No sound from my computer. It says there is "No Audio Device" when I click on the volume control. Is the sound card incorporated in the motherboard? My motherboard's name is Asus P4GE-MX. thanks.
  • Computers & ... Master
  • 5,660 Answers
One way to know if you have Integrated Audio, is to see if the speakers plug into audio ports on the motherboard.
The Asus P4GE-MX does have audio ports on the motherboard.
(Integrated is also known as OnBoard. ON the motherBOARD.
The device chip is soldered to the motherboard.
Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit )
Asus Support > P4GE-MX
http://usa.asus.com/product.aspx?P_ID=JdzKwFSqhlt5OPiW
Click on the Specifications tab.
Audio - ALC655
6 - Channel Codec
You need to download the Driver file, and install it. (Device driver)
(A Device Driver is a small piece of software that allows the O/S to 'communicate' with the device, and vice-versa, and also programs that utilize that device.
O/S = Operating System. One example is Windows XP.
http://en.wikipedia.org/wiki/Device_driver )
Click on the Downloads tab.
Now click on the + sign to left of Audio (1)
Click on Global (DLM) or China. I suggest Do Not click on P2P
Type the characters you see in the Captcha box. (Letters/Numbers. For letters be SURE to put CAPITAL letters)
Click on Submit.
[ If you want the Motherboard Manual for your P4GE-MX, click on the Downloads tab.
{It will state 0 files found}
Then to the right of the Operating System box, click on the blue Down Arrow.
Now click on WinXP.
{Doesn't matter WHAT O/S you're running, a motherboard manual IS A motherboard manual.
Asus, sheesh!}
Now click on the + sign to the left of Manual (5)
Go down the list until you come to the heading -
Version E1862
Now click on Global (DLM) or China. (I'm in the USA, and have better luck with the China server)
Type the letters/numbers you see in the Captcha box. (Use CAPITAL letters!)
Click on Submit ]
Posted on Oct 16, 2010
I have a gigabyte 945 motherboard i attach a new sound card but no sound in the computer what can i do
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Oct 31, 2011 | Computers & Internet
No sound on pc,,ran diagnostics and i hear sound from test on headphone jack,,,left plugged in restart pc,, still no sound,,hardware or software////??
also
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
if you dont have a motherboard disc you will have to download the drivers
click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
hope this helps
Sep 06, 2011 | Dell (8H390) Sound Card
No sound
also
hope this helps you
Aug 26, 2011 | EliteGroup M810DLU Motherboard
Creative labs sb0410
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable) also you might check
you might have to uninstall your sound card restart your computer then reinstall it
if you don't have the motherboard disk or the sound drivers you will need to download them
Aug 04, 2011 | Creative Labs Sound Blaster Live! 24-bit...
NOT ACTIVE AUDIO WINDOWS XP.....WHAT THIS IS SOLUTION ASUS P5KPL-AM SE
Click Start, click Control Panel, double-click System, click the Hardware tab, and then click Device Manager. 18abb370-ac1e-4b6b-b663-e028a75bf05b.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation. Double-click Sound, video and game controllers to expand that category. If a sound card is listed, you have one installed. If no sound card is listed, check the information that came with your computer to see if there's supposed to be a sound card installed. If there should be a sound card installed, you'll need to install one.If you think you have a sound card installed, but you don't see it under the Sound, video and game controllers category, expand the Other devices category and check any devices listed there.Laptops don't usually have sound cards. Instead, they have integrated sound processors, which appear in the same category in Device Manager.
If there's a yellow question mark next to the name of the sound card in Device Manager, there might be a problem.
  1. Right-click the name of the sound card, and then click Properties.
  2. Click the General tab, and then look in the Device status box to identify problems with the sound card.
  3. Although most speakers have a volume control, you can control the overall level of sound using Windows.
    1. Open Volume Control by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then, under Audio Devices and Sound, clicking Adjust system volume.
    2. Under Main Volume, move the slider up or down to raise or lower the volume.
Aug 04, 2011 | ASUS P5KPL-AM SE Motherboard
Sound card
If you are referring to to or having problems with you sound
also
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 29, 2011 | EliteGroup 661GX-M Motherboard
Sound device not found in C 700 compaq
the sound drivers might not have been installed for the sound card
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers :
also
Jul 08, 2011 | Compaq Audio card Sound Card
The operation system in my computer is Windows xp professional service pack3. I have intel D101GGC motherboard. I installed the audio driver AUD_XP_5.10.0.6201_PV.exe to my computer but it was not...
you might not have a sound card installed on your computer or it might not be recognised due to a dirty socket if there is a sound card you could remove it from the socket and clean it if your computer came with a motherboard disc the sound drivers could be on it
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
you might have to get another sound card or a portable usb sound card if you dont have a sound card installed
hope this helps
Apr 13, 2011 | Intel D101GGC Motherboard
No sound device detected. need driver installler for sound card
if you are having problems with your sound
also
hope this helps
you might have to get a portable usb sound card if you mean dont have a sound card installed
Mar 30, 2011 | Asrock N68PV-GS Motherboard
No audio device, mixer device, sound device for my matsonic 9158E+ motherboard possibly loss from a previous formatting. please send me free download for said problem. tanx
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer dont forget to vote
hope this helps
Feb 02, 2011 | Matsonic MS9158E+ Motherboard
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
