeable.
Turning this slightly will adjust flame. don-ohio
Can the 3 way gas tap be replaced with two independent cut off valves by a GAS Safe installer?
sorry that is something you need to check with the gas company about .
Dec 01, 2016 | Water Heaters
New kozy world natural gas heater. Pilot light wont stay lit snd heater flame wont stay lit.
Are you holding down the pilot light button long enough for the heat sensor probe to get hot and turn on the gas valve? It takes up to 3 minutes
Nov 20, 2016 | World Heating & Cooling
New thermocouple on GE/rheem water heater pilot still won't lite
does the pilot go out when you let off the button? Or does the pilot not light at all?
If you dont get any gas at all to the pilot the the gas valve is bad.
Of you get a pilot light that goes out when you let go of the button then the therno couple is not reading the flame (needs adjustment so the pilot flame touches it)
did you kink the new thermocouple? or over tighten it at the gas valve.
if it was kinked its now toast,cant straighten them. If kinked and starightened the fluid inside has broken the inner seal and wont work.
Jan 10, 2013 | GE 50 gal. Heat Pump Electric Water Heater
I just bought a brand new Kozy World blue flame heater and the pilot light will not stay lit and when it is lit, it goes out as soon as I turn up the nob.
The thermocouple is bad or not aligned properly. It is the metal bar in front of the pilot light. This bar senses the heat put off by the pilot light. If it does not get hot it will not allow the gas to flow. You either need to align it so that it is in front of the pilot light and receives enough heat to allow the gas valve to operate or possibly the thermocouple has gone bad and needs replacing.
It could also be that you are not waiting long enough. The thermocouple must sense the heat for at least one minute or more before it will let the gas valve turn on. Turn everything to off for at least five minutes. Re-light the pilot light and let it burn for at least one minute and then try turning the knob to on.
Nov 25, 2010 | The Companion Group Kozy World Portable...
Furnace wont light properly.
You have to press the red buton below the off/test selector for about 1 minute until the flame sensor detects the heat coming from the pilot before switching the gas valve to on.
Dec 04, 2009 | Heating & Cooling
Heater won't light
YOU HAVE A BAD THERMOCOUPLE. IF YOU LOOK AT THE FLAME you should see a little match size piece of gold metel connected to a metal tube like then screwed into the gas valve. what happens is when you light the pilot, the gas heats up one end of the thermocouple and the other end changes that heat into microvoltage. the gas valve senses the microvoltage , knows the pilot light is lit then opens the main gas valve. when they go bad they cant send voltage to valve and th valve locks out. you always have to start at off. then depress valve button and turn to pilot and light it. hold button down 3 minutes then turn to full open or main the thermocouples are cheap, call supply houses or service companoies till you find one that will sell you one. unscrew the thermo couple from the valve with a little wrench unwravel the excess tubing , size of a pencil lead in diametor, then the probe part usually slids up through a spring like holder, note position of old sensor before reoming. get end half of new sensor into good pilot flame. reuae old retainers or new ones that come with new t couple.
Oct 09, 2008 | Procom ML060HPA Heater
Heating & Cooling Logo
474 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
